Home > My Defender > Grafty's Td5 90
Page 73 of 124 <123 ... 727374 ... 122123124>
Retroanaconda
Got any pictures of your wiper linkages? I’ve seen it done on Land Rover racers and wondered whether it would be possible to fit it behind a dashboard, clearly you have done just that.
Post #725540 26th Aug 2018 8:06pm
grafty99
Can you believe it, I actually haven't taken any photos of it fitted !?! Embarassed
The only one I have it the one earlier in the thread with the single wiper box and linkage on the bench.
It basically a steel bracket which picks up on the standard motor mounting threads on the bulkhead. A Range Rover wiper motor is attatched to it. Then two modified wiper boxes with arms welded onto them and rods with rose joints linking it all together. Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Triumph Tiger Explorer 1200
Post #725546 26th Aug 2018 9:08pm
Retroanaconda
Not to worry. What model of Range Rover did the motor come out of?
I imagine it took a bit of trial and error to get the lengths and positions of the linkages/arms right so as to get the correct sweep.
Post #725585 27th Aug 2018 8:06am
Procta
What about doing some kits grafty? Might be worth it Thumbs Up Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
Post #725643 27th Aug 2018 1:47pm
hank
Love the wiper mod and would definitely be keen on a kit!!!
Post #725645 27th Aug 2018 1:53pm
grafty99
The motor is from my Range Rover Classic donor. Even the wiring colours match!
As for the lengths I measured the standard sweep angle (105°) and then used Pythagoras to work out how long the wheel box arms needed to be with the wiper sweep.
Put it all together and turns out my maths was correct! Luckily Shocked
If there was interest in a kit then I could look into producing one Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Post #725676 27th Aug 2018 5:21pm
Procta
Id take a kit off you, the vent upgrade/update was a great help for heating and cooling Thumbs Up Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
Post #725686 27th Aug 2018 6:50pm
Retroanaconda
Thanks for the motor info. What did you make the link rods out of? I guess they could be standard bar with a rose joint on each end at the simplest end of the scale.
Any packaging challenges behind the dash in terms of finding space for the moving linkages?
Post #725918 28th Aug 2018 8:24pm
grafty99
I used stainless tube with rose joints as you say. Packaging is very, very tight. Missing the vent brackets and the rear of the centre console by just a few mm.
I think a Tdi would be a bit easier but it's hard to say for sure without looking Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Post #725934 28th Aug 2018 8:37pm
L110CDL
Did you see part 18 of project Binky in the end as it explains all how to get your angles and sweeps Whistle Clayton.
Keeper.
Post #725951 28th Aug 2018 9:08pm
grafty99
I have started the series from the beginning. Up to episode 16 at the moment. So I will have seen it by the end of the week Laughing 2002 90 Td5 Station Wagon
1990 Vogue SE
Post #725952 28th Aug 2018 9:11pm
L110CDL
I thought that you were following it Shocked anyway, what do you think of it and the detail Very Happy Clayton.
Keeper.
Post #725955 28th Aug 2018 9:15pm
grafty99
I have been following it but only started watching at about episode 7, I thought it would be good to catch up from the beginning before I get to episode 18 Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Post #725959 28th Aug 2018 9:25pm
grafty99
The attention to detail is amazing. I wish I had that much patience Laughing 2002 90 Td5 Station Wagon
1990 Vogue SE
Post #725961 28th Aug 2018 9:26pm
L110CDL
^^^ Me to Wink
Wait until you get to part 18, all i will say is rear wiper Whistle Clayton.
Keeper.
Post #725968 28th Aug 2018 9:45pm
