Home > Technical > Oil advice and recommendations here! |
army scope jockey Member Since: 10 Aug 2008 Location: germany Posts: 12 |
This is what I use
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewI...0115172410 It is Ford oil made in germany and meets all of LR specs. 5 liters cost me about 20 euros.[/img][/url] |
3rd May 2009 10:03am |
I use this (much better)
http://cgi.ebay.it/Castrol-Magnatec-Prof-A...m153.l1262 |
3rd May 2009 11:24am |
Gabriel Boff Member Since: 19 Apr 2009 Location: Rio Grande do Sul Posts: 95 |
I use this (the bet in my opinion!)
http://www.ew2.lubesinfo.com/datasheetFS.a...3B%205W-30 And what do you use for gearbox, T-case and diff's? |
7th Jun 2009 3:05am |
Naks Member Since: 27 Jan 2009 Location: Stellenbosch, ZA Posts: 2638 |
In SA the MY11 models have an addition to the oil specification in the manual that reads: "In high sulphur markets, use WSS-M2C921-A"
this is an SAE 10W-30 oil which meets ACEA E5-99 and API CH-4 -- 2010 Defender Puma 90 + BAS remap + Alive IC + Slickshift + Ashcroft ATB rear 2015 Range Rover Sport V8 Supercharged Defender Puma Workshop Manual: https://bit.ly/2zZ1en9 Discovery 4 Workshop Manual: https://bit.ly/2zXrtKO Range Rover/Sport L320/L322/L494 Workshop Manual: https://bit.ly/2zc58JQ |
3rd Mar 2011 8:04am |
gambit Member Since: 26 Mar 2011 Location: Sussex Posts: 79 |
Hi
I am thinking of doing my own mini service. My car is due an oil change, so Make - Defender Model - 90 CSW Year - 2002 - 52 plate Mods - will have a Stage 1, EGR kit, de-cat and iar filter change Use (road/track etc) - mostly road Although not had the mods done yet, would like the oil used to be able to cope. Cheers |
8th Apr 2011 5:15pm |
MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2416 |
For upgraded engines an ACEA A3/B3 B4 (i.e 5W-40) would be ok. Otherwise a 5W-30. Puma 110" SW
9th Apr 2011 4:44am |
Thanks for the info. Off to look up some prices now |
9th Apr 2011 12:09pm |
vinsell Member Since: 06 Feb 2009 Location: Brindisi (Italy) Posts: 74 |
At my 3th service (out of warranty) I used sae 5w30 acea A3/b4 ENI i-sint. Engine seems smoother and quiter when it is hot . I'll keep You posted. Ciao Vinicio https://google.com/+VinicioSelleri |
9th Apr 2011 2:34pm |
mog Member Since: 27 Feb 2011 Location: Århus Posts: 26 |
Can anyone tell me if this oil from castrol is Ok
Castrol EPX 80w/90 (GL 5) The manual states Texaco Geartex EP 85W/90 But that is hard to get here in denmark |
23rd Apr 2011 4:41pm |
mooro47 Member Since: 26 Apr 2011 Location: Surrey Posts: 29 |
I recently changed the oil in my 2003 Td5 XS Station wagon 70kmiles and after consulting the Castrol website used their recommendation - Castrol Edge Turbo Diesel 5W 40 fully synthetic. Any thoughts on this e.g yes its fine or get it out quick!
12th May 2011 11:48am |
Good choice. How long until next change?
Personally I would use an API CI rated oil for a 7500 km interval service. Puma 110" SW ............................................................. Earth first. Other planets later |
12th May 2011 12:02pm |
I was going to do 6000 mile oil changes as its not a big job, well not now I've got a filter wrench I can actually get round the filter and it can only benefit longer engine life
I'm going to change both the centrifuge filter and the usual canister one as well as they cost peanuts. Compared to the 80 quid for the oil they're peanuts anyway |
27th May 2011 1:55pm |
totoD110 Member Since: 26 Nov 2008 Location: Manila, Philippines Posts: 86 |
I use Motul CRDi specific
28th May 2011 3:26pm |
Tazz Member Since: 24 Mar 2011 Location: Harrow Posts: 90 |
I have a 2004 TDI 110 station wagon and some oil (unused) which is surplus from previous vehicles. I can't remember which was for which, so my questions are 4 Litres of Mobil Synthetic 0W-40 & 4 litres of Castrol SLX Longtec 0W-30. can either of them be safely used in my Land Rover a) as a lubricant, or b) being burnt with the fuel Tazz |
29th May 2011 3:16pm |
