Home > Technical > 2 stroke oil
Page 1 of 10 12345678910>
Trokkie
South Africa 2002 Defender 90 Td5 HT Epsom Green
2 stroke oil
Hi Guys,
I'm new to the forum. I've read on a diffirent forum(landyonline.co.za) about the benifits of adding 2 stroke oil to my diesel. Do anybody have a take on this?
Post #14486 21st Aug 2009 12:58pm
shorty
South Africa 2009 Defender 90 Puma 2.4 XS CSW Chawton White
Hi Trokkie, Ive also heard about this. Apparently it increases the cetane number in diesel & provides needed lubrication for low sulphur fuel. I would strongly recommend that you check your warranty will not be affected. Land Rover's don't leak oil, they simply mark their territory!
Post #14697 27th Aug 2009 9:06am
LESVOSD110
South Africa 2010 Defender 110 Puma 2.4 SW Fuji White
Hi.
I've seen chaps use it on older mechanical pump Diesel engines.The story was that it lubricated the pump but it added some smoke,however they did not use expensive smokeless oil.Rather look for Wynn's diesel treatment to use.
Cheers Puma 110 SW
90 V8 SOFT TOP
Post #14805 30th Aug 2009 3:04am
RED-DOT
I use a tin of "Forte" Diesel treatment in both my TD5 and Tdci twice a year and it has instant results in the engines power and noise, it really cleans the crud from the top end and injectors. My mate runs a small garage and every fuel filter change has 30% neat Forte added inside the filter....
http://cgi.ebay.co.uk/FORTE-ADVANCED-FORMU...286.c0.m14 2008 RS4 gone, 123d M Sport, and a Puma 90 XS..
Post #14806 30th Aug 2009 9:13am
landyman1
United Kingdom 2009 Defender 110 Puma 2.4 USW Stornoway Grey
Thumbs Up
I too used forte regularly.
Before current and soon to depart v8 110 I had a series 111 swb diesel. Made a moped seem fast but it was reliable & got it through mot every time by filling fuel filter with forte prior to drive to mot station---- and cleaned injectors for another year.
Landyman 1
Post #14807 30th Aug 2009 1:41pm
scatt
England 2008 Defender 110 Puma 2.4 DCPU Alpine White
has any one ran there tdci puma with 2 stroke in?? i want to try it, but thought i would ask if anyone has been brave enough to put some in ??? before i do Confused
Post #17322 27th Oct 2009 6:21pm
LR09WA
Australia 2009 Defender 110 Puma 2.4 SW Stornoway Grey
The guys on the freelander2 forum have been running there freelanders on two stroke and diesel with great results for quiet some time now, also know of a few people running there puma tdci on 300ml two stroke oil per tank with great results ,quiet idle, less knock on cold start, less chatter under load. heres the link. [url] http://www.freel2.com/forum/topic878.html?...stroke+oil
Post #17363 28th Oct 2009 12:45am
LR09WA
Post #17365 28th Oct 2009 4:07am
Trokkie
Hi Guys,
I've been adding 2stroke since I posted this a few months ago. I have to say that my Td5 is quieter and alot smoother. I have not had any issues and will keep on adding. Just some stats - i dive between 1000km -1200km per week on all sort of surfaces and my Trokkie is running like charm Razz .
Post #17384 28th Oct 2009 9:52am
Tim seymour
Australia
hi yes i tried the 2 stroke 300 mm in a tank seems quiter and a bit more power. iwont do it all the time but if some one out there is i would like to know the results cheers tim Smile Cess the Taswegian
Post #52504 12th Jan 2011 2:57am
Lorryman100
I have, got the landy new 1/9/09 and has had 2 stroke through it since, also gets forte treatment twice a year Thumbs Up
Do a search on here as 2 stroke use has been covered in numerous threads Thumbs Up
Post #52525 12th Jan 2011 10:52am
BigMike
I'm trying this. Engine is definitely quieter, also smoother power delivery at lower revs. Going to keep on with it for the time being.
Post #52786 13th Jan 2011 3:38pm
LESVOSD110
18000KM on mine now using TCW-3 marine two stroke and all is fine.200ml per fill-up and I feel protected.On another note,my local Ford dealer advised me to use there 5W-40 diesel oil as a better alternative to 5w-30 low SAPS.I was using 5w-50 in summer anyway. Whistle Puma 110 SW
90 V8 SOFT TOP
Post #52798 13th Jan 2011 5:02pm
totoD110
tried this and definitely smoother and quiter... Thumbs Up Thumbs Up i will use it always... thanks for the tip guys! Bow down
Post #56154 2nd Feb 2011 4:48am
mrdk1970
Cyprus 2008 Defender 110 Puma 2.4 XS DCPU Stornoway Grey
I have learned this method of "lubricating" diesel engines when I was in the army in the late 80s!
We used it in old diesel trucks and land rovers, since then I have always used 2 stroke oil in all my land rovers (200tdi, td5 and now my tdci) and never had a problem.javascript:emoticon('Thumbs Up')
An old mechanic told me that it also washes the moisture out of the engine, I don't know if this is true.
Post #56156 2nd Feb 2011 6:57am
