Home > Technical > 2 stroke oil |
Zinke Member Since: 27 Jan 2009 Location: Scunthorpe Posts: 670 |
Also brake fluid is a oil but is also hygroscopic.
Pete. |
13th Feb 2011 2:15am |
spudfan Member Since: 10 Sep 2007 Location: Co Donegal Posts: 4717 |
Been using 2 stroke in the Puma 110 for a while. The warning light binged on today at 563 kms-that is about 350 miles. Do not know what the mpg comes out as, as I fill her up at home. This fill up I did not use 2 stroke but put some Millers in the tank. Did not know whether to mix the Millers with the 2 stroke or not. Next fill up I will revert to the 2 stroke. Don't think that the 2 stroke does much to increase mpg but it makes the engine sound so smooth.That Millers sure does smell-I can still smell off my clothes!! 1982 88" 2.25 diesel
20th Feb 2011 5:55pm |
Well i have ran a few tanks through my TD5 now and today was MOT time. The emissions test was 0.13 which is the lowest ive ever had so looks like it is cleaning up the engine. It does sound smoother and pull better too i think but havent done enough mileage to record any accurate change in fuel consumption but looking at how many miles im getting to a tank it does look favourable.
Pete. |
24th Feb 2011 10:28am |
willy eckerslike Member Since: 15 Jun 2009 Location: North yorks Posts: 1789 |
Cheers Bob I knew someone would get there eventually Original Member Pie n Pea Club. 110 HCPU Tipper |
24th Feb 2011 11:01am |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17457 |
Filled my DC up on Saturday evening and for the first time added two stroke, JASO FC. I was going to put in 200ml but due to the forecourt being dark and the bottle being black, I ended up adding around 350ml!
Did 250 miles during the course of Sunday and I have to admit that I was very pleasently surprised - the engine seems quieter, smoother and more responsive! Despite all that has been written, I still find it hard to believe quite how much differernce it has made. I will try the same in the TD5 Disco when I next fill that up. |
28th Feb 2011 1:51pm |
party monkey Member Since: 31 Dec 2010 Location: Oxon. Posts: 1311 |
First crack at doping with 2 stroke today.
Using JASO FB Mineral by Motul (thanks Opie) Mix ratio of 1:200'ish but erring on side of caution to weaker rather than stronger I'm still amazed by the recent improvement that the shot of Forte made, so can't say I've noticed any further improvement in the uptake of the engine so far, but it is certainly considerably quieter. So much so my daughter even noticed the turbo whistle. Jon - 110 td5 [sold]. Currently Defenderless. |
3rd Mar 2011 11:23pm |
bm52 Member Since: 04 Apr 2010 Location: Kent Posts: 2189 |
been reading all the posts and thought i would give it a try as well especially after Tim's comments.
just filled my 1st tank. the test has started. BM52 |
5th Mar 2011 5:11pm |
ralton Member Since: 04 Feb 2010 Location: Durban Posts: 153 |
Well, after my above comment and a bit more investigating, i have now run 3 tanks with 1:200 "FB" oil and there is definitely an improvement in performance, economy and engine noise. www.ralton.co.za |
6th Mar 2011 5:34pm |
LESVOSD110 Member Since: 19 Aug 2009 Location: South Africa Posts: 241 |
Now you can pay us. :lol:20000km's on mine and going strong,using tcw-3. How's Durbs these days? Puma 110 SW 90 V8 SOFT TOP |
6th Mar 2011 6:16pm |
after about 50 miles i am starting to 'hear' the difference in both cold start and acceleration under load. i'm going to wait until after the 1st couple of tanks before i make a judgement. so far so good. BM52
6th Mar 2011 6:19pm |
Naks Member Since: 27 Jan 2009 Location: Stellenbosch, ZA Posts: 2645 |
Hehe, we knew you'd come around eventually! Don't forget to also use diesel injector cleaner every 2000km or so -- 2010 Defender Puma 90 + BAS remap + Alive IC + Slickshift + Ashcroft ATB rear 2015 Range Rover Sport V8 Supercharged Defender Puma Workshop Manual: https://bit.ly/2zZ1en9 Discovery 4 Workshop Manual: https://bit.ly/2zXrtKO Range Rover/Sport L320/L322/L494 Workshop Manual: https://bit.ly/2zc58JQ |
6th Mar 2011 6:52pm |
i've just changed my fog and reversing light around by swapping pins 7 & 8 on the loom connector, saves rewiring and messing about .. |
8th Mar 2011 10:18pm |
MacDefender Member Since: 17 Aug 2011 Location: Caxias do Sul Posts: 16 |
I must agree with you guys in favor of adding 1:200 ration of two stroke oil in diesel tanks.
Defently the engine turns quiter, smoother and maybe more powerfull.. I had to change all four diesel injectors of my 2007 Tdci Defender recently, and I am very concerned about the health of the fuel injection system from now on. I strongly recomend the use of TS oil even in tuned engines like mine. Mauro Chies Rio Grande do Sul - Brazil nihil sub sole novum. dum potes vive. |
5th May 2013 1:55pm |
wow 2 yrs 2 months since this tread waslast used........ BM52
5th May 2013 4:51pm |
