Home > Maintenance & Modifications > Corrosion Prevention Guide! |
Numnuts Member Since: 07 Sep 2016 Location: West Wickham Posts: 6 |
Thanks XK4SPK for the detailed response, want to have this stabilised before the wet weather sets in.
Also, the wife wants to use it to tow and has to drive across a cattle farm to get to the yard, a couple of the horsey people down there are convinced the slurry has caused a lot of issues with rust. Hoping if it can be sealed a gentle wash with a hose wouldn't do it any harm. many thanks Matt |
9th Sep 2016 2:11pm |
Zagato Site Supporter Member Since: 08 Jan 2011 Location: Billingshurst West Sussex Posts: 5013 |
You are all booked in Matt
Yes cow poo eats metal as well as concrete. Pig is the worst, takes days to get the smell out of your skin ( I started off in farming at 14, great days, hard work, we had a series III, I always got the tractor work so wasn,t too bad picking brussel sprouts by hand in snow was no joke). |
9th Sep 2016 2:55pm |
X4SKP Member Since: 29 Nov 2013 Location: Berkshire Posts: 2295 |
... Click image to enlarge But then again...XK Click image to enlarge SKIP https://www.defender2.net/forum/topic83242.html |
9th Sep 2016 3:22pm |
My Fault... Miss driving it but not owning it!
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated |
9th Sep 2016 3:47pm |
very nice...you win...
you have to give it to Jaguar...making a virtue out of the reliability issue...brilliant SKIP https://www.defender2.net/forum/topic83242.html |
9th Sep 2016 4:34pm |
Sadly not a real one but a Nostalgia exact replica worth roughly a third of a real XK120. I bought mine for £17,000 in 2008 and sold it two years later for £27,000 worth 40k plus nowadays. Loved the XK straight six Had to look underneath to tell it was a replica It paid for my new Defender but got my money back from the loss on that with a yacht. sold the yacht for a half cabin trailer sailer, soo cheap to use and a SAAB 96. Will never sell either and now run around in £1000 SAABs that cost nothing to run
9th Sep 2016 4:50pm |
Lunch time top tip, how to reduce your MPG
Check above your front mudflaps, you may think your vehicle is clean after a jet wash but there will be loads of muck hiding unseen. This half box of mud came out of a 110 JUST in the area above the front mudflaps Quite a bit can also hide behind the riveted quarter panel in front of the rear wheel on a 110. That mud will eventually rot the rivets and anything in comes in contact with... As a gardener trying to work with clay soil I do appreciate the fertile earth you all bring me Makes my veg grow lovely :lol: Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Last edited by Zagato on 14th Sep 2016 1:04pm. Edited 2 times in total |
14th Sep 2016 12:03pm |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20376 |
^^^^ I know that spot well just up under the front wheel arch above the mudflap.
You can just about get your hand up there. Then there is the support stay on a 90 to the front of the arch from tub to inner wing. It's steel with a low 'U' shaped upward profile. Mud sticks in there well and in the corners. |
14th Sep 2016 1:02pm |
Three more in for this week Very comfy ride in the black 110, bargain wheels and tyres off Ken I thought
18th Sep 2016 8:20am |
scotty38 Member Since: 21 May 2011 Location: Lincolnshire Posts: 571 |
Chris, if you cast your mind back you were going to do mine when I bought it in 2011 but in the end I decided to do it myself....
Anyway, 5 years on and I reckon it's ready for a fettle. In my mind it doesn't look too bad but there are bits of rust coming through on the chassis and also axles etc (that I didn't do in the first place). You mention that second hand cars take more time (which I understand) but how long would you typically need it for? Thanks.... |
18th Sep 2016 11:45am |
Hairysteve Member Since: 15 Jun 2015 Location: Surrey Posts: 692 |
I like that Black 110
18th Sep 2016 12:29pm |
Yours is a good looking beasty Steve
Scotty just sent you a PM, 2011 and been done before so shouldn,t be any significant extra work involved |
18th Sep 2016 6:20pm |
Stacey007 Member Since: 25 Sep 2015 Location: Cheshire Posts: 3750 |
Having just resprayed my cross member I was also having a look under my car,
It actually doesn't look to bad I don't think its seen any serious off roading anyway. My question, given I need to use the car so not a block of time I could prepare the car, leave it to dry for upto 5 days and then actually do the job. Looking at the front arches for example and front under the sump protector, Can I do 'bits' at a time? |
18th Sep 2016 6:50pm |
It,s easier and a lot quicker to do it in one go of course as everything is clean, dry, masked and stripped at the same time but yes you can do bits of it at a time. The time is the preperation, cleaning, getting rust off, acid converting (wait to dry) light film of cavity wax (wait to dry) then underbody wax. Once clean and flushed I would get the cavity wax in the chassis done first then the other outer bits on the chassis/body can be done more conveniently around the weather
It,s also easier to do it in one go as you only get mucky a few times over the two days. If you are doing it on and off you would need more masking material, plastic sheeting for the ground (you tend to stick to it if you try and re-use) a couple of disposeable boiler suits, more filters for your mask, more gloves and more times to clean yourself up. How ever you cover up it still goes in your eyes, hair etc not to mention your lungs : |
19th Sep 2016 7:02am |
