Home > Technical > 2 stroke oil
Page 5 of 10 <12345678910>
BigMike
Chers Bri Thumbs Up
Post #57593 7th Feb 2011 10:30pm
Lorryman100
Tim seymour wrote:
hi does anyone know about the pumas is south aust with no cat . because mine has a lead on the side of the gear box going no where and iam in tas cheers tim ps was looking at a decat pipe
Alive Tuning wrote:
LESVOSD110 wrote:
I have a plug with 3 wires next to the gearbox that is blanked with a plug.Is this the O2 wire?I cant find a sensor anywere near the the cat or pipe.Maybe they all do not have a O2 sensor fitted.
Puma engined defenders do not have an O2 sensor fitted, ever.
Alive Tuning wrote:
If there's no cat, you should hear a muted turbo whistle from the tailpipe at idle. Also the cat 'box' will sound hollow.
Post #57600 7th Feb 2011 11:28pm
Naks
pom wrote:
all this talk of bio does make me chuckle. IF its been made correctly then its loads better for the motor than dino diesel.
The bio-diesel tends to absorb more moisture, you end up with lots of water going through your filters and injectors. Never a good thing in the long run Wink --
Post #57622 8th Feb 2011 7:39am
spudfan
Ireland
http://www.uniteddiesel.co.uk/diesel-fuel-treatment.php
Check out the above link to Diesel Aid Fuel treatment. £50 treats 2,500 litres of diesel. When you read the proposed benefits of the product it lists the exact things that people are claiming from using 2 stroke. These include quieter running, increase in power,increases combustion so lowers exhaust gases and helps keep the fuel system lubricated.When reading it you could be reading the 2 stroke thread here!You can also buy a test kit to check that the fuel you are buying complies with theEN-590 diesel spec. Thought I would mention it as I found it interesting, just a different way of achieving the same goal.
They do not like EGR valves and say they should never have been fitted to cars. They recommend blanking them off-where possible. Sounds like one of us already! Does not seem keen on variable vane turbos either. 1982 88" 2.25 diesel
1992 110 200tdi csw -Zikali
2008 110 2.4 tdci csw-Zulu
2011 110 2.4 tdci csw-Masai
Post #57846 8th Feb 2011 10:21pm
BigMike
Not sure about this part
"Diesel Aid is advantages to Bio-diesel and heating oil’s as it will allow for better combustion and also help to dissipate any water within the fuel. Diesel Aid is also effective in home heating fuel and used in the same treatment ratio will save you money."
How?
Post #57849 8th Feb 2011 10:26pm
spudfan
Ireland
Not recommending it, just thought it might be of interest to read. If they are claiming those benefits are good for your engine then adding the 2 stroke which seems to do the same, must be good for your engine too. 1982 88" 2.25 diesel
Post #57851 8th Feb 2011 10:33pm
BigMike
Yeah I know spud. Jut wondering what he means by that and the science behind it (which isn't mentioned in the text)
Post #57948 9th Feb 2011 9:53am
bob neville
willy eckerslike wrote:
I'm using 200ml of diesel per tankful of two stroke, seemed to work the engine went really quiet.........really really quiet, in fact you can't tell it's running.
Rolling with laughter Rolling with laughter
Was it really only me that missed this ?
Bob
Post #58006 9th Feb 2011 12:57pm
spudfan
Ireland
Looks like we all missed it. A tank full of 2stroke would be expensive no matter how quiet it was. Laughing Hope we do not strt to anulise a te pists on hure as wi all mike mystukes. Whistle Looks like I will have to go back to getting the Mrs. to type mine for me. Just in case... 1982 88" 2.25 diesel
Post #58020 9th Feb 2011 1:31pm
bob neville
I think it was more of a very subtle and well executed joke than a mistake.
I will credit you with the former Willy even if it was not Thumbs Up
Bob
Post #58022 9th Feb 2011 2:01pm
mick
When I was in my boy racer era I used to put some Castrol R in the tank to get the rally car smell Embarassed
Post #58328 10th Feb 2011 6:12pm
bob neville
Used to use Castrol R in my Greeves scrambler - showing my age now Laughing
Bob
Post #58355 10th Feb 2011 8:14pm
ickle
As a note, I've been adding about 300ml to a tank for a couple of months now, its done about 50K and first MOT was today, smoke meter was 0.76, fast pass limit is 1.5, engine must be below 3 for a pass.
It failed btw, bloody foglight on the wrong side! (LHD import, I did the headlamps, added mph to the speedo etc but forgot to change the fog and reversing around) Embarassed
Post #58552 11th Feb 2011 9:34pm
Zinke
United Kingdom 2003 Defender 90 Td5 HT Epsom Green
I have just bought some FB 2-stroke oil from the motor factors at £3.25/litre in 1litre bottles which i didnt think was bad. In the past ive used Millers diesel additive which i bought for £10 and would give me ten 50 litre fills using the minimum recommended ratio working out at £1 per fill or a extra 2p/litre. Using 2-stroke at a 200:1 ratio and a 50 litre fill of diesel will work out at £0.8125 (just over 81p) per fill or 1.625p/litre so this also works out a little cheaper.
I was going to start recording my mpg to see if it changes much, but as i have been using Millers in my fuel before i didnt think it would be a fair comparison as im not going from no additives to using 2-stroke. I normally work out my mpg when i fill up though so will keep a eye out to see if there is any change in the trend.
Pete.
Post #58654 12th Feb 2011 4:37pm
pom
You've been on the umbongo juice mate. Oil cannot 'absorb' water its a chemical impossibility.
Pom
Post #58698 12th Feb 2011 6:59pm
