![]() | Home > My Defender > 1988 Shire Blue Landrover 90 Restoration |
Clemmo Member Since: 03 Aug 2012 Location: Mile Oak Posts: 1241 ![]() ![]() ![]() |
100 % correct.... Ivory White (LRC354)
Changed over in 1990 (ish) to Alpine White Earlier cars were Limestone..same as the Steel Wheels of the day Be sure its what you want as its a creamy, yellowy off-white... Never looked amazing Clemmo ![]() Defender 90 HT............Pangea Green BMW X3 Msport............Carbon Black Mini Electric................Grey. (wow!) MGB Roadster……..........Vermillion 17k miles Honda Benly CD200....Maroon --------McLouis Fusio........7.4m of fun |
Dinnu Member Since: 24 Dec 2019 Location: Lija Posts: 3536 ![]() ![]() ![]() |
Cheers Clemmo, and thanks for confirming it
![]() 2012 90 CSW, 2.2TDCI, Santorini Black |
Got the original roof out - luckily had not sold it (probably because was too much of a faff getting it out from behind lots of other stuff) as I had replaced it with a smooth roof at some point. Nice to see its corrosion free
![]() ![]() Click image to enlarge 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing 2012 90 CSW, 2.2TDCI, Santorini Black |
L110CDL Member Since: 31 Oct 2015 Location: Devon Posts: 10973 ![]() ![]() |
Great your putting it back on the 90
![]() 1996 Golf Blue 300Tdi 110 Pick up. Keeper. |
Not much doing lately, but got round to prime the roof, and ready for its final coat.
In the mean time had to do some black painting, so figured I could also do a part that was well overdue and desperate to be finished. ![]() Click image to enlarge This should complete the engine bay. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing 2012 90 CSW, 2.2TDCI, Santorini Black |
Procta Member Since: 04 Dec 2016 Location: Sunderland Posts: 5276 ![]() ![]() |
where did you get the bolts to rebuild the defender? My dads has had the same treatment, and they have just used some hardware shop job. largest bolts known to man, for some things, lack of washers, or the wrong washers etc. Its a right old mess.
![]() In the words of my Good Friend, Gary Forrest 1980 -2025 " we will work something out" |
I read your thread on your dad's 90 refurbishment Protca, and you do have a valid reason to be annoyed to say the least.
Most of the fasteners, washers, rivets, self tappings etc I source from local Wurth branch. All of the non critical bolts were replaced with stainless steel, ensured that they are the correct thread size and length, and isolated from the aluminium. Same for washers, all identical size to original. For critical components they were either replaced with like for like, if grade 8.8, then use 8.8, if 10.9, then use 10.9 also of the same thread, and length. Note that for that era, there were still a few UNF bolts. When they were very hard to source, or they were in good condition, and not too cheap to buy, case in point the upper A frame bolts, they were cleaned and re galvanized at home. And some were 'fabricated'. Example the hinge bolts. I wanted stainless (owe, this is one case where I changed from UNC to metic), but could not get domed countersunk philips drive locally. So I purchased pan head M8 screw which I turned and made countersunk. The only fasteners that I had to order online and paying 3x of what they should had costed where the sealed rivets, as the local Wurth branch did not stock them at that time. On the funny side of getting my fasteners, when I was putting the rear tub back onto the chassis, I needed several M8*25 bolts, 14 for sure, but I always tend to buy 2x or 3x of what I need to keep my stock (kind of sick yeah, but saves me a lot of trips). So when I ordered them over the counter, and were handed over, I checked the bolts, and I asked the guy behind the counter to replace some of the bolts because they where not all the same. He looked at me with a blank face, and stated "They are all M8*25!". So I showed him the stamping on the head of the bolts, and asked him to replace because of different stamping on the head (different brands) ![]() ![]() But I am not yet sick enough to align all the hex in exact same orientation ![]() 2012 90 CSW, 2.2TDCI, Santorini Black |
Been contemplating on this feedback ![]() Today ordered the paint.... so I ordered something else ![]() Should have enough extra paint to paint the wolf style rims too if needed. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing 2012 90 CSW, 2.2TDCI, Santorini Black |
JOW240725 Member Since: 04 May 2015 Location: Suffolk Posts: 7918 ![]() ![]() ![]() |
You tease! As long as it isn't black!!
Can't wait to see! James MY2012 110 2.2TDCi XS SW Orkney Grey - http://www.defender2.net/forum/topic43410.html MY1990 110 200TDi SW beautifully faded Portofino Red - https://www.defender2.net/forum/post743641.html#743641 MY1984 90 V8 Slate Grey - https://www.defender2.net/forum/post744557.html#744557 Instagram @suffolk_rovers |
I do enjoy the surprise Dinnu, no matter what colour you have chosen, it will look great and you will do a great job as always
This is what fresh Chawton looks like
CarMan Member Since: 29 Nov 2010 Location: Cotswolds Posts: 1886 ![]() ![]() |
Nice
![]() 1993 200tdi 90 hard-top 1998 300tdi 90 soft-top |
Not been on Def2 for a while so thought I'd catch up on progress Dinnu.... James
Been busy with everything else, and kind of need a kick of motivation…. But today I painted the rear window frames
![]() Just a glimpse: ![]() Click image to enlarge 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing 2012 90 CSW, 2.2TDCI, Santorini Black |
