Home > Technical > 2 stroke oil
Page 3 of 10 <12345678910>
pom
So whats the deal then, mineral or syth ?
How much oil per litre of diesel ?
Pom
Post #56817 4th Feb 2011 10:45pm
szracer
England 2010 Defender 110 Puma 2.4 USW Stornoway Grey
Mineral or semi-synth.
5ml of 2 stroke per litre.
Pom
2010 110 XS USW (the slow one)
1960 Alfa Romeo Giulietta SZ (the fast one)
2005 Ducati ST3
1954 Sunbeam S8
Post #56821 4th Feb 2011 11:16pm
pom
Thanks I need to fill up before laning on Sunday, will give it a bash Thumbs Up
Pom
Post #56822 4th Feb 2011 11:20pm
party monkey
England 2005 Defender 110 Td5 XS CSW Cairns Blue
This sounds like a plan..... Just waiting for my Ebay seller to deliver the Forte and then I think a dose of every other fill (good shout SZRacer) is in order. If nothing else, for a couple of months to trial it.
I'm still not 100% sure if it should be mineral or semi synth, FB or FC or in fact it doesn't matter. The only concensus I can see is deffo NOT fully synthetic. Assume no real difference for a Td5 against a PUMA. Perhaps logically it makes sense to only mix a mineral 2 stroke in with 'mineral' diesel
Too late and too windy to go rumaging in the barn to see whether my Stihl 2 stroke is the right spec.... One for the morning and then off to Turneys methinks.
Out of interest - has anyone noticed any significant change in mpg either way as a consequence ? Jon - 110 td5 [sold]. Currently Defenderless.
Post #56824 4th Feb 2011 11:38pm
spudfan
Ireland
Lorryman100 wrote:
You should only use mineral oil, as semi and synthetic don't burn up completely leaving ash deposits in the cat. I use Motul 100 MOTO MIX 2T Lubricant for 2 Stroke engines from site sponsor Opie oils. It is a mineral oil with rating JASO FB. JASO FC is a low ash oil which I have in the garage for my 2 stroke outboard engines, but wont risk using it in my landy as it is semi-synthetic. Basically any mineral 2 stroke oil with JASCO FB rating will do. Thumbs Up
Glad to hear that the mineral JASO FB SPEC is O.K. for the Puma. Very Happy 1982 88" 2.25 diesel
1992 110 200tdi csw -Zikali
2008 110 2.4 tdci csw-Zulu
2011 110 2.4 tdci csw-Masai
Post #56827 4th Feb 2011 11:49pm
pom
These guys say to use 0.2ml per litre?
Pom
Post #56830 5th Feb 2011 12:00am
pom
According to the Aussie thread should only use FC rated if you have a cat.
Pom
Post #56831 5th Feb 2011 12:02am
spudfan
Ireland
Pom
Cheers for that. I am correct in assuming that the Puma has a cat? 1982 88" 2.25 diesel
Post #56833 5th Feb 2011 12:04am
pom
All puma's have them as far as I know. Some threads here about de-cat pipes and such.
Pom.
Post #56834 5th Feb 2011 12:07am
Naks
Incorrect. Pumas in SA do not have the cat. Although the pipe is there, the internals are not and the oxygen sensor is not connected.
Look on your gearbox on the side closest to the exhaust. If you see an unconnected plug there, it means you don't have a cat.
Post #56844 5th Feb 2011 6:41am
dgardel
Italy
Puma with CAT have not oxygen sensor Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #56848 5th Feb 2011 7:47am
Tim seymour
Australia
yes iam still useing it it is lot quiter more power and i am using castrol mineral 2 stroke oil for motor bikes it is going really well cherrs tim Twisted Evil Cess the Taswegian
Post #56883 5th Feb 2011 11:05am
pom
Just filled up and slapped in some, going for 0.2ml per litre to start off.
This from Halfrauds, correct spec and £9 quid a liter Shocked
Pom
Post #56897 5th Feb 2011 12:17pm
totoD110
I also use 5ml per Liter of diesel...
Post #56909 5th Feb 2011 1:58pm
willy eckerslike
United Kingdom 2007 Defender 110 Puma 2.4 HCPU Keswick Green
I'm using 200ml of diesel per tankful of two stroke, seemed to work the engine went really quiet.........really really quiet, in fact you can't tell it's running. Original Member Pie n Pea Club.
110 HCPU Tipper
Post #56918 5th Feb 2011 2:54pm
