Home > Maintenance & Modifications > Corrosion Prevention Guide!
Page 78 of 86 <123 ... 777879 ... 848586>
Co1
Top man, thanks. Thumbs Up
Have you got a rough steer on how many cans I’d need for a 90? Can it literally go on pretty much anything (brake components excluded!).
Post #977629 11th Jan 2023 6:31pm
Zagato
Yes can go on anything, common rails included. I would go with 6-8 cans and put on 3 layers. Thumbs Up
Post #977689 12th Jan 2023 9:16am
chopper
United Kingdom 2010 Defender 90 Puma 2.4 XS CSW Santorini Black
Have sent a PM regarding current prices 👍
Post #978599 17th Jan 2023 8:18pm
Zagato
Thumbs Up
Post #978601 17th Jan 2023 9:26pm
dainger
United Kingdom 2015 Defender 90 Puma 2.2 XS CSW Corris Grey
How bad is this looking?
It was undercoated (24 months ago) by a professional but can see its peeling in some areas. Is this expected?
Should I let it run its course? touch it up? Or is it better now to have it properly stripped back and treated properly?
She’s a 2015 40k miles on her.
Post #979346 23rd Jan 2023 11:55am
Zagato
Pm sent! (Sensitive area commenting on another's work)
Post #979357 23rd Jan 2023 12:55pm
GM_FFX
United States 1992 Defender 90 200 Tdi HT Rimini Red
Interested in this too
Post #980418 29th Jan 2023 10:44pm
TexasRover
If you ask me it does not look great. But then I think in America it needs to be clarified where and how this car is driving around. The Rustbelt is something special, maybe it is the salt they use, but it is aggressive!
I lived in the south for many years and cars will look near new after 15-20 years. Even 1980s cars can have 0 rust. I also had a LR3 (Discovery 3) from Alaska and it looked fantastic underneath. No salt in Alaska from what I understand. However you look at a U-tube channel such as South Main Auto (New York) and even 5 year old cars in the rustbelt have holes rotten in it.
Regular warm/soap HP washing of the bottom to remove sand and salt combined with a more regularly applied oily style protection (waxoil, Fluid Film (I like that one!)) is I think the better solution than trying to create some sort of permanent barrier.
Post #980444 30th Jan 2023 9:46am
Waiteu2
Mines is similar to the 2015 one above.
Zag can you PM me with prices too please?
Not eligible to PM you as not enough posts.
Thanks.
Craig
Post #980558 30th Jan 2023 8:22pm
RobKeay
The windscreen surround on my 2014 looks terrible. It’s been painted twice but the paint just flakes off. Any advice gratefully received.
Post #980559 30th Jan 2023 8:26pm
geobloke
What was it treated with? There is no way after 24 months it should be looking that bad, not even with Lanoguard which is not as resilient as waxoyl or dintrol. Did you take any freshly coated photos for comparison?
Post #980561 30th Jan 2023 8:28pm
dainger
I never asked the place which did it what they used but i reckon it must have just been painted on over the top of this already.
But I’m booked in with Zagato later this year to get it all sorted so happy days.
Post #980571 30th Jan 2023 9:19pm
Zagato
Thanks.
Craig
Pm sent Craig Thumbs Up
Post #980616 31st Jan 2023 9:40am
Zagato
You will see in many previous posts over the years I have noted that 14 plates are particularly bad for windscreen corrosion. I am afraid as with many parts on all Land Rovers including chassis, these were largely already corroding prior to the actual vehicle being built.
To explain the chassis for instance is simply coated with a porous matt black paint. No primer to stop moisture getting through, so when the chassis are stacked up outside the factory in the rain prior to the actual vehicle being built your rear crossmember will start to rust in no time.
I have seen window frames corrode even on collectors vehicles that have only ever been dry from new. It is a weird alloy mix that bubbles and crumbles into a powder especially where the seams are but lesser elements do seem to rust like steel. I am afraid (similar to simple alloy corrosion) there is nothing you can do. You can rub it back and paint it but it will come back through in a year or so.
Hopefully someone will produce sound aftermarket window frames Thumbs Up
Post #980621 31st Jan 2023 9:57am
Zagato
TexasRover wrote:
Regular warm/soap HP washing of the bottom to remove sand and salt combined with a more regularly applied oily style protection (Fluid Film (I like that one!)) is I think the better solution than trying to create some sort of permanent barrier.
Wise words... there is no instant cure, maintenance is the only answer, spraying your vehicle with a clear glue product or rock hard product just makes matters a lot worse. You are trapping in corrosion which you cannot easily address in the future, it actually accelerates corrosion as they trap in moisture. I can pop lifted areas on Lanoguard, Buzzweld products, Raptor etc etc that just let out brown water but worse you cannot get this damn stuff off.
Post #980623 31st Jan 2023 10:19am
