![]() | Home > Maintenance & Modifications > Corrosion Prevention Guide! |
Mine are about 1/2 as bad so I'll do them myself. I really want to get going now, despite the rain, as the black chequerplate is ready to go back on. I would do ACF first to drive the water out then Sikaflex but won't ACF stop it binding? p.s. Just found out how fast bimetallic corrosion can occur: the untreated chequerplate had been touching one of the capping rivets that had a tiny bit of paint scratched off - there was rust all over it and stains on the plate - after only 2 months :shock: Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated ![]() But shout it at them in German because life is also terrifying and confusing... |
You are right, ACF is somewhat oily and Sikaflex won't take well to it. Steve.
Zagato Site Supporter Member Since: 08 Jan 2011 Location: Billingshurst West Sussex Posts: 5018 ![]() ![]() |
Jesus Matt, I'm going to order you some blimmen sealant myself
Actually, Mr Zag, following your excellent advice I have already bought Sikaflex and ACF and imported them to Germany at great expense ![]() ... it's just a pity I'm too stupid to know what to do with them (suggestions will NOT be welcome ![]() ![]() But shout it at them in German because life is also terrifying and confusing... |
Matt, OK crossed wires if your silkaflex is not the cement/glue type
"window sealant from Frosts.co.uk http://www.frost.co.uk/automotive-windscre...ealer.html" black window sealer code S185 or similar as Bob suggested - stuff that does not dry up anyway! |
Thanks again ![]() Just found out my seal is leaking, hence wet feet. Now I know what to do ![]() But shout it at them in German because life is also terrifying and confusing... |
PeteA Member Since: 14 Jan 2012 Location: Lancs Posts: 44 ![]() ![]() |
Thanks Pete
ginjez Member Since: 18 Sep 2011 Location: huddersfield Posts: 1767 ![]() ![]() |
I've always set to with an artists paint brush and smoothrite on all the door and bonnet screws to stop them rusting and then gone over the smoothrite with a genuine parts touch up pen. No nasty rusty water on the paintwork- cheaper and easier than swapping for stainless.
Alternatively, just smother the entire vehicle with ACF, allow to dry and polish to a shine. Comes up lovely and nothing sticks to it - except my wife's coat the other morning. She still hasn't forgiven me
Spraying with ACF-50 also stops the metal washers in between the the hinges from rusting and the pins also - you can't paint those and they look unsightly when rusty let alone breaking down eventually. My TD5 hinge pin rusted through at only 4 years old
I love the simplicity - just spray everything... perhaps not the windscreen
![]() ACF smells good too ![]() But shout it at them in German because life is also terrifying and confusing... |
