Home > Maintenance & Modifications > clatter clatter....could it be.....
Page 3 of 9 <123456789>
Caterham
What I did was removed existing tre position onto a length of wood and then assembled new steering rod and tre's to match markings on wood. Assembled steering /tre's dropped straight into uprights no bother and as such was really surprised to see how much steering wheel is now off centre compared to host it was?
Post #413647 3rd Apr 2015 11:46pm
K9F
As Munch said get your tracking done professionally before we're subjected to another plethora of threads and/or posts about tyre wear, vehicle pulling to the left or right or any other issues caused by your recent bout of tweaking and fettling in pursuit of your Holy Grail.......'perfection'......PLEASE!
Bow down Bow down Whistle If you go through life with your head in the sand....all people will see is an ar5e!!
Post #413649 3rd Apr 2015 11:52pm
Caterham
I will need to get the tracking done properly - but I still need to fit the short steering rod first.
Truck getting the once over tomorrow along with some tweaking so hopefully can report back soon.
Sorry munch90 I don't think I commented on your earlier assumptions of being low mileage... done almost 53k trouble free miles.
Happy Easter weekend all. Thumbs Up
Post #413652 4th Apr 2015 12:00am
K9F
Now that is funny. You're telling Porkies as it is definitely NOT April 1st. Laughing If you go through life with your head in the sand....all people will see is an ar5e!!
Post #413715 4th Apr 2015 10:08am
munch90
trouble free Whistle
your never get it right measuring on a piece of wood
1/2 turn out and it will show on tracking gauges
Post #413717 4th Apr 2015 10:13am
Caterham
So ok there's been the odd inconvenience along the way......... Rolling with laughter
Nothing that ever bothered me very much though. Whistle
Will get a few photos and general update later etc.
( still surprised re the tracking - clearly I got it wrong but to be honest a full turn appeared to show up on the length of wood as either too long or too short and the fact that the new track rod just dropped straight into the uprights I was sure there was no change )
Post #413718 4th Apr 2015 10:29am
Happyoldgit
What does
mean? Which rod? Steve.
http://forums.lr4x4.com
Post #413831 4th Apr 2015 9:35pm
Caterham
Got a feeling I'm going to use wrong terminology here but I'll try all the same....
I've fitted to track rod and new ends (one of which was shot), gone for the terrafirma HD version (ends have grease nipples) and surprisingly this seems to have put the steering off centre however I've yet to fit the short steering rod (also terrafirma HD version) that goes from steering column / gear to the o/s wheel upright and I believe I can use this to correct the position of the steering wheel?
Thumbs Up
Post #413836 4th Apr 2015 9:50pm
Caterham
so clank on switching engine off seems to have gone, not had the serious clatter in 1st gear (although still early days to say for sure) so it's all looking good.
I've also had the quantum leap generator installed. as some of you lucky enough will know once activated generators huge gaps between the rear view mirror and the automobile behind ( Mr. Green ) thanks to an extra 90 Nm over standard.
will be doing a few miles this will so will let you know how I get on, but for now Very Happy
Post #414378 7th Apr 2015 7:01am
Caterham
damn it and blast !
why did I give the wheels a shake yesterday?
there's a clatter there again ! it might simply be the brake disc shields / plate things rattling or the brake pads but I don't think so.....could it possibly be the clutch plate rattling when shaking the wheels?
the other thing IS the clutch - can anyone explain what (other than me not depressing the clutch far enough) would case the clutch to drag. ie occasionally from stationary there's a clunk (like engaging diff lock) when going from neutral to first - this 'dragging' effect I'm concerned might be having a detrimental effect on me changing gear ie does the ECM not see a proper drop in torq on the engine and therefore not do the gear change harmonisation properly which prevents me from being able to adjust engine revs properly for a smooth gear change ie sometimes when changing gear it's like the load pedal has become non responsive? in the same way when you slow down to a stop the engine revs drop to c800 rpm when there's no load on the engine - with load it's at about 900 rpm?
Question
Post #422555 11th May 2015 8:15am
munch90
think you would need to be superman to make clutch springs rattle by shaking the wheels !!!
clunk , transfer box shaft ?
thought you were going to get clutch done ?
Post #422557 11th May 2015 8:22am
Caterham
just waiting for a date to get clutch and extension shaft replaced. I'm hoping that will sort 'everything' out. (really can't wait).
that said I'm curious what could be 'clanking' when shaking the wheels....are they all like that?.....remembering I'm only 10.5 stone so certainly not superman. 'clanking / rattle' seems to be coming from the front but I can hear it if I shake the back wheels too?
Confused
Post #422558 11th May 2015 8:33am
munch90
shaking wheels , top and bottom ? front and back ? rotating ?
so hands 12 & 6 o/clock on wheel ? or 3 & 9 on wheel ? or spinning wheel etc ?
Post #422559 11th May 2015 8:52am
Caterham
Def is just parked up on the ground.
holding tyre at 12 o'clock position and pushing / pulling generates a clank clank clank type sound?
it does sound a little like the disc back plates are hanging on a piece of string clanging but if I tap them they are secure and no rattle?
Post #422563 11th May 2015 9:13am
munch90
front radius arm bushs ?
play in bush letting arm touch axle ?
any play when wheel jacked up ? which wheel ?
Post #422565 11th May 2015 9:27am
