Home > Puma (Tdci) > Another output shaft.....
Page 10 of 18 <123 ... 91011 ... 161718>
ian series 1
United Kingdom 2008 Defender 90 Puma 2.4 CSW Bonatti Grey
I will have a look Thumbs Up 80" 80" 86" 88" 90"
Wanted, Forward Control Anything considered.
Post #720942 2nd Aug 2018 5:25am
shropshiredefender
England 2011 Defender 110 Puma 2.4 USW Santorini Black
I'm having an Ashcroft conversion fitted next week as a precaution before my next continental trip.
My 2011 model 2.4 110 has done 115k miles, I bought it with 40k on the clock @ 3 years old. During my ownership no output shaft problems, so I guess it's on the statistical cusp of problems!
Anyway I have the kit and have taken some pics. at odd angles Whistle
Replacement for plastic and and zip tie combo
Modded cup
I'll update regarding the condition of the existing set up later next week.
Post #721008 2nd Aug 2018 11:51am
ian series 1
Ahh, so it looks like they have addressed the clip, by making it a screw on cover?
So surely they can’t pull apart?
Looks good to me!
I think I will try an Ashcroft kit on the next one I do.
Thanks for posting the pics Thumbs Up 80" 80" 86" 88" 90"
Post #721013 2nd Aug 2018 12:05pm
shropshiredefender
Yes Ian the screw on cover with dual O rings at each end of the assembly looks as if it also helps to retain the shaft fully into the cup with minimal in/out movement.
Ashcroft transmissions seem to have missed a significant USP with their marketing on this item Cool
Post #721016 2nd Aug 2018 12:14pm
The main reason for the screw-on cap is to ensure that the splined section is oil-tight (there are O rings fitted at the small end which run on a newly machined section of the output shaft), but it will also have the benefit that the parts cannot shift much if the spring ring lets go.
^^ Snap - posts coincided!
Post #721017 2nd Aug 2018 12:15pm
DAZ110
United Kingdom 2013 Defender 90 Puma 2.2 XS CSW Barolo Black
ian series 1,
Your welcome to change my output shaft to an Ashcroft one if you want the job. Also change the clutch at the same time as mine is rattling.
Let me know if you want the job. Thumbs Up
Can run the vehicle over to you.
Darren
Post #721064 2nd Aug 2018 2:43pm
ian series 1
Hi Darren
I’m out this evening, but I will drop you a PM either later Tonight, or in the morning. Thumbs Up 80" 80" 86" 88" 90"
Post #721101 2nd Aug 2018 5:19pm
DAZ110
Thanks Ian. Thumbs Up
Post #721108 2nd Aug 2018 6:13pm
Yannis
United Kingdom 2015 Defender 90 Puma 2.2 CSW Corris Grey
Driving up the hill to the house tonight I heard a few teltail noises from my output shaft!!
Basically here in Italy all the dealers are closed for August so I will be doing the job my self.
Ashcroft Shaft and will fit a Clutch Fix Clutch at the same time.
Before I dive into the manuals, can anyone tell me any special tools or parts I may need to consider ontop of the Shaft and Clutch kits?
Post #722118 7th Aug 2018 11:44pm
ian series 1
You will need either a 2 or 3 leg puller to remove the drive cup from the box,
Something to align the clutch plate with, apart from that it’s all straightforward.
If your doing it at home, probably the worst part is the weight of it all, especially the T box!
Take care Wink 80" 80" 86" 88" 90"
Post #722123 8th Aug 2018 6:17am
Yannis
I join the “my output shaft just failed” club....
Lucky I got it on the drive and moved into a sensible posistion to strip it down.
I actually have the shaft failing on video..... Shocked
I will try and post the video to YouTube and post a link!
2015 - 29,758miles
Post #722184 8th Aug 2018 10:00am
Yannis
As promised;
Post #722191 8th Aug 2018 10:15am
agentmulder
Kuwait
Shocked Laughing Solved the bowel problem, working on the consonants...
Post #722204 8th Aug 2018 10:53am
ian series 1
Yep! That’s gone Big Cry Rolling Eyes 80" 80" 86" 88" 90"
Post #722208 8th Aug 2018 11:15am
How come? Was it just pure coincidence that you happened to be filming?
That sound is instantly recognisable to Defender drivers as either the failure of the splines on either the o/p shaft or a halfshaft. Big Cry
Post #722265 8th Aug 2018 2:27pm
