Home > Technical > 2 stroke oil
Page 6 of 10 <12345678910>
party monkey
England 2005 Defender 110 Td5 XS CSW Cairns Blue
Just posting this from wikipedia in regard to bio-diesel and water etc.
Apols for taking this further off original topic ....
Quote
Contamination by water
Biodiesel may contain small but problematic quantities of water. Although it is not miscible with water, it is, like ethanol, hygroscopic (absorbs water from atmospheric moisture).[32] One of the reasons biodiesel can absorb water is the persistence of mono and diglycerides left over from an incomplete reaction. These molecules can act as an emulsifier, allowing water to mix with the biodiesel.[citation needed] In addition, there may be water that is residual to processing or resulting from storage tank condensation. The presence of water is a problem because:
Water reduces the heat of combustion of the bulk fuel. This means more smoke, harder starting, less power.
Water causes corrosion of vital fuel system components: fuel pumps, injector pumps, fuel lines, etc.
Water & microbes cause the paper element filters in the system to fail (rot), which in turn results in premature failure of the fuel pump due to ingestion of large particles.
Water freezes to form ice crystals near 0 °C (32 °F). These crystals provide sites for nucleation and accelerate the gelling of the residual fuel.
Water accelerates the growth of microbe colonies, which can plug up a fuel system. Biodiesel users who have heated fuel tanks therefore face a year-round microbe problem.
Additionally, water can cause pitting in the pistons on a diesel engine.
Previously, the amount of water contaminating biodiesel has been difficult to measure by taking samples, since water and oil separate. However, it is now possible to measure the water content using water-in-oil sensors.[citation needed]
Water contamination is also a potential problem when using certain chemical catalysts involved in the production process, substantially reducing catalytic efficiency of base (high pH) catalysts such as potassium hydroxide. However, the super-critical methanol production methodology, whereby the transesterification process of oil feedstock and methanol is effectuated under high temperature and pressure, has been shown to be largely unaffected by the presence of water contamination during the production phase.
Unquote.
To be clear, this post is in relation to pure bio-fuel (b100), not the up to 7% blends that we all use when we fill up at the forecourts, although, I assume that the water related issues relating to B100 could still be pertintent to a much smaller level in b7.
No coming from a position of knowledge here, just posting what I've found elsewhere on t'internet. Jon - 110 td5 [sold]. Currently Defenderless.
Post #58744 12th Feb 2011 11:30pm
Zinke
United Kingdom 2003 Defender 90 Td5 HT Epsom Green
Also brake fluid is a oil but is also hygroscopic.
Pete.
Post #58749 13th Feb 2011 2:15am
spudfan
Ireland
Been using 2 stroke in the Puma 110 for a while. The warning light binged on today at 563 kms-that is about 350 miles. Do not know what the mpg comes out as, as I fill her up at home. This fill up I did not use 2 stroke but put some Millers in the tank. Did not know whether to mix the Millers with the 2 stroke or not. Next fill up I will revert to the 2 stroke. Don't think that the 2 stroke does much to increase mpg but it makes the engine sound so smooth.That Millers sure does smell-I can still smell off my clothes!! 1982 88" 2.25 diesel
1992 110 200tdi csw -Zikali
2008 110 2.4 tdci csw-Zulu
2011 110 2.4 tdci csw-Masai
Post #60221 20th Feb 2011 5:55pm
Zinke
Well i have ran a few tanks through my TD5 now and today was MOT time. The emissions test was 0.13 which is the lowest ive ever had so looks like it is cleaning up the engine. It does sound smoother and pull better too i think but havent done enough mileage to record any accurate change in fuel consumption but looking at how many miles im getting to a tank it does look favourable.
Pete.
Post #60887 24th Feb 2011 10:28am
willy eckerslike
United Kingdom 2007 Defender 110 Puma 2.4 HCPU Keswick Green
bob neville wrote:
I think it was more of a very subtle and well executed joke than a mistake.
I will credit you with the former Willy even if it was not Thumbs Up
Bob
Cheers Bob I knew someone would get there eventually Thumbs Up Original Member Pie n Pea Club.
110 HCPU Tipper
Post #60891 24th Feb 2011 11:01am
Filled my DC up on Saturday evening and for the first time added two stroke, JASO FC. I was going to put in 200ml but due to the forecourt being dark and the bottle being black, I ended up adding around 350ml!
Did 250 miles during the course of Sunday and I have to admit that I was very pleasently surprised - the engine seems quieter, smoother and more responsive! Despite all that has been written, I still find it hard to believe quite how much differernce it has made.
I will try the same in the TD5 Disco when I next fill that up.
Post #61424 28th Feb 2011 1:51pm
party monkey
First crack at doping with 2 stroke today.
Using JASO FB Mineral by Motul (thanks Opie)
Mix ratio of 1:200'ish but erring on side of caution to weaker rather than stronger
I'm still amazed by the recent improvement that the shot of Forte made, so can't say I've noticed any further improvement in the uptake of the engine so far, but it is certainly considerably quieter. So much so my daughter even noticed the turbo whistle. Jon - 110 td5 [sold]. Currently Defenderless.
Post #62175 3rd Mar 2011 11:23pm
bm52
United Kingdom 2014 Defender 110 Puma 2.2 XS CSW Havana
been reading all the posts and thought i would give it a try as well especially after Tim's comments.
just filled my 1st tank. the test has started. BM52
Post #62395 5th Mar 2011 5:11pm
ralton
South Africa 2007 Defender 90 Puma 2.4 SW Zermatt Silver
ralton wrote:
You guys are crazy. I wouldn't add 2-stroke oil to my Puma if you paid me to.
Whistle
Well, after my above comment and a bit more investigating, i have now run 3 tanks with 1:200 "FB" oil and there is definitely an improvement in performance, economy and engine noise.
Smile www.ralton.co.za
Post #62512 6th Mar 2011 5:34pm
LESVOSD110
South Africa 2010 Defender 110 Puma 2.4 SW Fuji White
ralton wrote:
Whistle
Smile
Now you can pay us. :lol:20000km's on mine and going strong,using tcw-3. How's Durbs these days? Puma 110 SW
90 V8 SOFT TOP
Post #62518 6th Mar 2011 6:16pm
bm52
after about 50 miles i am starting to 'hear' the difference in both cold start and acceleration under load. i'm going to wait until after the 1st couple of tanks before i make a judgement. so far so good. BM52
Post #62519 6th Mar 2011 6:19pm
Naks
Hehe, we knew you'd come around eventually!
Don't forget to also use diesel injector cleaner every 2000km or so Thumbs Up --
Post #62525 6th Mar 2011 6:52pm
ickle wrote:
As a note, I've been adding about 300ml to a tank for a couple of months now, its done about 50K and first MOT was today, smoke meter was 0.76, fast pass limit is 1.5, engine must be below 3 for a pass.
It failed btw, bloody foglight on the wrong side! (LHD import, I did the headlamps, added mph to the speedo etc but forgot to change the fog and reversing around) Embarassed
i've just changed my fog and reversing light around by swapping pins 7 & 8 on the loom connector, saves rewiring and messing about ..
Post #62867 8th Mar 2011 10:18pm
MacDefender
Brazil 2007 Defender 110 Puma 2.4 CSW Zermatt Silver
Two stroke oil ? Defently YES.
I must agree with you guys in favor of adding 1:200 ration of two stroke oil in diesel tanks.
Defently the engine turns quiter, smoother and maybe more powerfull..
I had to change all four diesel injectors of my 2007 Tdci Defender recently, and I am very concerned about the health of the fuel injection system from now on.
I strongly recomend the use of TS oil even in tuned engines like mine.
Thumbs Up Mauro Chies
Rio Grande do Sul - Brazil
nihil sub sole novum. dum potes vive.
Post #232848 5th May 2013 1:55pm
bm52
wow 2 yrs 2 months since this tread waslast used........ BM52
Post #232904 5th May 2013 4:51pm
