![]() | Home > Technical > Oil advice and recommendations here! |
army scope jockey Member Since: 10 Aug 2008 Location: germany Posts: 12 ![]() |
This is what I use
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewI...0115172410 It is Ford oil made in germany and meets all of LR specs. 5 liters cost me about 20 euros.[/img][/url] |
I use this (much better)
http://cgi.ebay.it/Castrol-Magnatec-Prof-A...m153.l1262 |
Gabriel Boff Member Since: 19 Apr 2009 Location: Rio Grande do Sul Posts: 95 ![]() ![]() ![]() |
I use this (the bet in my opinion!)
http://www.ew2.lubesinfo.com/datasheetFS.a...3B%205W-30 And what do you use for gearbox, T-case and diff's? |
Naks Member Since: 27 Jan 2009 Location: Stellenbosch, ZA Posts: 2661 ![]() ![]() ![]() |
In SA the MY11 models have an addition to the oil specification in the manual that reads: "In high sulphur markets, use WSS-M2C921-A"
this is an SAE 10W-30 oil which meets ACEA E5-99 and API CH-4 -- 2010 Defender Puma 90 + BAS remap + Alive IC + Slickshift + Ashcroft ATB rear 2015 Range Rover Sport V8 Supercharged ![]() ![]() Defender Puma Workshop Manual: https://bit.ly/2zZ1en9 Discovery 4 Workshop Manual: https://bit.ly/2zXrtKO Range Rover/Sport L320/L322/L494 Workshop Manual: https://bit.ly/2zc58JQ |
gambit Member Since: 26 Mar 2011 Location: Sussex Posts: 79 ![]() |
Hi
I am thinking of doing my own mini service. My car is due an oil change, so Make - Defender Model - 90 CSW Year - 2002 - 52 plate Mods - will have a Stage 1, EGR kit, de-cat and iar filter change Use (road/track etc) - mostly road Although not had the mods done yet, would like the oil used to be able to cope. Cheers |
MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2455 ![]() ![]() ![]() |
For upgraded engines an ACEA A3/B3 B4 (i.e 5W-40) would be ok. Otherwise a 5W-30. Puma 110" SW
![]() Off to look up some prices now ![]() |
vinsell Member Since: 06 Feb 2009 Location: Brindisi (Italy) Posts: 74 ![]() ![]() ![]() |
At my 3th service (out of warranty) I used sae 5w30 acea A3/b4 ENI i-sint. Engine seems smoother and quiter when it is hot ![]() Ciao Vinicio https://google.com/+VinicioSelleri |
mog Member Since: 27 Feb 2011 Location: Århus Posts: 26 ![]() ![]() ![]() |
Can anyone tell me if this oil from castrol is Ok
Castrol EPX 80w/90 (GL 5) The manual states Texaco Geartex EP 85W/90 But that is hard to get here in denmark |
mooro47 Member Since: 26 Apr 2011 Location: Surrey Posts: 29 ![]() ![]() ![]() |
I recently changed the oil in my 2003 Td5 XS Station wagon 70kmiles and after consulting the Castrol website used their recommendation - Castrol Edge Turbo Diesel 5W 40 fully synthetic. Any thoughts on this e.g yes its fine or get it out quick!
Good choice. How long until next change?
Personally I would use an API CI rated oil for a 7500 km interval service. Puma 110" SW ............................................................. Earth first. Other planets later |
I was going to do 6000 mile oil changes as its not a big job, well not now I've got a filter wrench I can actually get round the filter
![]() I'm going to change both the centrifuge filter and the usual canister one as well as they cost peanuts. Compared to the 80 quid for the oil ![]() |
totoD110 Member Since: 26 Nov 2008 Location: Manila, Philippines Posts: 86 ![]() |
I use Motul CRDi specific
Tazz Member Since: 24 Mar 2011 Location: Harrow Posts: 90 ![]() ![]() |
I have a 2004 TDI 110 station wagon and some oil (unused) which is surplus from previous vehicles. I can't remember which was for which, so my questions are 4 Litres of Mobil Synthetic 0W-40 & 4 litres of Castrol SLX Longtec 0W-30. can either of them be safely used in my Land Rover a) as a lubricant, or b) being burnt with the fuel Tazz |
