Home > Technical > Oil advice and recommendations here!
Page 10 of 10 <12345678910
RichLech
United Kingdom 2012 Defender 90 Puma 2.2 HT Keswick Green
I'm using the Castrol Syntrans Multivehicle 75W-90 GL-4 synthetic in the gearbox but for transfer box & diffs, which can take GL-5, I am using Castrol Syntrax Universal Plus 75W-90 GL-5 synthetic.
Not sure what the difference is between GL-4 and GL-5. I'm just following advice found in the forum and from Opie Oils.
Opie Oils have several engine oils to the Ford M2C934-B (low SAPS) specification. I am using Millers XF Longlife C1 5W-30 Synthetic.
I bought it all from Opie Oils,
Post #521045 5th Apr 2016 8:34am
discomog
My understanding of the difference between GL4 and GL5 transmission oils is the amount of protection it provides to the yellow metal content of the transmission, ie synchromesh hubs etc. GL4 is a low detergent oil and therefore gives better yellow metal and phosphorous element protection than GL5.
Best to stick to the exact oil spec given by the motor manufacturer particularly if your vehicle is still under warranty. Defender 90XS SW
Mini Countryman Cooper S
Morgan Plus 8
Post #521064 5th Apr 2016 10:02am
muddybaldboy
Wales 1999 Defender 110 Td5 HT Chawton White
After upgrading my TD5 oils at your recommendation, I'm looking for possible (if any advantage) alternatives for Old's Cool, my early 90.
Land Rover 90
1984 68000 miles from new
2.25 petrol
Light use, sub 2k miles per year, usually dry stored over winter.
Suggestions? He who dies with the most toys...wins!
Post #533583 21st May 2016 11:27pm
boxoftricks
United Kingdom 2011 Defender 110 Puma 2.4 USW Zermatt Silver
Defender 110
TDCI 2.4 2010
No modifications
100,000 miles
Australian import
Been serviced (apparently) ever 6000k
Please advise on all oil you recommend as I’d like to change everything.
Thanks
Post #762755 10th Mar 2019 10:26am
