Home > Technical > 2 stroke oil
Page 9 of 10 <12345678910>
munch90
I don't think it will solve a problem , its more to prevent problems (hopefully ! )
but cant see the harm in trying it
earlier defenders were bit more juicy , I know my 200tdi was , if you got no smoke , misfire , rough tick over then it maybe as it should be
Post #361007 29th Sep 2014 5:07pm
TDCi Guy
United Kingdom 1996 Defender 110 300 Tdi HCPU Auto Keswick Green
Try sticking an injector cleaner through it?
You can get the tips of your injectors changed/serviced at your local bosch place, new injectors are a lot of moolah!
Post #361009 29th Sep 2014 5:11pm
cornish rattler
United Kingdom 1988 Defender 90 200 Tdi CSW Bronze Green
Yeah it runs and sounds great but it has always had a slight uneven run on idle, last owner had speeded up the idle to prevent this but i found it was idling to fast and slowed it down and noticed it and just the other weekend as i was stood over the engine assisting son fit the clutch master cylinder i noticed no 4 injector was very rusty compaired to the other 3 hence why i think i have an injector problem Confused Graham
1988 Defender 90 county 200tdi ( Beast )
Paul Walker 1973-2013
( I Almost Had You )
Post #361011 29th Sep 2014 5:25pm
munch90
take them out and get them tested , doesn't cost that much
the non electronic injectors are a lot cheaper to recon or buy new
im not a great lover of recon injectors , if funds can do it try to find some new ones
9 out of 10 times its metal from the high pressure pump (just normal wear ) that's causes the problem with injectors and no additive will dissolve metal !
also might be worth checking pump timing , just because the cambelt timing is right it doesn't mean the pump timing is right
Post #361013 29th Sep 2014 5:35pm
Anderzander
I've poured in 300ml of two stroke tonight - see what happens Smile
Post #361016 29th Sep 2014 5:45pm
munch90
most seem to use 200ml for a 90 not sure on 110
be handy to hear your views on it
Post #361017 29th Sep 2014 5:47pm
Anderzander
Oops - I put 250 in, not sure why I said 300.
Mine is a 90 - I was calculating from the detailed quote at the start of the thread, which states 200:1 - 500ml to 1000 litres. I have 50 + litres in so I'm in line with it.
I'll report back. Thumbs Up
Post #361023 29th Sep 2014 6:29pm
MartinK
Just a though, does the 2SO mix ok when poured into the tank?
I usually put a glob in the tank at the petrol station before refueling in the belief that it helps it mix? In case the 2SO just sinks in the diesel and sits in the bottom of the tank? Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's)
Post #361062 29th Sep 2014 7:54pm
jst
100L = 0.5L Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #361064 29th Sep 2014 7:57pm
munch90
as you drive it will mix in
Post #361085 29th Sep 2014 8:40pm
pjw4233
United Kingdom 2011 Defender 90 Puma 2.4 HT Stornoway Grey
I have a 90, and I put 250ml of 2SO when the fuel light comes on and I fill up (about 50 liters) which works out at 200 to 1.
Post #361117 29th Sep 2014 9:46pm
Anderzander
jst wrote:
100L = 0.5L
Embarassed
Thanks - I'm having some sort of number crisis .... I meant 100 L
Post #361139 29th Sep 2014 10:21pm
dgardel
Italy
It will mix in few seconds, diesel is like a thinner for the oil Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #361177 30th Sep 2014 6:31am
Anderzander
Well ! Mine is substantially smoother and quieter.
It seems most noticeable at lower engine speeds - as in it rattles if In a bit firm of aggressive in the throttle, however tick over and on he gentle pick up the engine note is substantially different.
Only other point - I wasn't sure if pick up was a little slower ? That may be due to me still getting used to this engine though.
Post #361360 1st Oct 2014 7:28am
takoon
Norway
2 stroke or 4 stroke?- any significant difference other than the 4 stroke looks and feels more like chainsaw oil (thicker)?
I have used both but can`t notice any difference so far. Does anyone else has experience of the matter? -99 Td5 90 CSW
-09 Jaguar xk4,2 Portfolio
Post #361364 1st Oct 2014 8:15am
