Home > Maintenance & Modifications > clatter clatter....could it be.....
Page 4 of 9 <123456789>
Caterham
Munch90,
just been out to give it another shake and basically if I shake any of the wheels (front or back) as soon as the front starts moving left / right I can here the noise coming from the front somewhere?
a quick visual and all of the bushes appear ok - the steering is in the straight forward position?
I presume first and foremost - is this actually normal or not. for all I know it could actually be normal?
Post #422566 11th May 2015 9:36am
munch90
rod that comes down from steering box the n/s of axle bushs ( panhard rod ) that stops left to right movement of chassis/axle
look for brown dust around bushs
NOT steering rod
I know you played with it a while ago , something loose ? Whistle ( no offence intended )
Post #422567 11th May 2015 9:43am
Caterham
tracking rod and steering rod replaced and they've been checked so not loose.
this noise was there before replacing the above.
reference your note below - sorry are you referring to the panhard rod or something relating to the steering box (sorry?).
in the meantime I'll go have a look at the panhard rod.
Thumbs Up
ah! forgot to mention. I know the defenders suspension isn't renowned for being silky smooth like a Citreon DS but I'm sure mine has become more crashy than usual. thought the new wheels/tyres might have been over inflated but they're right?
Post #422571 11th May 2015 9:57am
munch90
yes panhard rod mounts from near bottom of steering box to axle near radius arm mounts ( rubber bushs in each end )
make sure bolts though all bushes are tight and look for brown dust
all bushes could look all good , but movement/clunk could be between bolt and centre metal tube of the bush , make sure bolts are tight
bet the neighbours think your mad keep going outside and wobbling your defender ! Rolling with laughter
Post #422574 11th May 2015 10:03am
zone30
Belgium 2011 Defender 110 Puma 2.4 X-Tech LE Nara Bronze
Post #422576 11th May 2015 10:06am
Caterham
I wish I was at home - the neighbours as used to it.........I'm at work - god only knows what everyone thinks Rolling with laughter
thanks zone30 will have a looks.
Post #422579 11th May 2015 10:23am
Caterham wrote:
the other thing IS the clutch - can anyone explain what (other than me not depressing the clutch far enough) would case the clutch to drag. ie occasionally from stationary there's a clunk (like engaging diff lock) when going from neutral to first ....
There's always some "drag" (as you call it) through a clutch when disengaged, due to friction in the spigot bearing and the possibility of friction in the clutch hub splines causing the driven plate still to be lightly in contact with the pressure face of either the flywheel or cover. Very often this is wholly masked by the synchromesh on the gear you are engaging, and drivers with no understanding of the internal workings of a transmission won't know it is happening. If you have a particularly free-running gearbox it is even more likely.
Those of us who cut our teeth in the old days when there was no synchro on 1st, 2nd, or reverse are well aware of this phenomenon - you will recognise us because we slip the box into third before engaging 1st, 2nd or reverse from rest (and of course we double declutch up and down the box).
After pressing the clutch to the floor, how long do you wait before engaging first gear? Long enough for all the gubbins to stop whirling round, or are you synchro-dependent?
Post #422602 11th May 2015 12:01pm
munch90
yes agree blackwolf
caterham , try slowing down ( you not car ) when selecting gears
Post #422603 11th May 2015 12:04pm
Caterham
not wanting to take anything away from your comments above but I have been driving for almost 30 years and granted the oldest car I've driven may only go back to the mid 80's I've been very lucky to have never experienced anything similar before. .......
hold on before I go any further.......my last 07 def didn't have any gear change problems (rough engine, abs lights, etc but never recall any gear change problems)?
back to the clutch....so I can start up in the morning....no rush and a clonk just getting it into first - certainly no fast gear change?
Post #422604 11th May 2015 12:15pm
Does it do it if you select a different gear cluster first?
If there is a problem causing this, it could be clutch springs, other clutch problems, weak synchro, or other transmission problems.
On a lighter note (and please don't take offense, because sincerely none is intended) how have you managed to drive for 30 years without learning more about how vehicles work along the way? I always had you down as a relative youngster and on your first Defender!
Post #422610 11th May 2015 12:21pm
Caterham
Laughing
perhaps just a young brain !!! Rolling with laughter
not done much mechanically albeit I have built a westfield from space frame up and a caterham.......
personally I think I'm fairly mechanically minded...the problem lies (in my eyes) more with me thinking there's a problem and everyone telling me it's me. hopefully one fine sunny day I'll be able to say - there you go 'that was the problem' all along.
another thing that doesn't help much is not having the time to get stuck into stuff as this is my daily commute and let's be honest even the defender is incredibly complicated these days - for example you pull off in 1st / 2nd low range up an incline and the engine is lurching at slow speed - where do you start - mechanical / drive train slack, turbo actuator sticking, faulty sensor such as high low affecting throttle response, VCV on the fuel, lose connection........
it's probably just me - but in my eyes something ain't right and it's doing my fruit in. Very Happy
and certainly no offence taken.
in fact when I had the last def the dealer did 100 miles test driving in it and gave it a clean bill of health - I assumed it was simply the agricultural character of the defender as I'd been told by many - the dealer that bought it off me virtually phoned me before he'd got back to base that things weren't right??
Post #422622 11th May 2015 1:04pm
Caterham
So just been launched wobbling the wheel some more.
I'm not suggesting this is the cause as nothing is rotating but the clank clank sound is very much like the sound you get when rotating the prop back and forth check for play?
I've checked the panhard rod and it seems fine.
The seems to be coming from the axle / diff but it's difficult to say as I'm wobbling the wheel and not underneath listening?
Post #422743 11th May 2015 8:58pm
munch90
Get it put on ramp and checked , always easier with 2 people
Post #422746 11th May 2015 9:04pm
Caterham
Yes need to. I assume there shouldn't be any noise at all .... perhaps just a little creaking here and there?
Post #422748 11th May 2015 9:07pm
munch90
Make sure its on a 4 poster ramp , that way can be checked with everything in the running postion
two posters can hide things as the axles etc are hanging down
Post #422752 11th May 2015 9:15pm
