Home > Technical > Defender Puma Clutch Issues |
2dae Member Since: 21 Sep 2013 Location: Maudsland Posts: 27 |
Im pulling out my gearbox to rebiuld as ive got a noise in first gear
Does anyone know where i can get a heavy duty clucth form |
4th Nov 2013 8:27am |
aage Member Since: 26 Jul 2012 Location: Iceland Posts: 44 |
No issues at all. Driven it all over the highland many times. NO issues , not a single bulb failure. Clutch feels like new. http://www.defender2.net/gallery/index.php?cat=13451
18th Nov 2013 9:31pm |
Cheshire110 Member Since: 26 Jul 2013 Location: Cheshire/London Posts: 2762 |
dont jinx it!! Cheers, David
Land Rovers of all shapes S3 onwards… Daily is a 110 V8. |
18th Nov 2013 9:49pm |
richardg Member Since: 17 Dec 2012 Location: Cumbria Posts: 30 |
Thinking I might have a clutch problem on my Puma (MY11, 30K miles). In 6th gear I notice a slight over rev on the tacho if I accelerate going up hill at say 60mph. Seems fine pulling away even if I accelerate quite hard. Any thoughts ?
19th Mar 2014 9:35pm |
Blacktt600 Member Since: 30 Nov 2013 Location: Leeds Posts: 125 |
Just picked mine up after having a new clutch fitted owing to rattle springs. It's transformed the drive and I'm one happy bunny!
24th Mar 2014 5:44pm |
pjw4233 Member Since: 30 Nov 2009 Location: Lake District & Cheshire Posts: 273 |
2011 model with 56k mileage, no problems so far. Clutch springs seem to rattle a little on tick over when stationary but rattle goes when I depress clutch pedal. I have a couple of months warranty left, is it worth taking it to the dealer to have a look at it?
31st Mar 2014 10:48pm |
AndrewS Member Since: 10 Apr 2007 Location: Hereford Posts: 3709 |
Yes
1st Apr 2014 2:24pm |
110SEB Member Since: 29 Jan 2009 Location: Essex, England Posts: 1444 |
Defo. Sounds like a clutch release bearing on the way out. Get it while the will pay for it. Get every other single niggle you may have looked at and resolved.
1st Apr 2014 8:43pm |
Hey Martin, who the do you think you are censoring all my words and my posts up.
1st Apr 2014 8:47pm |
degi80 Member Since: 24 Apr 2011 Location: MT Posts: 24 |
Seems like its just not a good time, (just hit the 35,000 miles mark) just replaced the EGR, now on idling, i have a horrible chatter coming from the gearbox / clutch, chatter stops when I press the clutch. Since mine is an early puma late 2007, from what's being said here, I assume it has a faulty / more prone to failure clutch?
Any clue how long it will hold out till it dies totally? Do i have time / any hope to try and plead to LR? Regards Mark |
20th May 2014 7:58am |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17527 |
Certainly if it is the original driven plate I'd do it asap.
There have been at least three and maybe more different iterations of the driven plate since 2007 and they are improving (a little) each time. My 2007 110 is now on clutch number 3 (fitted at approx 60k miles) and is soon to get number 4 (at approv 145k miles). |
20th May 2014 8:15am |
tatra805 Member Since: 16 Aug 2011 Location: Dolany Posts: 436 |
I am now convinced there is no better version out there and the mileage is only depending on type of usage.
Replaced mine with a V4 2 weeks ago after it went bang while pulling a trailer, did just over 100 000 km. It was still the original plate which had the rattle for the past 30K. Drove the new clutch for the past 200km of which 180km offroad; continues steep hills that demand to work the car. The new one is now already making the same sound as our new 130 with 2000km (of which 50% on this same terrain) Not the rattle in neutral yet but when under load at certain revs / labour. This was not there during the first say 50km and was an first change on the original plate about 10k before the rattle-in-neutral started just fyi |
20th May 2014 11:32am |
Just got back from my mechanic, all hands on deck, and they all concluded that its simply a "feature" to live with.
It only rattles at a certain rpm when in idle, rattle stops when clutch pedal is pressed. Apparently its a "feature" that's been around since the tdi 300s.... i was told to live with it if it doesn't bother me since it shouldn't be doing any harm. As i mentioned earlier its done 31K miles from new, so starting to develop a few rattles, just another to add to the list, really doesn't say much about Land Rover's quality control (stating the obvious I know)!!! |
20th May 2014 1:05pm |
give me some time and i'll post pictures of how the plate looks after rattling for too long, It is not the rattle that makes a problem but the continues beating it gets due to the free springs which are not dampening the forces as supposed to (and which cause the innocent rattle sound)
after "some" time it disintegrates completely |
20th May 2014 1:09pm |
