![]() | Home > Technical > 2 stroke oil |
shorty Member Since: 31 Oct 2008 Location: Hillcrest, Kwa Zulu Natal Posts: 160 ![]() ![]() ![]() |
Hi Trokkie, Ive also heard about this. Apparently it increases the cetane number in diesel & provides needed lubrication for low sulphur fuel. I would strongly recommend that you check your warranty will not be affected. Land Rover's don't leak oil, they simply mark their territory!
LESVOSD110 Member Since: 19 Aug 2009 Location: South Africa Posts: 241 ![]() ![]() ![]() |
Hi.
I've seen chaps use it on older mechanical pump Diesel engines.The story was that it lubricated the pump but it added some smoke,however they did not use expensive smokeless oil.Rather look for Wynn's diesel treatment to use. Cheers Puma 110 SW 90 V8 SOFT TOP |
RED-DOT Member Since: 29 Jun 2009 Location: stirling Posts: 2363 ![]() ![]() |
I use a tin of "Forte" Diesel treatment in both my TD5 and Tdci twice a year and it has instant results in the engines power and noise, it really cleans the crud from the top end and injectors. My mate runs a small garage and every fuel filter change has 30% neat Forte added inside the filter....
http://cgi.ebay.co.uk/FORTE-ADVANCED-FORMU...286.c0.m14 2008 RS4 gone, 123d M Sport, and a Puma 90 XS.. |
landyman1 Member Since: 11 Jul 2009 Location: Pembrokeshire,South Wales Posts: 57 ![]() ![]() ![]() |
![]() I too used forte regularly. Before current and soon to depart v8 110 I had a series 111 swb diesel. Made a moped seem fast but it was reliable & got it through mot every time by filling fuel filter with forte prior to drive to mot station---- and cleaned injectors for another year. Landyman 1 |
scatt Member Since: 24 Aug 2009 Location: nottingham Posts: 103 ![]() ![]() ![]() |
has any one ran there tdci puma with 2 stroke in?? i want to try it, but thought i would ask if anyone has been brave enough to put some in ??? before i do
LR09WA Member Since: 30 Apr 2009 Location: Perth Posts: 88 ![]() ![]() ![]() |
The guys on the freelander2 forum have been running there freelanders on two stroke and diesel with great results for quiet some time now, also know of a few people running there puma tdci on 300ml two stroke oil per tank with great results ,quiet idle, less knock on cold start, less chatter under load. heres the link. [url] http://www.freel2.com/forum/topic878.html?...stroke+oil
and a another link
http://www.patrol4x4.com/forum/showthread....ght=stroke |
Trokkie Member Since: 21 Aug 2009 Location: Centurion Posts: 2 ![]() ![]() ![]() |
Hi Guys,
I've been adding 2stroke since I posted this a few months ago. I have to say that my Td5 is quieter and alot smoother. I have not had any issues and will keep on adding. Just some stats - i dive between 1000km -1200km per week on all sort of surfaces and my Trokkie is running like charm ![]() |
Tim seymour Member Since: 17 Jan 2010 Location: Devonport TAS Posts: 92 ![]() ![]() |
hi yes i tried the 2 stroke 300 mm in a tank seems quiter and a bit more power. iwont do it all the time but if some one out there is i would like to know the results cheers tim
Lorryman100 Member Since: 01 Oct 2010 Location: Here Posts: 2686 ![]() |
I have, got the landy new 1/9/09 and has had 2 stroke through it since, also gets forte treatment twice a year ![]() Do a search on here as 2 stroke use has been covered in numerous threads ![]() |
I'm trying this. Engine is definitely quieter, also smoother power delivery at lower revs. Going to keep on with it for the time being.
18000KM on mine now using TCW-3 marine two stroke and all is fine.200ml per fill-up and I feel protected.On another note,my local Ford dealer advised me to use there 5W-40 diesel oil as a better alternative to 5w-30 low SAPS.I was using 5w-50 in summer anyway.
![]() 90 V8 SOFT TOP |
totoD110 Member Since: 26 Nov 2008 Location: Manila, Philippines Posts: 86 ![]() |
tried this and definitely smoother and quiter...
mrdk1970 Member Since: 30 Mar 2010 Location: Nicosia Posts: 15 ![]() ![]() ![]() |
I have learned this method of "lubricating" diesel engines when I was in the army in the late 80s!
We used it in old diesel trucks and land rovers, since then I have always used 2 stroke oil in all my land rovers (200tdi, td5 and now my tdci) and never had a problem.javascript:emoticon(' ![]() An old mechanic told me that it also washes the moisture out of the engine, I don't know if this is true. |
