Home > Technical > Defender Puma Clutch Issues |
mick Member Since: 08 Feb 2010 Location: Yorkshire Posts: 2109 |
Do they change pressure plate and flywheel as well.
2nd Dec 2010 5:44pm |
Lorryman100 Member Since: 01 Oct 2010 Location: Here Posts: 2686 |
Not had any issues as off yet!!!! Only done 10k though.
2nd Dec 2010 5:56pm |
mse Member Since: 06 Apr 2008 Location: UK Posts: 5034 |
i dont think i would know what is normal with these, they all seem to have some issue - even if its a minor niggle. Mike
2nd Dec 2010 7:08pm |
fekete Member Since: 24 Dec 2008 Location: Here on the other end of the computer Posts: 3626 |
I've had 3 Clutches changed and since the last one no more issues.....Time will tell though NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY
2nd Dec 2010 7:14pm |
willy eckerslike Member Since: 15 Jun 2009 Location: North yorks Posts: 1789 |
Thats what happened to mine after 30k miles, spring fell out in Dundee had to drive home to Yorkshire with intermittent clutch .
Try not to change to early into 6th gear now as I think the torque judder this can produce eats the clutch springs. Original Member Pie n Pea Club. 110 HCPU Tipper |
2nd Dec 2010 7:45pm |
bm52 Member Since: 04 Apr 2010 Location: Kent Posts: 2189 |
i'll abstain from this one. Don't want to tempt fate BM52
2nd Dec 2010 7:47pm |
RobKeay Member Since: 19 Jul 2009 Location: Stafford Posts: 1579 |
I have a 110 and tow alot but only done 12k so far.
2nd Dec 2010 8:48pm |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 7987 |
mines had two clutches fitted in one day..... i think they just got the first one wrong.
Engine is fine and not lumpy and problem has gone since the new clutch was gone. Cheers James 110 2012 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
2nd Dec 2010 9:03pm |
MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2407 |
Going for another one. Not LRPOS this time Puma 110" SW
2nd Dec 2010 10:17pm |
do they have the same problem with transits ? or is it a different clutch ? I can't see white van man putting up with clutch issues
3rd Dec 2010 8:44am |
The Boy Member Since: 28 Aug 2008 Location: East Northants Posts: 1459 |
My first Puma had two in 14k miles. My 09 has done 13k and so far so good but knowing my luck will hold out until just after the waranty runs out. Yes it is lumpy as hell!!!!!! Never been the same since the last download update but all I get is the standard answer "they all do that"
3rd Dec 2010 9:53am |
ralton Member Since: 04 Feb 2010 Location: Durban Posts: 153 |
I believe the new spec clutch is ok...
I've had 3 clutches - the first two were the old spec (Ford spec), and this third one is the new spec (Land Rover) clutch. As a rough statement: If your clutch is 2007/2008 version, i think there is a fair chance it'll break. If it's a 2009/2010 version you'll probably be ok... www.ralton.co.za |
3rd Dec 2010 11:57am |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17320 |
I thought (but may be wrong) that the tranny Puma has a dual-mass flywheel. If so, then the clutch will be totally different since it won't have the springs at all. |
3rd Dec 2010 11:58am |
Really? My third one (have it in my hands) has the Ford brand stamped. Click image to enlarge Click image to enlarge In this one you can see the gap between the spring and plate Click image to enlarge Puma 110" SW ............................................................. Earth first. Other planets later Last edited by MK on 3rd Dec 2010 12:21pm. Edited 2 times in total |
3rd Dec 2010 12:06pm |
