Home > Puma (Tdci) > Another output shaft.....
Page 2 of 19 <123 ... 171819>
Naks
dorsetsmith wrote:
I still don't understand how Land Rover haven't taken responsibility for this yet!!
ford gear box not LR as ford run LRJ Rolling Eyes
hey, at least it's not as bad as the crank failures on the T/SDV6 Whistle --
Post #686279 13th Feb 2018 9:51am
ian series 1
United Kingdom 2008 Defender 90 Puma 2.4 CSW Bonatti Grey
Very true! Thumbs Up 80" 80" 86" 88" 90"
Wanted, Forward Control Anything considered.
Post #686294 13th Feb 2018 11:11am
dorsetsmith
Ian on that out shaft was retaining clip in place when you removed transfer box Question
Post #686302 13th Feb 2018 11:56am
ian series 1
Yes the clip was in place, but it wasn’t fully home!
I’ve found this on all of the ones I’ve replaced.
When putting them back together, I drive the shaft into the cup with a block of wood and a hammer, to get it seated all the way in. Thumbs Up 80" 80" 86" 88" 90"
Post #686313 13th Feb 2018 12:37pm
dorsetsmith
that explains spline damage from your pic Rolling Eyes thanks
Post #686315 13th Feb 2018 1:10pm
JOW240725
Another output shaft gone, yesterday. Original output shaft replaced under warranty in 2015 (prior to my ownership), so this one has lasted 3yrs Shocked James
Instagram @suffolk_rovers
Post #711076 6th Jun 2018 2:17pm
MK
I do not have a full track of failures occurred and informed in this forum, but it seems the problem started on Pumas built after some certain date. Mine is a very early one and I´m wondering it will eventually fail. Excuse my spanglish. Puma 110" SW
Post #711248 7th Jun 2018 3:12pm
From a non-scientific survey of the forum I did a year or two ago it seems that 2007-build failures are rare (mine is currently on 225,000 miles on the original shaft) and it has gone downhill from then. 2010-build seems to be a very bad time, with many failures.
Although this failure is a really annoying fault and it is shameful that Landrover built a vehicle with this fault, it continues to fascinate me how two notionally identical vehicles, bult at the same time, can be so different. One might last 250,000 miles and the next off the line might last 5,000 miles. There must be more to this than simply a lack of lube. Somewhere there is a major QC problem, whether it is materials spec or alignment, I couldn't say, but there must be more to this than lubrication.
Post #711249 7th Jun 2018 3:19pm
Caterham
BW can I through a spanner into the works / equation. It's about all I'm capable of doing with spanners Laughing ....
I had a fault with my transmission from day one. the trucks done 100k miles now. My first failed at approx. 25k, 2nd at about 50k - 60k and had a further one installed before failure at about 90k (all from memory).
when I safe fault with my transmission numerous LR dealerships drove my truck including a LR mobile tech guy and they all gave it a clean bill of health as have numerous other persons all familiar with LR's (defenders). any how turns out they my diff lock lever was poorly adjusted and not pushing the tab on the transfer box far enough over to the nearside. albeit the diff lock light never came on there has been numerous indicators to suggest the transmission was locking up and I also believe noise from the transmission.
now my thoughts are if so many people (both educated and experienced) thought it was 'ok' how many other trucks are out there that are 'ok' and could this lead to premature wear? I think it probably would, I'm not saying it's the sole cause but I strongly believe it's a contributing factor. Question
Post #711253 7th Jun 2018 4:07pm
nosnibod
United Kingdom 1998 Defender 110 300 Tdi SW Bronze Green
Off to Ian at IRB on Saturday to check mine out. On the first shaft at 52,000 miles and there is definitely a clonk if I'm a bit heavy-handed changing gear. In reality I just want to make sure it's not going to fail during our holiday later in the year towing the caravan.
Must remember to take some pictures... Dave
Green Goddess - 1998 Defender 110 300tdi
Post #711258 7th Jun 2018 4:46pm
MK
Not an expert, but I dont think any clonk is related to such end of the output shaft. If flange splines are ok, I would blame a slacky central diff. Puma 110" SW
Post #711269 7th Jun 2018 5:38pm
nosnibod
That’s why I’m having an expert look at it! Dave
Post #711271 7th Jun 2018 5:41pm
JOW240725
An interesting thought, I wonder how you would check/know? James
Post #711274 7th Jun 2018 5:53pm
Caterham
crawl underneath and check if the tab on the transfer box is getting pushed all the way across by the leakage or can you push it the last 1cm by hand?
Post #711280 7th Jun 2018 6:30pm
Julie
Some say that the spline is going to receive more wear if the MT82 and the shaft are not exactly in one line.
Interesting detail: The part LR030054 has two equal splines but only one spline fails in any case.
The inner spline at the MT82 will never fail. It's always the "outer" spline connecting the shaft.
From my point of view corrosion seems to be relevant.
The "inner" spline is black and appears almost new (no wear).
The "outer" spline is completely corroded (rust is harder than steel, an accelerated wear is obvious).
Corrosion in the spline is a result from humidity / temperature changes.
The absence of grease could also explain an early wear.
Post #711502 8th Jun 2018 9:35pm
