Home > Maintenance & Modifications > clatter clatter....could it be.....
Page 5 of 9 <123456789>
ian series 1
United Kingdom 2008 Defender 90 Puma 2.4 CSW Bonatti Grey
Might be a daft question?
But have you considered the swivel housings?
These can "knock" if badly worn, although I assume yours is quite a late model? 80" 80" 86" 88" 90"
Wanted, Forward Control Anything considered.
Post #422754 11th May 2015 9:22pm
Caterham
thanks Ian. I believe they were looked at briefly and dismissed - done 55k miles so hopefully they should be fine?
back to my previous question - I presume there shouldn't be any knocking what so ever?
Post #422791 12th May 2015 7:27am
munch90
Should not be knocking , if only pulling pushing by had on wheels
Post #422984 12th May 2015 7:53pm
Caterham
Def was up in the air last night...but before that we noted there was no knocking on full r/h lock.
Up in the air it was difficult to replicate knocking - moving the wheels into full lock positions appeared to replicate knocking. Front drive flanges have worn causing play in shafts and my defender wizard feels there is something not right with axle internals but unfortunately we ran out of time to investigate further Sad
Will keep you posted.
Post #423211 13th May 2015 2:45pm
Do you have a two-gear or four-gear front diff?
Post #423214 13th May 2015 3:12pm
Caterham
Got a bad memory so can't really for sure but seem to recall having a look through the fill hole and thinking it's a 4 pin - but can't recall why I think that?
It's was also mentioned that there is concern over the CV's too?
Post #423222 13th May 2015 4:03pm
Caterham
Might be on to something.....was eyeing up the flanges tonight before fitting. Just so happens the front o/s which is the six that knocks doesn't have any shims between the circlip and the drive flange and hence some free play! ?
Post #434363 28th Jun 2015 8:43pm
Lorryman100
Shims are not always needed, depends on what the end float reading is using a DTI gauge. If I was paranoid I would be more worried that it was a 2 pin diff fitted and the pin had worn an oval hole and was about to fall out causing a catastrophic failure. Twisted Evil Whistle
Post #434368 28th Jun 2015 8:52pm
Caterham
Shocked
With comments like that I trust you are keeping well Brian?
Not sure what a DTI gauge is (yet) but think I'll get a variety of shims ordered up......
Then just wait for my new axle before my oval pinion thing bang Razz
Post #434387 28th Jun 2015 9:46pm
Caterham
Before I upset anyone i'm not questioning if you need a DTI gauge or saying the accuracy of the shims being fitted isn't important but I'm curious as to why?
Unlike the rear I presume it's to do with ensuring the cv is aligned with the pivot point of the hub?
If out of centre I presume this could cause a gyroscopic effect on the cv when turnkey but wouldn't be an issue in a straight line?
Thanks
Post #434391 28th Jun 2015 9:58pm
Lorryman100
Busy but doing well Wayne, You????
DTI Gauge: Dial Test Indicator
http://www.machine-dro.co.uk/indicators-an...e.html?p=2
Post #434396 28th Jun 2015 10:09pm
Caterham
Over worked and all that......... Crying or Very sad
Yes just looked on the net and see what you mean......
Had I not been told about a DTI I'd be pulled the shaft out and put a feeler gauge between the flange and circlip?
Post #434397 28th Jun 2015 10:13pm
Caterham
anyone able to give me an idiots guide to putting a video on here or want to offer me their email address to do it for me?
and perhaps that will be the key to finding out what the knocking noise is?
done it!
&feature=youtu.be
any ideas?
Post #437646 14th Jul 2015 12:39pm
Caterham
go on.....who's going to be the first to admit that just may be.....just may be I've been right all along and something isn't right and that it's not just my imagination?
Mr. Green
Post #437661 14th Jul 2015 2:11pm
Clive
That's deffo not right for sure Confused
I had something very similar once where the bolt through the Panhard rod bush, (chassis end,) was a bit loose and the bolt shaft had worn to an oval shape allowing a fair bit of play within the metal inner bush.
Post #437675 14th Jul 2015 4:11pm
