Home > My Defender > 1988 Shire Blue Landrover 90 Restoration
Page 15 of 27 <123 ... 141516 ... 252627>
Co1
Great work Dinnu!
Post #924677 6th Oct 2021 6:05am
Dinnu
Thanks all.
I was thinking of taking the axle to a sandblaster. quite a bit of cleaning needed in the knocks and crannies where the shock and radius arms bolt to. I have already capped the ends (I just turned some PVC and hammered them in the ends)... so would only have needed to make a plate where the diff fits.
In the end I decided to let the rust remover do its job. It is slow, but effective. Patience is key (and a bit of elbow grease just to make it work faster).
For those wondering what rust remover I use, here is a link.
https://hg.eu/uk/products/hg-rust-remover
It is effective as it claims, I use it undiluted, just brush it on. It is not a very harsh chemical, actually has a 'sweet' smell, but a bit irritant if you get it on your hands.
The problem is it has been out of stock locally for quite a while, and I am running low Big Cry 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #924681 6th Oct 2021 6:49am
Did you consider using a needle-scaler instead of blasting?
Post #924700 6th Oct 2021 10:16am
Dinnu
Hi Blackwolf.... doohh why did it not cross my mind.. and I have one sitting on the shelf gathering dust!!!
Thumbs Up 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #924709 6th Oct 2021 11:24am
Dinnu
I think this is as far as cleaning and prepping will go.
Post #924769 6th Oct 2021 7:41pm
Dinnu
Been busy with the spray gun. Few more parts done. Hope to get the front axle less the swivel balls under the chassis, radius arms and panhard rod were done a while ago. So then I can start with the engine, which hopefully frees up some space.
Post #925081 9th Oct 2021 3:09pm
JOW240725
Looking great!! Be done by Christmas! 😉 James
Instagram @suffolk_rovers
Post #925124 9th Oct 2021 8:27pm
Dinnu
Yes. Thats why Christmas comes every year Rolling with laughter 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #925128 9th Oct 2021 8:59pm
Dinnu
Sunday progress.
Post #925196 10th Oct 2021 1:49pm
L110CDL
Great progress Dinnu especially on the axle casing Thumbs Up Clayton.
Keeper.
Post #925685 14th Oct 2021 9:05pm
Dinnu
Was not easy getting the axle case (final drive and diff on) whilst making sure that no paint is scratched and single handed. But now in and I think looks good. Strap in pic was to align panhard rod.
Post #925988 16th Oct 2021 8:08pm
db950
United Kingdom 1997 Defender 110 300 Tdi HT Nato Green
Excellent work as usual, looking great Thumbs Up 1997 Ex-MOD 110, Pop Top Camper, build thread https://www.defender2.net/forum/topic72352.html
2014 Discovery 4 SE Tech
Instagram @the110camper
Post #925993 16th Oct 2021 8:57pm
Dinnu
Thank you db950. I have admired your build.
I think next step will be re building the 19J. I know that there are not a lot of fans of this engine, but will keep you all posted just the same. Only problem is that next update will take a while (December probably) due to travels Big Cry 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #926537 20th Oct 2021 7:31pm
db950
Thank you Dinnu, mutual admiration I guess!!
Will look forward to the engine updates, safe travels Thumbs Up 1997 Ex-MOD 110, Pop Top Camper, build thread https://www.defender2.net/forum/topic72352.html
Post #926556 20th Oct 2021 8:43pm
Dinnu
Finally got about to continue stripping the engine.
Here preparing to get the crank and camshaft out.
Crank bearing caps off:
And the engine block fully stripped for cleaning. I have taken all core plugs since pics, so can do proper flush. Surprised at how little corrosion was on the core plugs.
Post #934045 17th Dec 2021 8:58pm
