![]() | Home > Technical > 2 stroke oil |
TDCi Guy Member Since: 17 Aug 2014 Location: Yorkshire Posts: 286 ![]() ![]() ![]() |
Try sticking an injector cleaner through it?
You can get the tips of your injectors changed/serviced at your local bosch place, new injectors are a lot of moolah! |
cornish rattler Member Since: 31 Aug 2013 Location: Manchester Posts: 642 ![]() ![]() ![]() |
Yeah it runs and sounds great but it has always had a slight uneven run on idle, last owner had speeded up the idle to prevent this but i found it was idling to fast and slowed it down and noticed it and just the other weekend as i was stood over the engine assisting son fit the clutch master cylinder i noticed no 4 injector was very rusty compaired to the other 3 hence why i think i have an injector problem
![]() 1988 Defender 90 county 200tdi ( Beast ) Paul Walker 1973-2013 ( I Almost Had You ) |
take them out and get them tested , doesn't cost that much
the non electronic injectors are a lot cheaper to recon or buy new im not a great lover of recon injectors , if funds can do it try to find some new ones 9 out of 10 times its metal from the high pressure pump (just normal wear ) that's causes the problem with injectors and no additive will dissolve metal ! also might be worth checking pump timing , just because the cambelt timing is right it doesn't mean the pump timing is right Last edited by munch90 on 29th Sep 2014 5:45pm. Edited 1 time in total |
Anderzander Member Since: 08 Feb 2011 Location: Lancashire Posts: 1000 ![]() ![]() |
I've poured in 300ml of two stroke tonight - see what happens
most seem to use 200ml for a 90 not sure on 110
be handy to hear your views on it |
Oops - I put 250 in, not sure why I said 300.
Mine is a 90 - I was calculating from the detailed quote at the start of the thread, which states 200:1 - 500ml to 1000 litres. I have 50 + litres in so I'm in line with it. I'll report back. ![]() |
Just a though, does the 2SO mix ok when poured into the tank?
I usually put a glob in the tank at the petrol station before refueling in the belief that it helps it mix? In case the 2SO just sinks in the diesel and sits in the bottom of the tank? Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's) |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8233 ![]() ![]() ![]() |
100L = 0.5L Cheers James 110 2010 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
as you drive it will mix in |
pjw4233 Member Since: 30 Nov 2009 Location: Lake District & Cheshire Posts: 273 ![]() ![]() ![]() |
I have a 90, and I put 250ml of 2SO when the fuel light comes on and I fill up (about 50 liters) which works out at 200 to 1.
![]() Thanks - I'm having some sort of number crisis .... I meant 100 L |
It will mix in few seconds, diesel is like a thinner for the oil Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition ![]() IID Pro MV License |
Well ! Mine is substantially smoother and quieter.
It seems most noticeable at lower engine speeds - as in it rattles if In a bit firm of aggressive in the throttle, however tick over and on he gentle pick up the engine note is substantially different. Only other point - I wasn't sure if pick up was a little slower ? That may be due to me still getting used to this engine though. |
takoon Member Since: 16 Oct 2013 Location: central Posts: 48 ![]() ![]() |
2 stroke or 4 stroke?- any significant difference other than the 4 stroke looks and feels more like chainsaw oil (thicker)?
I have used both but can`t notice any difference so far. Does anyone else has experience of the matter? -99 Td5 90 CSW -09 Jaguar xk4,2 Portfolio |
