Home > Technical > Defender Puma Clutch Issues
Clutch issues
Not had any clutch issues
47%
 47%  [42]
Clutch has been changed once and no more issues
29%
 29%  [26]
I have had more than one clutch
13%
 13%  [12]
I have had more than one clutch and on going clutch issues
10%
 10%  [9]
Total Votes: 89
Page 5 of 6 <123456>
hamster
United Kingdom 2011 Defender 90 Puma 2.2 XS CSW Orkney Grey
Just had a new clutch fitted to my 2011 defender 21000 miles, also has to have a new transfer box but they are on back order for how long I don't know. Would like to pass on my thanks to Steve (miserableoldgit) who drove my Defender and gave me his opinion and advised me where to take it to for repair.
Kind regards Paul
Post #260076 20th Aug 2013 2:57pm
2dae
Australia 2008 Defender 110 Puma 2.4 SW Santorini Black
Clutch upgrade
Im pulling out my gearbox to rebiuld as ive got a noise in first gear
Does anyone know where i can get a heavy duty clucth form Question Question Question
Post #279281 4th Nov 2013 9:27am
aage
Iceland 2011 Defender 110 Puma 2.4 DCPU Alpine White
Mine at 19.000 km
No issues at all. Driven it all over the highland many times. NO issues , not a single bulb failure. Clutch feels like new. http://www.defender2.net/gallery/index.php?cat=13451
Post #283344 18th Nov 2013 10:31pm
Cheshire110
dont jinx it!! Cheers, David
Post #283357 18th Nov 2013 10:49pm
richardg
2010 Defender 110 Puma 2.4 XS CSW Stornoway Grey
Thinking I might have a clutch problem on my Puma (MY11, 30K miles). In 6th gear I notice a slight over rev on the tacho if I accelerate going up hill at say 60mph. Seems fine pulling away even if I accelerate quite hard. Any thoughts ?
Post #317357 19th Mar 2014 10:35pm
Blacktt600
England 2008 Defender 110 Puma 2.4 XS CSW Cairns Blue
Clutch replaced
Just picked mine up after having a new clutch fitted owing to rattle springs. It's transformed the drive and I'm one happy bunny! Very Happy
Post #318742 24th Mar 2014 6:44pm
pjw4233
United Kingdom 2011 Defender 90 Puma 2.4 HT Stornoway Grey
2011 model with 56k mileage, no problems so far. Clutch springs seem to rattle a little on tick over when stationary but rattle goes when I depress clutch pedal. I have a couple of months warranty left, is it worth taking it to the dealer to have a look at it?
Post #320698 31st Mar 2014 11:48pm
AndrewS
Yes
Post #320791 1st Apr 2014 3:24pm
110SEB
Defo. Sounds like a clutch release bearing on the way out. Get it while the Censored will pay for it. Get every other single niggle you may have looked at and resolved.
Post #320922 1st Apr 2014 9:43pm
110SEB
Hey Martin, who the Censored do you think you are Censored censoring all my Censored Censored Censored words and Censored Censored my Censored posts up.
Rolling with laughter
Post #320925 1st Apr 2014 9:47pm
degi80
Malta 2007 Defender 90 Puma 2.4 PU Chawton White
Seems like its just not a good time, (just hit the 35,000 miles mark) just replaced the EGR, now on idling, i have a horrible chatter coming from the gearbox / clutch, chatter stops when I press the clutch. Since mine is an early puma late 2007, from what's being said here, I assume it has a faulty / more prone to failure clutch?
Any clue how long it will hold out till it dies totally? Do i have time / any hope to try and plead to LR?
Regards
Mark
Post #332205 20th May 2014 8:58am
Certainly if it is the original driven plate I'd do it asap.
There have been at least three and maybe more different iterations of the driven plate since 2007 and they are improving (a little) each time. My 2007 110 is now on clutch number 3 (fitted at approx 60k miles) and is soon to get number 4 (at approv 145k miles).
Post #332212 20th May 2014 9:15am
tatra805
Slovakia 2008 Defender 110 Puma 2.4 CSW Bonatti Grey
I am now convinced there is no better version out there and the mileage is only depending on type of usage.
Replaced mine with a V4 2 weeks ago after it went bang while pulling a trailer, did just over 100 000 km. It was still the original plate which had the rattle for the past 30K.
Drove the new clutch for the past 200km of which 180km offroad; continues steep hills that demand to work the car.
The new one is now already making the same sound as our new 130 with 2000km (of which 50% on this same terrain)
Not the rattle in neutral yet but when under load at certain revs / labour. This was not there during the first say 50km and was an first change on the original plate about 10k before the rattle-in-neutral started
just fyi
Post #332257 20th May 2014 12:32pm
degi80
Just got back from my mechanic, all hands on deck, and they all concluded that its simply a "feature" to live with.
It only rattles at a certain rpm when in idle, rattle stops when clutch pedal is pressed. Apparently its a "feature" that's been around since the tdi 300s....
i was told to live with it if it doesn't bother me since it shouldn't be doing any harm.
As i mentioned earlier its done 31K miles from new, so starting to develop a few rattles, just another to add to the list, really doesn't say much about Land Rover's quality control (stating the obvious I know)!!!
Post #332281 20th May 2014 2:05pm
tatra805
give me some time and i'll post pictures of how the plate looks after rattling for too long, It is not the rattle that makes a problem but the continues beating it gets due to the free springs which are not dampening the forces as supposed to (and which cause the innocent rattle sound)
after "some" time it disintegrates completely
Post #332283 20th May 2014 2:09pm
