![]() | Home > Technical > 2 stroke oil |
landybehr Member Since: 17 Apr 2013 Location: -D- Posts: 173 ![]() |
Sorry if Iīve missed when/where itīs been answered.
What about 2SO and the DPF. I read contradictory things elsewhere. Some say that 2SO will add Sulphur-Ash which blocks the DPF. Others say that combustion is cleaner with 2SO so in the end the DPF benefits. The latter thesis seems to be based on "gut feeling" rather than measurements. And if Sulphur were not to be considered , I wouldnīt have to buy that 5W30-C1 oil for it. Anyone driving a post-ī12MY TD4 with 2SO and without DPF blocking (mileage?). |
keith Member Since: 15 Aug 2012 Location: Edinburgh Posts: 2237 ![]() ![]() |
Yep , 2.2 110 XS with 12000 miles . Making no differance to the DPF and had no smoke or soot or running problems . The DPF is doing its job and running a burn cycle at 880 degrees every 350 miles for me . Can I feel a differance with the 2SO ? Not really , except the cost at 350ml every tankfull . Unless its beneficial to the engine then i don't see it doing any other positive things , eg : fuel economy , emitions ,
Zinke Member Since: 27 Jan 2009 Location: Scunthorpe Posts: 670 ![]() ![]() ![]() |
Ive stopped using 2SO in my TD5 and now using the millers diesel max stuff. Its never ran so well!
rossy Member Since: 29 Nov 2010 Location: Co. Roscommon Posts: 1296 ![]() ![]() ![]() |
I think different additives suit different motors. I used that stuff religiously on my previous VW engined motor and I was still getting running issues eg frequent gunged up MAP sensor. Then 2SO cured everything miraculously. I regard 2 stroke now as a kind of automotive All-Bran - stops everything sticking to the sides
SteveT247 Member Since: 21 Feb 2011 Location: Central Posts: 491 ![]() ![]() ![]() |
Same here. I'm really impressed with the Millers stuff ![]() |
First90 Member Since: 20 Mar 2012 Location: Melbourne, Australia Posts: 22 ![]() ![]() |
Same thing, we were driving on the highway at 100kph and actually having a conversation (unfortunately for me!) when she said the sound proofing I installed was working really well. Only thing is that the sound proofing is still in the packet... 2 stroke doesn't do much for the whine of BFG KM2's though so the sound proofing will still go in. |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8222 ![]() ![]() ![]() |
So any more views to add with more time having past on the benefits or not of adding 2SO?
those that saw an initial change still using it? had any problems with it? Cheers James 110 2010 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
LR90XS2011 Member Since: 05 Apr 2011 Location: bickenhill Posts: 3664 ![]() ![]() ![]() |
I've used quality 2SO in my BM for 62k miles from new it has a DPF no ill effects so far in fact the at each MOT they cant even measure the emissions DEFENDER 90 TDCI XS,
everyone I got to try it are all reporting good things , and are all continuing to use it
never known any additive to have as good results as 2t |
just out of interest what oil do you use? |
cheers Guys, yes which 2SO are you using? Cheers
That was from a post nearly five years ago. I still use Millers to this day and it has become 'second nature' each fill up to shove some in the tank. I obviously must have rated it too but have been using it so long now I've forgotten why? ![]() Treat every day as if it is your last....one day you will be right!! |
cornish rattler Member Since: 31 Aug 2013 Location: Manchester Posts: 642 ![]() ![]() ![]() |
Please forgive me for being ignorant but i am not sure if i have an injector problem or not really heavy on juice 20 mpg ( 2.5 td 90 with defender 200tdi fitted ) so assuming i have would 2 stroke help solve this or am i better buying a new set of injectors and going from there
![]() 1988 Defender 90 county 200tdi ( Beast ) Paul Walker 1973-2013 ( I Almost Had You ) Last edited by cornish rattler on 29th Sep 2014 5:14pm. Edited 1 time in total |
Graham, I may be wrong but if it runs well with no undue noise or smoke personally I wouldn't worry. Most modern Defenders return on average (for those that drive 'normally') 24-27mpg. Taking the age and boots that you have fitted to your nice looking truck as stated don't worry too much.
Also if it ain't broke don't fix it. Perhaps a little Millers for a few tankfulls and then see how you fair at worst, or, just leave well alone. ![]() ![]() ![]() Treat every day as if it is your last....one day you will be right!! Last edited by K9F on 29th Sep 2014 5:08pm. Edited 1 time in total |
