![]() | Home > Technical > Oil advice and recommendations here! |
Caterham Member Since: 06 Nov 2008 Location: Birmingham Posts: 6318 ![]() ![]() ![]() |
thanks Tim.
oilman Site Supporter Member Since: 19 Mar 2009 Location: Cornwall Posts: 511 ![]() |
Hi
I don't deal with Havoline, so can't really comment on them. http://www.opieoils.co.uk/c-653-5w-30.aspx Fuchs Pro S, Motul 300V and Red Line are the best options, followed by the Castrol Edge, Mobil ESP, Millers EE and XF, Fuchs GT1 and Shell Helix Ultra ECT. The others are fine as cheaper alternatives. Cheers Tim Use the code DEF2 and get 10% Club Discount View Opie Oils Current Offers Here > > oilman's website: http://www.opieoils.co.uk/ - register for news and offers email: sales@opieoils.co.uk phone: 01209 202944 |
adseybear Member Since: 08 Oct 2009 Location: Vancouver, Canada Posts: 262 ![]() ![]() |
Thanks Tim,
I'm always a bit puzzled by the ACEA specs. The Manual Calls for an A1 spec all, some of those don't meet that, but my reading would appear to indicate that actualy an A3/B3 oil would provide better protection? I'm not fussed about the fuel economy claims! 2003 Defender 90 Td5 CSW Belize Green - "Betty" 1958 Series IIA 109 Station Wagon - "Randolph" - Awaiting Restoration 2019 Jeep Wrangler JL Rubicon - SOLD 2006 Volvo V70 D5 - Ocean Race Edition, SOLD 2003 VW Passat Estate 1.9TDI - SOLD 2008 BMW 320D M Sport Estate - SOLD 2001 Defender 90 Td5 Hard Top - SOLD |
Hi
Yes, those oils are all more up to date than A1, so will be fine. A1 is a pretty basic spec and pretty much anything will meet/exceed that spec now. The fuel economy side of it is pretty minute, I really don't think anyone has noticed a difference between an A1 and A3 5w-30 oil. Cheers Tim Use the code DEF2 and get 10% Club Discount View Opie Oils Current Offers Here > > oilman's website: http://www.opieoils.co.uk/ - register for news and offers email: sales@opieoils.co.uk phone: 01209 202944 |
Cheers Tim.
Another question! I notice you've started selling the Fuchs commercial oils. How would something like the 5w30 commercial oil stack up against the usual car engine oils? I only ask because in SA and Australia where arguably they have more demanding conditions, I've noticed alot of the owners there using the Mobil 1 Delvac oil, which is the commercial diesel oil and supposed to be able to handle difficult working conditions better. 2003 Defender 90 Td5 CSW Belize Green - "Betty" 1958 Series IIA 109 Station Wagon - "Randolph" - Awaiting Restoration 2019 Jeep Wrangler JL Rubicon - SOLD 2006 Volvo V70 D5 - Ocean Race Edition, SOLD 2003 VW Passat Estate 1.9TDI - SOLD 2008 BMW 320D M Sport Estate - SOLD 2001 Defender 90 Td5 Hard Top - SOLD |
Hi
Commercial oils are usually pretty basic compared to normal car oils. A lot of commercial oils are mineral or semi-synthetic, but most modern car engines require synthetics. Commercial oils are designed for large capacity, low-revving engines, with very long change intervals, which is not the same as a car engine. A lot of people consider the best option to be the cheapest one and that is usually not the case. As long as the commercial oil meets the correct specs, then it can be used in a car. I've had a quick look at the Mobil Delvac 5w-30s and they do not mention the Ford 913 or 934 specs, so don't cover what the modern Defenders require. That means that they wouldn't be suitable for warranty use. If it has a DPF, using a non-934B spec oil could lead to a blocked DPF. I don't know if the Au and SA models have DPFs, but I think DPFs are far more common in Europe than elsewhere. Because of that, a Delvac oil could be okay for it. Cheers Tim Use the code DEF2 and get 10% Club Discount View Opie Oils Current Offers Here > > oilman's website: http://www.opieoils.co.uk/ - register for news and offers email: sales@opieoils.co.uk phone: 01209 202944 |
HardCharger Member Since: 03 Mar 2013 Location: Manila Posts: 748 ![]() ![]() ![]() |
Hi All!
Quick question, a friend of mine who is wise in the ways of the Rover, says that for the gearboxes (transmission, t-case, differentials) it's OK to use regular Shell Spiral oils. Is this true? My change interval for the gearboxes is almost around and was about to buy some other branded gear oils (Motul, LiquiMoly, et al.) as per the cheat sheets and specs but of course, they'll cost more. Of course engine oils are a different story and I use LiquiMoly Special Tec F for that. So what do all y'all think? |
Hi
Some Shell Spirax products are good synthetics, some are fairly basic mineral oils, so it depends which ones you use. Cheers Tim Use the code DEF2 and get 10% Club Discount View Opie Oils Current Offers Here > > oilman's website: http://www.opieoils.co.uk/ - register for news and offers email: sales@opieoils.co.uk phone: 01209 202944 |
Thanks for the reply, Tim!
I'll what's locally available and revert back to you. We don't usually have a nice selection in this neck of the woods. |
excossack Member Since: 22 Feb 2012 Location: North West Posts: 5884 ![]() ![]() ![]() |
What oil suggestions do you have for Defender;
Front and rear diffs. Transfer case Gearbox - R380 1999 Defender TD5 110 Regards John M0VAZ Econet Station 48 no clock |
Assuming yours is the 1999 td5 in your sig? You will need an SAE 90 GL5 for the transfer case, something like this http://www.opieoils.co.uk/p-68903-fuchs-ti...f-oil.aspx
Originally the gearbox took something called MTF 94, this is essentially a modified engine oil. You can still use this or you can upgrade to a modern 75w-80 GL4 such as these here http://www.opieoils.co.uk/c-670-75w-80-75w...fluid.aspx To make things easy you can use the same GL5 SAE90 used for the transfer case for the front and rear diff. Cheers Guy Use the code DEF2 and get 10% Club Discount View Opie Oils Current Offers Here > > oilman's website: http://www.opieoils.co.uk/ - register for news and offers email: sales@opieoils.co.uk phone: 01209 202944 |
Tim,
I always used the Mobil 1™ Peak Life 5W-50 What do you think? High HTHS (maximum resistance of the oil film, wide Temp window,...) Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition ![]() IID Pro MV License |
The Mobil is good stuff, you will have no problems with it
![]() Cheers Guy Use the code DEF2 and get 10% Club Discount View Opie Oils Current Offers Here > > oilman's website: http://www.opieoils.co.uk/ - register for news and offers email: sales@opieoils.co.uk phone: 01209 202944 |
![]() ![]() ![]() but, the best is? Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition ![]() IID Pro MV License |
