Home > My Defender > My 110 MILLIE.
Page 11 of 67 <123 ... 101112 ... 656667>
Procta
It might be worth having a check just in case yours is going the same way, if two people have had the same trouble Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
Success is 90% Inspiration and 4 minutes Preparation # you can make it!
Post #705525 5th May 2018 7:14pm
L110CDL
You will know when you have a crack, when the grill starts getting the oily stuff on it Wink 1996 Golf Blue 300Tdi 110 Pick up.
Keeper.
Clayton.
Post #706262 9th May 2018 7:39pm
L110CDL
Millie had reached a milestone today, so i had to stop and take a pic ................................................
Mr. Green 1996 Golf Blue 300Tdi 110 Pick up.
Keeper.
Clayton.
Post #707164 14th May 2018 7:33pm
JOW240725
Cricket, that's some mileage! My red is just run in at 178k Shocked James
Instagram @suffolk_rovers
Post #707170 14th May 2018 7:54pm
Procta
how does millie still pull at that mileage? Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
Post #707173 14th May 2018 8:01pm
L110CDL
Yours is just run in James, but should reach this mileage if serviced regularly Wink Very Happy 1996 Golf Blue 300Tdi 110 Pick up.
Keeper.
Clayton.
Post #707179 14th May 2018 8:16pm
L110CDL
After sorting out the problems she is pulling really good, just a little bit of black smoke Wink 1996 Golf Blue 300Tdi 110 Pick up.
Keeper.
Clayton.
Post #707181 14th May 2018 8:17pm
Mines only done 64k yet. I do under 10k a year so at that rate I've got at least another 20 years plus to go. Rolling with laughter Rolling with laughter No Guts, No Glory.
๐Ÿ‡ฌ๐Ÿ‡ง๐Ÿด๓ ง๓ ข๓ ฅ๓ ฎ๓ ง๓ ฟ๐Ÿด๓ ง๓ ข๓ ท๓ ฌ๓ ณ๓ ฟ๐Ÿด๓ ง๓ ข๓ ณ๓ ฃ๓ ด๓ ฟ๐Ÿ‡ฎ๐Ÿ‡ช๐Ÿ‡บ๐Ÿ‡ธโ›ฝ๏ธ๐Ÿ›ข๏ธโš™๏ธ๐Ÿงฐ๐Ÿ’ช
Post #707196 14th May 2018 8:48pm
L110CDL
^^^ Rolling with laughter 1996 Golf Blue 300Tdi 110 Pick up.
Keeper.
Clayton.
Post #707208 14th May 2018 9:19pm
L110CDL
Just a little update on the wheel arch product that i'm using, the arches have had a second wash and as i was drying Millie down i dried the wheel arches as well and as rubbed them, they came up like this ...............................
I'm impressed with it so far as normally it would of faded and you would of seen all sorts on the arches. So after one more wash and dry, i will let you know how it all goes Very Happy Very Happy 1996 Golf Blue 300Tdi 110 Pick up.
Keeper.
Clayton.
Post #708466 21st May 2018 8:49pm
L110CDL
As i have posted our green laning day out in " what did you do in your defender today " Millie had some other damage, the pic is of the bit of metal bent back into place, you can see where the tare in the metal is and i have pot riveted back in as the rivets that were holding it all in place just came right out, it had bent it self upwards about 30 degree's, i was very lucky that the indicator unit stayed in tack Very Happy ............
The reflector went missing as well, but i got another one today and has been fitted Very Happy
I had to re attach the mud flap as well, no problems there Wink
The last bit of damage was the splash guards/trim, the same side as the above damage, it had broken it good and proper so off it comes and i then took the other side off as well ..................................
Damaged side ..............
The other side ...........
The damaged splash guard/trim ........................
I wont be putting another set on, will be leaving it as is Thumbs Up 1996 Golf Blue 300Tdi 110 Pick up.
Keeper.
Clayton.
Post #710023 30th May 2018 8:52pm
L110CDL
I had to change my wiper's today as they were not doing the job as good as before, so i went back to the OEM look and got these ..................................
Will see how i get on with these and will let you know Thumbs Up 1996 Golf Blue 300Tdi 110 Pick up.
Keeper.
Clayton.
Post #710032 30th May 2018 9:05pm
mk1collector
What caused the damage? There's some good rear corner protectors about that could save the back, they bolt to the rear crossmember and around the corner. Looked like a great day out though Thumbs Up Ray
My build thread
Post #710067 30th May 2018 11:15pm
L110CDL
Not sure what caused the damage Ray, i'm assuming that it happened at the same time i did the front wing Sad
I have looked at putting the corner protectors on but cant as i have my Laid supports fixed where they would go Sad you can see in the pic what i mean .........................
Keeper.
Clayton.
Post #710328 1st Jun 2018 7:05pm
Corner protectors are good, so long as it isnโ€™t such heavy damage theyโ€™ll be bent in No Guts, No Glory.
Post #710332 1st Jun 2018 7:11pm
