![]() | Home > Maintenance & Modifications > Corrosion Prevention Guide! |
arran jones Member Since: 21 Nov 2016 Location: south west Posts: 728 ![]() ![]() |
Hello All,
On my TDCI defender 90 Pick up, I have 2 little rust spots coming through on the paintwork just under the windscreen, would this be rusting just where the spots are or would it be the whole width of my defender, also what would be the best way to get rid of it b4 it gets to worse?? Thanks in advance ![]() ![]() |
I could take the bolts off the door hinges that go into the bulkhead, but have they got nuts the other side or is it just a screw out, screw in bolt, I don't know weather that's would help/stop it??? If I sprayed some anti - corrosion stuff in there???
They are captive nuts -J nuts - in the bulkhead, although they can be a bit of a sod so I'd be prepared with new ones if you haven't had the bolts out before. Darren
OK thanks, are they hard to put back in and does it matter if the old ones fall down the bulkhead or not??
'Fiddly' and 'no, not really'. I expect that there are many Defenders running around with nuts lost down the bulkhead pillars! Darren
X4SKP Member Since: 29 Nov 2013 Location: Berkshire Posts: 2303 ![]() ![]() ![]() |
Hello arran jones
As L'R'A said M8 J Nuts...old type on the left...new type on the right (longer thread section... ![]() I replaced all mine when I did this. ![]() Click image to enlarge Undo the bolts, Bulk Head side (one hinge at a time... ![]() a long reach pipe will allow you to get good (all be it blind) coverage within the 'cavity'. ![]() Click image to enlarge Good Luck... SKIP https://www.defender2.net/forum/topic83242.html |
OK thanks very much both for the awesome advice, this forum couldn't be any better
Just looking at the captive nuts now,
Are these the right one, u have a 2009 defender 90 pickup ![]() Click image to enlarge Thanks again ![]() |
Sorry spelling mistake
The 'U' was meant to be a 'i' |
DrRob Member Since: 29 Mar 2017 Location: Hampshire Posts: 243 ![]() ![]() |
PM sent
Yes...Land Rover Captive Nut for Door Hinge Series 3 and 90 / 110 MRC2178 https://www.johncraddockltd.co.uk/series/s...90110.html http://www.paddockspares.com/mrc2178-hinge...e-nut.html https://www.lrdirect.com/MRC2178-Door-Hing...ner-Bhead/ SKIP https://www.defender2.net/forum/topic83242.html |
Thanks both, very kind
Have now, ordered 3 aresols of dinitrol 3125(500ml) with extension pipes and 8 captive nuts,
As I can see the rust spots on the paintwork, how do I get rid of that from the outside, because obviously dinitrol will only stop it not take it away ![]() Thanks again ![]() |
Got all my stuff today
![]() ![]() Give it a start tomorrow ![]() ![]() Click image to enlarge |
