Home > My Defender > 1988 Shire Blue Landrover 90 Restoration
Page 13 of 27 <123 ... 121314 ... 252627>
Co1
Tidy work dinnu, as always.
Post #903948 19th May 2021 5:43pm
87110
Greece
I was going to find a post to quote you on Dinnu but I got distracted and re-read three pages Whistle
Anyway, it's great how you want to preserve the originality by keeping the 17H. I personally consider it the defender of land rover engines: you don't have it because it's good, you have it because you love it. Also, what is the suffix of your LT77? I'm assuming its a later one since the engine itself appeared later on.
Post #903971 19th May 2021 8:16pm
Dinnu
Actually I have the 19J. I think among the landrover owners and enthusiasts the 19J is considered the worse engine ever made by Landrover. But well said, I want to keep the originality because I love it. And I love it this way.
My gearbox is a suffix D. Not the strongest one either... but with the few horses to turn it I am sure it will last long enough 😁 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #903977 19th May 2021 8:30pm
87110
Greece
I just realized that I wrote 17H instead of 19J. I guess you know what engine is stuck in my mind now. Laughing
Post #903978 19th May 2021 8:33pm
Dinnu
Yes I know. What you say is very true. I think at that time the 19J was miles ahead of competition. And even more if you consider that only a handful of years earlier, Solihull was building series 3s. Nothing against the series landrover, but I think the coil sprung landrover are far superior especially in the chassis and suspension departments. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #903982 19th May 2021 8:55pm
Dinnu
Turned the attention to the pedals\boxes. The clutch pedal box is not yet assembled, contemplating about using Dot5, hence the other thread https://www.defender2.net/forum/topic78646.html
Post #904566 23rd May 2021 5:11pm
L110CDL
Nice work there as always Dinnu Cool 1996 Golf Blue 300Tdi 110 Pick up.
Keeper.
Clayton.
Post #904821 24th May 2021 8:19pm
Dinnu
Thank you. The assembly of clean parts is really satisfying although at times frustrating when I realize I have left out a part and the way to get it in is another disassembly 😡. Happened with the gas pedal too. I was so focused on not scratching the paint, and that the pivot shaft is well greased that after tapping in the cotter pin, realized that the return spring was still on the work bench Big Cry 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #904860 25th May 2021 4:37am
L110CDL
Yes i know what you mean, done that a few times thinking that it's all okay to put the last bit in only to realise that it has to come apart as you had forgot a part had to go in, o happy days Rolling Eyes 1996 Golf Blue 300Tdi 110 Pick up.
Keeper.
Clayton.
Post #905015 25th May 2021 8:09pm
Dinnu
Stupid mistake of mine.... I turned 6x M8 S/S bolts removing the top most 5 threads to replicate the original bolts only to find that the original bolts are UNF and not metric! Did not feel like going out to purchase 6 UNF bolts, so cleaned the original ones, and re galvanized them. Some time later, the clutch pedal box is fully assembled, and installed.
Post #906154 2nd Jun 2021 2:28pm
L110CDL
The bolts really did clean up well, they look new in the pic's Thumbs Up 1996 Golf Blue 300Tdi 110 Pick up.
Keeper.
Clayton.
Post #906216 2nd Jun 2021 8:29pm
Dinnu
Yes Clayton. The first pic shows the SS bolts, but those are the metric ones. There are 2 side by side bolts, the UNF original bolt and the modified metric SS bolt.
Yeah, a bit of time on the wire wheel, and in the galvanizing bath (electroplating) makes them look new again. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #906263 3rd Jun 2021 6:47am
Dinnu
Long time ago gave the 90 to a garage to repair a leaking clutch master cylinder. When it came back, the cover that covers the harness cable entry into the bulkhead, part number AMR4741 came broken, presumably after the clutch pipe was pulled out Big Cry Ever since, some odd 20 years, this broken cover was put aside with my other landrover spares. Glad I did not discard...
These covers are available, but the price of a small piece of plastic is ridiculous to say the least. So I made a quick and temporary repair to my original cover, got some fiberglass and resin, made a mold, and made a new one.. stronger material of course. Bit of paint.. and job done.
Post #906727 7th Jun 2021 8:21am
Fantastic Cool Darren
Post #906731 7th Jun 2021 8:40am
L110CDL
Bow down 1996 Golf Blue 300Tdi 110 Pick up.
Keeper.
Clayton.
Post #906968 8th Jun 2021 8:55pm
