Home > Maintenance & Modifications > Corrosion Prevention Guide!
Page 29 of 86 <123 ... 282930 ... 848586>
X4SKP
Both work well...Rustbuster FE 123 Reviews are... Thumbs Up
http://www.rust.co.uk/fe-123-rust-converter/c28125/
Good Luck... SKIP
Post #513237 11th Mar 2016 3:51pm
Martin 01
That's the sort of stuff I'm after X4SKP Thumbs Up
Post #513379 11th Mar 2016 9:20pm
APK
United Kingdom 2015 Defender 110 Puma 2.2 Adventure Corris Grey
Hello everyone,
Mine is coming up to 2 months and Zagato did a brilliant job with the Dinitrol treatment when it was just 1 week old Very Happy
I was going over the hinges, bolts and revets with ACF-50 today and noticed these two areas when I took a look inside.
Is there anything I can apply to stop the rust and get it back to looking new?
Thanks in advance for your comments!
Post #513715 12th Mar 2016 10:12pm
kingsley
United Kingdom 2006 Defender 90 Td5 XS CSW Tonga Green
Hi guys, looking for a good company or someone to wax my chassis on my defender, I live in Kent, can anyone please recommend someone???
Post #514326 14th Mar 2016 8:09pm
Inigo
United Kingdom 2012 Defender 110 Puma 2.2 USW Orkney Grey
Zagato is only a short trip away around the bottom of the M25. I got the supplying dealer in Canterbury to Waxoyl mine from new. but they weren't keen and it wasn't a very good job.
Post #514335 14th Mar 2016 8:16pm
kingsley
Thank you for replying, I asked them too, but sent me to a local garage who were going to jet wash then do it, don't think it would be dry enough to apply.
Post #514343 14th Mar 2016 8:37pm
kingsley
Are Zagato very good?
Post #514344 14th Mar 2016 8:38pm
kingsley
I cannot find anything on google about them, do you have any information for them please?
Post #514345 14th Mar 2016 8:41pm
X4SKP
APK wrote:
Hello everyone, I noticed these two areas when I took a look inside.
Hello APK
They all do that Sir... Exclamation
I used the FE123 to convert the rust to a hard 'stable' layer prior to painting, you actually need the rust
for this to work, but that shouldn't be an issue as this special attention to material selection comes as
standard on the Puma Engine... Shocked
I have yet to finish mine off, I just roamed around the engine bay and carefully 'converted' all that was there...
I did this last summer and it's still looks like these photos, when it warms up a little further I'll finish off with
some enamel or VHT paint (stove black)
Good Luck... SKIP
Post #514348 14th Mar 2016 8:43pm
kingsley
Thank you, I have corrosion starting on rear tub cappings
Post #514351 14th Mar 2016 8:49pm
RRUK
Zagato is a member of the forum who does this work. 2016 D4 HSE
1982 Series 3 SWB Petrol
Post #514397 14th Mar 2016 10:13pm
Inigo
And is the original poster of this thread.
Once my V8 is back on the road, I'll be giving him a call. Last time I asked, there was quite a long lead time.
Post #514430 15th Mar 2016 12:22am
APK
Thank you X4SKP
Looks great. Keen to know your thoughts on how long you expect the converter to last with the engine heat.
Also, are there any other areas to be mindful of?
Post #514608 15th Mar 2016 5:39pm
APK
Hello kingsley,
Zagato/Chris did an excellent job with my Defender in Jan. His explanation of the process and advice before / after the Dinitrol process was (and still is) much appreciated. Toughest part was leaving it at his place to dry for a week (it was raining). He is highly recommended.
Suggest dropping him a PM.
Post #514610 15th Mar 2016 5:46pm
Steve W
Zagato did mine the right way this was after the supplying dealer said they had done the whole vehicle and it was quite laughable. I would recommend Zag without any hesitation whatsoever.
Post #514631 15th Mar 2016 6:47pm
