![]() | Home > Technical > Oil advice and recommendations here! |
oilman Site Supporter Member Since: 19 Mar 2009 Location: Cornwall Posts: 511 ![]() |
Hi all,
We have been invited by the club to offer any help and advise we can on oil etc. If you have any questions on the oily stuff please post them here and we will do our best to help. If you would like a recommendation for your vehicle please add the following info. Make - Model - Year - Mods - Use (road/track etc) - Hope fully we can be of some service here Cheers Guy http://www.opieoils.co.uk Use the code DEF2 and get 10% Club Discount View Opie Oils Current Offers Here > > oilman's website: http://www.opieoils.co.uk/ - register for news and offers email: sales@opieoils.co.uk phone: 01209 202944 |
Yep, it will be fine. The only thing is it may use a bit more.
Cheers Guy Use the code DEF2 and get 10% Club Discount View Opie Oils Current Offers Here > > oilman's website: http://www.opieoils.co.uk/ - register for news and offers email: sales@opieoils.co.uk phone: 01209 202944 |
Thanks for the quick reply
Sorry should of asked before is the turbo deisel oil the same as the petrol oil or little difference Cheers Karl NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY |
Do you mean between the Edge 0w-30 and the Edge TD 0w-30?
Sorry guy
yess between the Edge 0w-30 and the Edge td 0w-30 as its the Edge 0w-30 i can get my hands on thanks Karl NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY |
MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2461 ![]() ![]() ![]() |
Sorry to jump in, but the manual states you can only use 5w/30 meeting the Ford WSS-M2C913-B
spec. It is an oil with low high-temp-high-shear viscosity. Puma 110" SW ............................................................. Earth first. Other planets later |
Hi MK,
EDGE is of the same Formulation, and probably a better oil NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY |
Don´t know, but does it meet such Ford spec? Puma 110" SW ............................................................. Earth first. Other planets later |
Tim in Scotland Member Since: 23 May 2007 Location: The Land that time forgot Posts: 3753 ![]() ![]() |
Make - Land Rover
Model - Defender Tdi300 Year - 1996 Mods - EGR removed and blanked off and Cat removed Use (road/track etc) - 20% on road 80% offroad - it only does about 3000miles a year Pangea Green D250 90 HSE with Air Suspension, Off-road Pack, Towing Pack, Black Contrast roof , rear recovery eyes, Front bash plate, Classic flaps all round, extended wheel arch kit and a few bits from PowerfulUK Expel Clear Gloss PPF to come 2020 D240 1st Edition in Pangea Green with Acorn interior. Now gone - old faithful, no mechanical issues whatsoever ever but the leaks and rattles all over the place won’t be missed! |
Defender 90 SW MY08
2.4 PUMA Engine Chipped (+/- 160 HP) 13000 km on the clock Mobil1 5w/30 with WSS-M2C913-B compliance (one of the best oil on the market) I changed ALL OILS at 8000km!!!! Last edited by dgardel on 24th Mar 2009 4:39pm. Edited 1 time in total |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6657 ![]() ![]() ![]() |
Hi Guy,
Can you please specify oils/fluids for the following: Defender with Td5 Engine (2.5 5 cylinder 1998-2007) Defender with Puma Engine (2.4 2007-) R380 Manual Gearbox (factory recommended oil is Texaco "MTF94") (1998-2007) LT230 Transfer Gearbox and Axles (factory recommended is 75W-90 GL5) (1998-?) Can someone fill in the gap for the Puma 6-speed gearbox, and is the LT230 transfer still used on the Pumas? |
Does such oil really exists? Puma 110" SW ............................................................. Earth first. Other planets later |
gearbox uses Castrol BOT 130 (fully synth GL-4), it is 75W/90. Do not use GL-5!. Yes, the LT230Q it`s still used. Puma 110" SW ............................................................. Earth first. Other planets later |
Tony_Hillerby Member Since: 03 Feb 2008 Location: Inverurie Posts: 36 ![]() ![]() ![]() |
Had a look on the Castrol website and put the registration in to find the corect oils for the 110. The manual gearbox says SMX -S which is a synthetic 75W-85 gear oil.
I cannot find any trace on the castrol site of BOT130 as stated. Is this SMX oil the same with a differant name. Tony |
