![]() | Home > My Defender > Grafty's Td5 90 |
kenzle8a Member Since: 12 Feb 2020 Location: None Posts: 1074 ![]() ![]() |
The paint on mine will remain as is considering the horse uses it as an itching post sometimes...
grafty99 Member Since: 15 Aug 2012 Location: North Devon Posts: 4795 ![]() ![]() ![]() |
If our horse did that to my 90 it would be turned into glue quicker quicker than you could say pritt
![]() 1990 Vogue SE Triumph Tiger Explorer 1200 Td5 90 Thread http://www.defender2.net/forum/topic50767.html Tdi 110 Thread https://www.defender2.net/forum/topic69562.html RRC Thread http://www.defender2.net/forum/topic54492.html Instagram http://www.instagram.com/george_grafton |
Shes also tried to chew the steering wheel a few times... Part of being an appy I think, mostly shes 500kg of thug.
![]() Luckily ours can't access where the vehicles are parked. Although she has bolted a gate twice before so perhaps she's trying ![]() 1990 Vogue SE Triumph Tiger Explorer 1200 Td5 90 Thread http://www.defender2.net/forum/topic50767.html Tdi 110 Thread https://www.defender2.net/forum/topic69562.html RRC Thread http://www.defender2.net/forum/topic54492.html Instagram http://www.instagram.com/george_grafton |
LJMARSDEN Member Since: 08 Jun 2021 Location: Nottingham Posts: 343 ![]() ![]() ![]() |
is it cheeky if I ask for an STL of that? lol I fancy making one from Aluminium Grafty |
PM inbound. 2002 90 Td5 Station Wagon
atakanmerdin Member Since: 15 Dec 2017 Location: Nairobi Posts: 26 ![]() ![]() |
HI grafty! Hoping to get a little more info on the td5 info dash. are you running it wired or over Bluetooth?
Thanks! |
When using it I run it wired via a USB adapter to my phone ![]() 1990 Vogue SE Triumph Tiger Explorer 1200 Td5 90 Thread http://www.defender2.net/forum/topic50767.html Tdi 110 Thread https://www.defender2.net/forum/topic69562.html RRC Thread http://www.defender2.net/forum/topic54492.html Instagram http://www.instagram.com/george_grafton |
Simboii Member Since: 09 Jun 2021 Location: Carmarthen Posts: 71 ![]() ![]() ![]() |
Have you any more info/pics of the intake setup your running from the wing to he airbox??
Interested to upgrade mine to a simular setup!! |
It's a kit available from IRB Developments, it's an adapter that replaces the factory elbow out of the Airbox, a 4 inch pipe then an adapter on the wing - you also remove the water separator in the Airbox.
Here are some pictures ![]() ![]() Click image to enlarge ![]() Click image to enlarge 2002 90 Td5 Station Wagon 1990 Vogue SE Triumph Tiger Explorer 1200 Td5 90 Thread http://www.defender2.net/forum/topic50767.html Tdi 110 Thread https://www.defender2.net/forum/topic69562.html RRC Thread http://www.defender2.net/forum/topic54492.html Instagram http://www.instagram.com/george_grafton |
Thats great, would be something if be very interested in getting! Best to contact them regarding this setup then! Is there a big difference running this setup? |
jimbo55 Member Since: 15 Jul 2020 Location: Midlands Posts: 400 ![]() ![]() |
Isn’t bad for a design I came up with on my lunch break from work (although Ian has changed a couple of bits), Nice to see Ian had some made over a year after I gave him the models
Grafty, how have you doubted the pipe under the engine cover? Mine goes over the top of the cover and never been too happy with it |
It is a super mod for a TD5. I got impatient for Ian to get the kit together so made my own. The increase in diameter makes a huge difference when a RAI is added on to the intake length. Miffy breathes beautifully. If you get rid of the air boxes impeller then I highly recommend not fitting a forward facing scoop, but something like the Mantec mushroom style tops or Donaldson style bowl tops. With the scoop in heavy rain your air filter can get a little damp...
It does fit underneath, it's tricky to route it but it will go, you have to push the coolant pipe junction to the header tank down but with some persuasion it all fits. It's then cable tied up out of the way of the steering column. I don't think it would work with the double servo on ABS equipped defenders though? 2002 90 Td5 Station Wagon 1990 Vogue SE Triumph Tiger Explorer 1200 Td5 90 Thread http://www.defender2.net/forum/topic50767.html Tdi 110 Thread https://www.defender2.net/forum/topic69562.html RRC Thread http://www.defender2.net/forum/topic54492.html Instagram http://www.instagram.com/george_grafton |
