Home > Maintenance & Modifications > Corrosion Prevention Guide!
Page 44 of 86 <123 ... 434445 ... 848586>
Zagato
No problem with this one I have just done Mark. A limited edition Bowler with 100 miles on the clock...
Post #610330 18th Mar 2017 5:29pm
arran jones
Hello All,
On my TDCI defender 90 Pick up, I have 2 little rust spots coming through on the paintwork just under the windscreen, would this be rusting just where the spots are or would it be the whole width of my defender, also what would be the best way to get rid of it b4 it gets to worse??
Thanks in advance Thumbs Up
Very Happy
Post #612538 27th Mar 2017 12:58pm
arran jones
I could take the bolts off the door hinges that go into the bulkhead, but have they got nuts the other side or is it just a screw out, screw in bolt, I don't know weather that's would help/stop it??? If I sprayed some anti - corrosion stuff in there???
Post #612540 27th Mar 2017 1:14pm
They are captive nuts -J nuts - in the bulkhead, although they can be a bit of a sod so I'd be prepared with new ones if you haven't had the bolts out before. Darren
Post #612560 27th Mar 2017 2:11pm
arran jones
OK thanks, are they hard to put back in and does it matter if the old ones fall down the bulkhead or not??
Post #612569 27th Mar 2017 2:57pm
'Fiddly' and 'no, not really'. I expect that there are many Defenders running around with nuts lost down the bulkhead pillars! Darren
Post #612574 27th Mar 2017 3:04pm
X4SKP
Hello arran jones
As L'R'A said M8 J Nuts...old type on the left...new type on the right (longer thread section... Thumbs Up )
I replaced all mine when I did this.
Undo the bolts, Bulk Head side (one hinge at a time... Exclamation ) and in you go with Dinitrol 3125
a long reach pipe will allow you to get good (all be it blind) coverage within the 'cavity'.
Good Luck... SKIP
Post #612575 27th Mar 2017 3:08pm
arran jones
OK thanks very much both for the awesome advice, this forum couldn't be any better Thumbs Up Very Happy
Post #612583 27th Mar 2017 3:51pm
arran jones
Just looking at the captive nuts now,
Are these the right one, u have a 2009 defender 90 pickup
Thanks again Thumbs Up
Post #612691 27th Mar 2017 8:26pm
arran jones
Sorry spelling mistake
The 'U' was meant to be a 'i'
Post #612692 27th Mar 2017 8:27pm
DrRob
PM sent Thumbs Up
Post #613083 29th Mar 2017 4:03pm
X4SKP
Post #613107 29th Mar 2017 5:35pm
arran jones
Thanks both, very kind Thumbs Up
Post #613115 29th Mar 2017 6:02pm
arran jones
Have now, ordered 3 aresols of dinitrol 3125(500ml) with extension pipes and 8 captive nuts,
As I can see the rust spots on the paintwork, how do I get rid of that from the outside, because obviously dinitrol will only stop it not take it away Thumbs Up
Thanks again Very Happy
Post #613445 30th Mar 2017 10:00pm
arran jones
Got all my stuff today Very Happy Thumbs Up
Give it a start tomorrow Laughing
Post #613676 31st Mar 2017 8:26pm
