Home > Technical > Oil advice and recommendations here!
Page 1 of 10 12345678910>
oilman
Hi all,
We have been invited by the club to offer any help and advise we can on oil etc.
If you have any questions on the oily stuff please post them here and we will do our best to help.
If you would like a recommendation for your vehicle please add the following info.
Make -
Model -
Year -
Mods -
Use (road/track etc) -
Hope fully we can be of some service here
Guy
http://www.opieoils.co.uk Use the code DEF2 and get 10% Club Discount
View Opie Oils Current Offers Here > >
oilman's website: http://www.opieoils.co.uk/ - register for news and offers
email: sales@opieoils.co.uk
phone: 01209 202944
Post #8597 19th Mar 2009 12:05pm
fekete
Hi oilman and welcome
in the puma thay recommend 5W-30 Castrol
my question is will 0W-30 Castrol EDGE do the same job
the reason im asking is beause i can get it Free
regards
Karl NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY
Post #8600 19th Mar 2009 1:55pm
oilman
Yep, it will be fine. The only thing is it may use a bit more.
Guy Use the code DEF2 and get 10% Club Discount
phone: 01209 202944
Post #8608 19th Mar 2009 4:03pm
fekete
Thanks for the quick reply
Sorry should of asked before is the turbo deisel oil the same as the petrol oil or little difference
Post #8610 19th Mar 2009 4:54pm
oilman
Do you mean between the Edge 0w-30 and the Edge TD 0w-30?
phone: 01209 202944
Post #8613 19th Mar 2009 5:33pm
fekete
Sorry guy
yess between the Edge 0w-30 and the Edge td 0w-30
as its the Edge 0w-30 i can get my hands on
thanks
Post #8614 19th Mar 2009 5:37pm
MK
Sorry to jump in, but the manual states you can only use 5w/30 meeting the Ford WSS-M2C913-B
spec. It is an oil with low high-temp-high-shear viscosity. Puma 110" SW
Post #8660 20th Mar 2009 5:49pm
fekete
Hi MK,
EDGE is of the same Formulation, and probably a better oil NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY
Post #8668 20th Mar 2009 7:25pm
MK
fekete wrote:
Hi MK,
Don´t know, but does it meet such Ford spec? Puma 110" SW
Post #8672 20th Mar 2009 7:58pm
Tim in Scotland
Make - Land Rover
Model - Defender Tdi300
Year - 1996
Mods - EGR removed and blanked off and Cat removed
Use (road/track etc) - 20% on road 80% offroad - it only does about 3000miles a year Pangea Green D250 90 HSE with Air Suspension, Off-road Pack, Towing Pack, Black Contrast roof , rear recovery eyes, Front bash plate, Classic flaps all round, extended wheel arch kit and a few bits from PowerfulUK Expel Clear Gloss PPF to come
2020 D240 1st Edition in Pangea Green with Acorn interior. Now gone - old faithful, no mechanical issues whatsoever ever but the leaks and rattles all over the place won’t be missed!
Post #8865 23rd Mar 2009 12:21pm
dgardel
Italy
Defender 90 SW MY08
2.4 PUMA Engine
Chipped (+/- 160 HP)
13000 km on the clock
Mobil1 5w/30 with WSS-M2C913-B compliance (one of the best oil on the market)
I changed ALL OILS at 8000km!!!!
Post #8872 23rd Mar 2009 1:17pm
Martin
Site Admin
Hi Guy,
Can you please specify oils/fluids for the following:
Defender with Td5 Engine (2.5 5 cylinder 1998-2007)
Defender with Puma Engine (2.4 2007-)
R380 Manual Gearbox (factory recommended oil is Texaco "MTF94") (1998-2007)
LT230 Transfer Gearbox and Axles (factory recommended is 75W-90 GL5) (1998-?)
Can someone fill in the gap for the Puma 6-speed gearbox, and is the LT230 transfer still used on the Pumas?
Post #8958 24th Mar 2009 3:53pm
MK
dgardel wrote:
Defender 90 SW MY08
2.4 TDCi Engine
Does such oil really exists? Puma 110" SW
Post #8959 24th Mar 2009 4:25pm
MK
gearbox uses Castrol BOT 130 (fully synth GL-4), it is 75W/90. Do not use GL-5!. Yes, the LT230Q it`s still used. Puma 110" SW
Post #8960 24th Mar 2009 4:35pm
Tony_Hillerby
Scotland 2016 Defender 90 Puma 2.2 Landmark LE Santorini Black
Had a look on the Castrol website and put the registration in to find the corect oils for the 110. The manual gearbox says SMX -S which is a synthetic 75W-85 gear oil.
I cannot find any trace on the castrol site of BOT130 as stated.
Is this SMX oil the same with a differant name.
Tony
Post #8989 24th Mar 2009 9:33pm
