Home > Maintenance & Modifications > Corrosion Prevention Guide! |
Go Beyond Member Since: 30 Jan 2012 Location: Headcorn, Kent Posts: 6678 |
Keep trying, he'll get back to you, March and April are always busy for the trade.
It'll be worth your patience and perseverance |
7th Apr 2015 7:39pm |
Def90 Member Since: 17 Jan 2015 Location: Kent Posts: 258 |
Hi Cadence
He is around,I spoke to him yesterday morning on his home number. |
8th Apr 2015 7:06am |
Venomator Member Since: 25 Aug 2014 Location: Peterborough Posts: 2087 |
He certainly is, I received a quote from him recently... Although he may take a while to respond to PMs as he is very busy... Rog... The GREEN One... MY2016 Urban Truck Build Thread - http://www.defender2.net/forum/topic40548....al[/color] |
8th Apr 2015 8:47am |
Cadence Member Since: 23 Mar 2015 Location: Beaconsfield Posts: 44 |
Now in contact with Chris - thanks all
8th Apr 2015 8:53am |
scotia Member Since: 29 Oct 2014 Location: North Cambs Posts: 96 |
RECOMMENDATION REQUIRED? Need to know where to get your new Defender protected against corrosion? Quote from Bowler Motorsport Technician yesterday. "Your 110 is the best protected Defender we have ever seen in here - it will last forever!" All down to the thorough treatment it received from Zagato (Chris) last month.
14th Apr 2015 7:22am |
Booked in with Chris a couple of days after the end of May delivery ETA.
Getting excited already! |
14th Apr 2015 7:38am |
Zagato Site Supporter Member Since: 08 Jan 2011 Location: Billingshurst West Sussex Posts: 5013 |
Nice to have my work acknowledged especially by Bowler, thanks Jo My next two Defenders are re-doing undersealing work done by two different companies plus all the extra stuff I do to the body and chassis which is the important bit as these things rot in critical areas from the inside out. A simple ad-hoc splurge of underseal is pretty useless, you really have to get your smaller nozzles into all the hidden areas that are not so easy to get at. Plastering the outside of the chassis with gunk may look like a done job but it's the inner areas which collect mud/dirt that rot and there is a lot of them. I am hoping to produce a more thorough guide to the one I have on hear so that people can see exacktly what needs to be done and what extent the work involves so that it's easier for others to do there own Defenders and saves me time in the evenings explaining to folks that call as it's difficult to describe certain areas/brackets etc. Always happy to help where I can though |
23rd Apr 2015 3:48pm |
Scotm Member Since: 28 Feb 2014 Location: Aberdeenshire Posts: 666 |
I did a bit of paint protection at the weekend.
Previously my door seals had rubbed through the paint at the bottom of all the door frame and caused corrosion. This was fixed under warranty and they had applied some waxoil type stuff to stop it happening again. I noticed that the paint was starting to scuff again so I used some 3M Helicopter tape left over from my bike between the paint and the door seal. I also put some on the edge of the sills and the bit just inside the sills to prevent the paint getting scuffed from feet. Hopefully this will mean I won't have to go down the checker plate route eventually for the sills. Hopefully you can see on the pictures Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge |
24th Apr 2015 7:17am |
Mr Fox Member Since: 10 Sep 2011 Location: green & pleasant land Posts: 1037 |
I've PMd Zagato for a quote on a new 90 SW, however, in the interim, I did have two question for the knowledgeable.
I assume it would make sense to replace all the hardware with stainless bolts before doing the corrosion protection - am I wrong? Furthermore, would it make the most sense to replace them whilst carrying out the protection? Secondly, would the same carry over to a the fitting of the spare wheel carrier? I'd like to give the beast the best start in life and would rather have the job done once and done right. |
7th May 2015 8:47am |
X4SKP Member Since: 29 Nov 2013 Location: Berkshire Posts: 2295 |
To add to the advice so far...
SKIP https://www.defender2.net/forum/topic83242.html Last edited by X4SKP on 16th Feb 2016 12:06pm. Edited 1 time in total |
8th May 2015 4:40pm |
MOve Member Since: 24 Dec 2014 Location: East Anglia Posts: 54 |
Excellent. Thanks for posting.
10th May 2015 4:03pm |
jonnyboy Member Since: 15 Oct 2014 Location: Wiltshire Posts: 161 |
Chris (Zegato) did the houours on my 10 year old TD5 last week and did a cracking job. Really thorough!
Highly recommended |
12th May 2015 3:43pm |
Mynstral Member Since: 14 Feb 2012 Location: Essex Posts: 119 |
Hi All. Chris worked his magic on my Utility yesterday. Very pleased with the results.
Regards Myn. Smoke me a kipper I'll be back for breakfast. |
17th May 2015 1:27pm |
Steve W Member Since: 30 Mar 2014 Location: West Sussex Posts: 223 |
Having had the underbody done by the dealer as part of the deal, there is only one check that needed doing.......a trip to Zagato (Chris) to ensure all was good, sadly as Chris has previously posted mine was one of the defenders that he was doing the job on as the best way to discribe what he checked was laughable
Couple of days later, job done top man,top job attention to detail out of this world. Cannot recommend highly enough. |
17th May 2015 3:23pm |
