Home > My Defender > Grafty's Td5 90 |
grafty99 Member Since: 15 Aug 2012 Location: North Devon Posts: 4795 |
Can you believe it, I actually haven't taken any photos of it fitted !?!
The only one I have it the one earlier in the thread with the single wiper box and linkage on the bench. It basically a steel bracket which picks up on the standard motor mounting threads on the bulkhead. A Range Rover wiper motor is attatched to it. Then two modified wiper boxes with arms welded onto them and rods with rose joints linking it all together. 2002 90 Td5 Station Wagon 1990 Vogue SE Triumph Tiger Explorer 1200 Td5 90 Thread http://www.defender2.net/forum/topic50767.html Tdi 110 Thread https://www.defender2.net/forum/topic69562.html RRC Thread http://www.defender2.net/forum/topic54492.html Instagram http://www.instagram.com/george_grafton |
26th Aug 2018 9:08pm |
Retroanaconda Member Since: 04 Jan 2012 Location: Scotland Posts: 2690 |
Not to worry. What model of Range Rover did the motor come out of?
I imagine it took a bit of trial and error to get the lengths and positions of the linkages/arms right so as to get the correct sweep. |
27th Aug 2018 8:06am |
Procta Member Since: 03 Dec 2016 Location: Sunderland Posts: 5230 |
What about doing some kits grafty? Might be worth it Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
27th Aug 2018 1:47pm |
hank Member Since: 12 Sep 2016 Location: South Wales Posts: 2315 |
Love the wiper mod and would definitely be keen on a kit!!!
27th Aug 2018 1:53pm |
The motor is from my Range Rover Classic donor. Even the wiring colours match!
As for the lengths I measured the standard sweep angle (105°) and then used Pythagoras to work out how long the wheel box arms needed to be with the wiper sweep. Put it all together and turns out my maths was correct! Luckily If there was interest in a kit then I could look into producing one 2002 90 Td5 Station Wagon 1990 Vogue SE Triumph Tiger Explorer 1200 Td5 90 Thread http://www.defender2.net/forum/topic50767.html Tdi 110 Thread https://www.defender2.net/forum/topic69562.html RRC Thread http://www.defender2.net/forum/topic54492.html Instagram http://www.instagram.com/george_grafton |
27th Aug 2018 5:21pm |
Id take a kit off you, the vent upgrade/update was a great help for heating and cooling Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
27th Aug 2018 6:50pm |
Thanks for the motor info. What did you make the link rods out of? I guess they could be standard bar with a rose joint on each end at the simplest end of the scale.
Any packaging challenges behind the dash in terms of finding space for the moving linkages? |
28th Aug 2018 8:24pm |
I used stainless tube with rose joints as you say. Packaging is very, very tight. Missing the vent brackets and the rear of the centre console by just a few mm.
I think a Tdi would be a bit easier but it's hard to say for sure without looking 2002 90 Td5 Station Wagon 1990 Vogue SE Triumph Tiger Explorer 1200 Td5 90 Thread http://www.defender2.net/forum/topic50767.html Tdi 110 Thread https://www.defender2.net/forum/topic69562.html RRC Thread http://www.defender2.net/forum/topic54492.html Instagram http://www.instagram.com/george_grafton |
28th Aug 2018 8:37pm |
L110CDL Member Since: 31 Oct 2015 Location: Devon Posts: 10859 |
Did you see part 18 of project Binky in the end as it explains all how to get your angles and sweeps Clayton.
28th Aug 2018 9:08pm |
I have started the series from the beginning. Up to episode 16 at the moment. So I will have seen it by the end of the week 2002 90 Td5 Station Wagon
28th Aug 2018 9:11pm |
I thought that you were following it anyway, what do you think of it and the detail Clayton.
28th Aug 2018 9:15pm |
I have been following it but only started watching at about episode 7, I thought it would be good to catch up from the beginning before I get to episode 18 2002 90 Td5 Station Wagon
28th Aug 2018 9:25pm |
The attention to detail is amazing. I wish I had that much patience 2002 90 Td5 Station Wagon
28th Aug 2018 9:26pm |
^^^ Me to
Wait until you get to part 18, all i will say is rear wiper Clayton. 1996 Golf Blue 300Tdi 110 Pick up. Keeper. |
28th Aug 2018 9:45pm |
