Home > My Defender > 1988 Shire Blue Landrover 90 Restoration
Page 16 of 28 <123 ... 151617 ... 262728>
L110CDL
Good bit of progress there Dinnu Very Happy Clayton.
Keeper.
Post #934054 17th Dec 2021 9:40pm
Dinnu
Thanks Clayton. Can say it is slow, but cannot say that it was steady last couple of months Big Cry
Hope I get back on track for a short while.... work commitment unfortunately taking too much time. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #934076 18th Dec 2021 8:34am
JOW240725
Just remember it's the work that pays the bills to allow you to do this fantastic restoration!! Thumbs Up Bow down James
Instagram @suffolk_rovers
Post #934085 18th Dec 2021 10:24am
Dinnu
You are so right James. Not just time is required !
Spent a couple of hours cleaning the engine block. Quite a bit of deposits came out. I honed the bores... unfortunately some areas at the top end of the stroke did not hone so well - I have the 3 legged honer not the ball type. I hope still good, as did not want to hone too much. I cannot really feel a ridge, so should be ok for the rings.
A bit of paint later, engine block looking nice again. Target was to get dirty today, so can spend some clean evenings playing with the bottom end of the engine.
Post #934119 18th Dec 2021 4:29pm
Co1
Nice work as always. Thumbs Up
Post #934140 18th Dec 2021 7:41pm
Dinnu
Thank you Co1 Very Happy 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #934144 18th Dec 2021 8:13pm
Dinnu
Some progress today.
Piston oil coolers installed.
Crank installed on new shells and thrusts. Getting the rear bearing cap on was a bit of a fight without the proper guiding blocks for the T shaped seals.. but in the end got there.
Rotating the crank found some 'hard spots' Shocked . Bit of head scratching later, found that the T seals on the rear bearing cap that still need trimming off fouling the crank... pheww.
Can shaft is installed on original journals.
Post #934440 20th Dec 2021 8:24pm
L110CDL
Time well spent Dinnu on cleaning the block and then starting to put it all back together Very Happy Clayton.
Keeper.
Post #934457 20th Dec 2021 9:39pm
Dinnu
Yes Clayton, best way to spend some time.. at least in my nerdish opinion 😂
Still a few more parts to clean... but for now I will try to assemble whatever is already clean 😉 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #934458 20th Dec 2021 9:47pm
L110CDL
I would be the same way, can't beat the items being clean and then you can have a good look and then asses them Thumbs Up Clayton.
Keeper.
Post #934461 20th Dec 2021 9:56pm
Black Puma
United Kingdom 2011 Defender 90 Puma 2.4 SW Sumatra Black
Love this build/rebuild Dinnu. Thank you for sharing. Don't rush, because I can wait to see this build unfold Bow down
Post #934532 21st Dec 2021 1:28pm
Dinnu
Thank you Black Puma. I am actually getting worried about the rush/no rush thing, as I already purchased the tyres Embarassed
Bit more progress..
Getting the first piston ready to install. Pistons are not genuine. The genuine ones were quite expensive, and my reasoning was that if genuine crack, then might as well spend less.. and worse case is they crack as well and buy another set Big Cry
The timing case is almost ready to install. This timing case has 3 gaskets. One that goes around, to tentatively keep the oil in. There is another gasket just behind where the tensioner goes, and there is another gasket for the coolant. Strangely enough, they have different thicknesses... so very baffled.
Post #934585 21st Dec 2021 8:11pm
Dinnu
It is getting together. Looking more like an engine now... will not break any land speed records, but I will take good care of it, and it will get me there.
The sump has seen some better times... need a lot of TLC to get it look good again. That will be for another day. And will get the cover and bracket at back side of the injection pump painted at the same time.
Post #934822 23rd Dec 2021 2:58pm
L110CDL
Great progress Dinnu, does look like an engine now Very Happy Clayton.
Keeper.
Post #934872 23rd Dec 2021 10:18pm
Dinnu
I had done the painting of the sump and a few small brackets, so Christmas afternoon while family was watching some movies, I entertained my self with this:
Better than watching another Christmas movie 😂 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #935054 25th Dec 2021 8:59pm
