Home > My Defender > Grafty's Td5 90
Page 72 of 124 <123 ... 717273 ... 122123124>
Procta
barbel jim wrote:
Procta wrote:
What has caused the head float?
The early (10p) engines were renown for head gaskets running standard. The 15P (circa 2002)engines should have metal dowels to stop the head moving around, should it lift. Unfortunately, and not surprising the Lanrdover employee used the whats at hand approach when building Georges engine Rolling Eyes coupled with his extras Laughing its proved costly. However with the need for another Head, another modification can be made
I bet thats why some of the early k series engines were better than th later ones, As the later ones had more trouble with the dowels too, as i mentioned to george. So lookes to me its been a famous cut back across the range then. Rolling Eyes Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
Success is 90% Inspiration and 4 minutes Preparation # you can make it!
Post #725025 23rd Aug 2018 12:05pm
Procta
barbel jim wrote:
Thought about Low comp pistons ??I know you can get uprated head bolts but not cheap Big Cry
Yeah george are you going to touch the bottom end? Might be worth looking at some upgrades there if you have the ££
When i did my k series engine i did look at the bottom end, but the pistons were £500, I did toy with the idea but i thought the car just isnt worth it. i threw nearly 10k at it before, yeah i threw 10k at a rover metro Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
Post #725027 23rd Aug 2018 12:09pm
LandymanStefan
England 2001 Defender 90 Td5 SW Epsom Green
Doesn't the amc head come with uprated dowels and bolts?
Post #725037 23rd Aug 2018 12:58pm
grafty99
The company I'm using is making me solid dowels for locating the head. The clamp pressure for the standard bolts is fine for what I'm doing, I would imagine you'd have to be running serious boost to need anything more substantial. I'm getting standard replacements Thumbs Up
So to answer the question no I don't think it does, unless you buy it from somewhere like Turner Engineering who build them up into kits Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Triumph Tiger Explorer 1200
Post #725087 23rd Aug 2018 6:39pm
barbel jim
Awwww come on George Whistle Whistle
U need more POWER Mr. Green
Post #725093 23rd Aug 2018 7:01pm
LandymanStefan
Oh right, I thought you could only get them from turners Embarassed
Will you be doing the work yourself? If so please take pictures of the new head in all its glory I'd be interested to see it. Mine being a 10p may need one when the time comes....
Post #725100 23rd Aug 2018 7:14pm
grafty99
Turners are the most well known but I wanted my valve gear putting into a new head as I know it's been well looked after. I'm using Wards Engineering in Rugby who are fitting my valve gear and building up the head (also turning some solid dowels for me).
Of course I'll take some pictures when I receive it and during the fitting process Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Post #725106 23rd Aug 2018 7:21pm
Procta
If the option is there to run the better head bolts and you have the budget, I would. Just to be a fanny Thumbs Up Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
Post #725147 24th Aug 2018 12:49am
grafty99
I'm sure the standard bolts are good for a bit more power yet Whistle 2002 90 Td5 Station Wagon
1990 Vogue SE
Post #725158 24th Aug 2018 6:55am
grafty99
Well the dash is all back together and the wipers are working a treat! A picture for Profyaffle of the alcantara Whistle
1990 Vogue SE
Post #725477 26th Aug 2018 3:16pm
grafty99
Still not sure about the alcantara gear lever covers, they might have to go.... 2002 90 Td5 Station Wagon
1990 Vogue SE
Post #725480 26th Aug 2018 3:17pm
Profyaffle
Bow down Bow down Bow down
Brilliant... I love it.. I know where you're coming from with the gear gators.. give them a months trial...
I've crossed my fingers for you getting your head sorted and getting back on the road...... 1993 200Tdi Defender 90
Post #725495 26th Aug 2018 5:07pm
grafty99
Thank You, me too Laughing 2002 90 Td5 Station Wagon
1990 Vogue SE
Post #725510 26th Aug 2018 5:56pm
barbel jim
fancy fixing the wipers..... it's living in the workshop Whistle
Post #725512 26th Aug 2018 6:00pm
grafty99
The wipers weren't broken Laughing
They're now silky smooth and sweep/park reliably. I have converted from cable to rod and link, much better Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Post #725519 26th Aug 2018 6:34pm
