Home > Puma (Tdci) > Another output shaft.....
Page 11 of 18 <123 ... 101112 ... 161718>
MK
shropshiredefender wrote:
I'm having an Ashcroft conversion fitted next week as a precaution before my next continental trip.
My 2011 model 2.4 110 has done 115k miles, I bought it with 40k on the clock @ 3 years old. During my ownership no output shaft problems, so I guess it's on the statistical cusp of problems!
Anyway I have the kit and have taken some pics. at odd angles Whistle
Replacement for plastic and and zip tie combo
Modded cup
I'll update regarding the condition of the existing set up later next week.
In theory a low mileage Defender intended to travel long distances and to remote areas would need at least:
Clutch
Release bearing just in case
Output shaft and seals
Drive flanges
Diff seals
At least one CV
Crankshaft seals
Headlight switch
Vaccum pump
Intercooler
Turbo actuator
Injector seals
A front diff in case it is a 110 or 130 with 2 gear diff.
So defenetly a small trailer just for spares Twisted Evil Puma 110" SW
Post #722324 8th Aug 2018 6:48pm
DSC-off
Yannis, Sorry to hear about your trouble.
Yours is yet another late model, low milage Defender failing in the typical 25 - 30k miles period.
What is becoming more apparent is that the paste/protection, whatever it was, used on late models has no effect and shafts are still failing at the same ridiculously low life.
This isn't really surprising, JLR couldn't be ar$ed to fix anything else, and the paint problems got steadily worse.
They were just waiting for the old Defender to go away after 2012, then their problems would be over.
http://www.defender2.net/forum/topic62521-60.html
There's 2 choices, standard or Ashcroft.
Standard will do the same again, absolutely no reason for it to last any longer than the first.
I'm changing to Ashcroft at 22k. Fingers crossed for the next 4000 miles... Confused
Post #722354 8th Aug 2018 8:37pm
agentmulder
Kuwait
Clutch
Drive flanges
Diff seals
At least one CV
Crankshaft seals
Headlight switch
Vaccum pump
Intercooler
Turbo actuator
Injector seals
VCV
Fuel pipe breathers
Wiper rack and boxes
Rear mudflap mount
Door hinge
Master Cyl and pedal box
Glow plug
Injector clamp bolts and little bitty o-rings
Accessory belt, various pulley bearings and tensioner
Radiator
EGR bypass and/or EGR + EGR cooler
Indicator stalk
Thumbs Up Solved the bowel problem, working on the consonants...
Post #722420 9th Aug 2018 2:02am
PAT303
Australia 1998 Defender 110 300 Tdi SW Alpine White
Can I ask,does the Ashcrofts adapter use the clip or does the cover push the shaft into the cup?.
Post #722435 9th Aug 2018 7:59am
I think you'd be foolish to set off on a challenging expedition without checking what type of front diff you have and making sure that it is not the two-gear Rover type.
As far as I know the Ashcroft set-up still uses the spring ring to retain the parts, the screwed cap is designed purely to retain the oil in the coupling and prevent what would otherwise be a continual leak of gearbox oil. No doubt it would also stop the parts disengaging fully in the event that the spring ring failed to do its job, but I don't know what percentage engagement would remain.
Post #722451 9th Aug 2018 9:03am
shropshiredefender
England 2011 Defender 110 Puma 2.4 USW Santorini Black
Mine was well on the way out, it had been replaced sometime before I bought it at 40k miles and has since done 75k.
The replacement had been well greased but it was dry when removed (the grease was dried and in small balls)
I had it replaced with an Ashcroft kit - well made and designed
The above and creating one piece rear half shafts
has eliminated backlash Cool
Post #722506 9th Aug 2018 2:18pm
BenB8man
United Kingdom 2010 Defender 110 Puma 2.4 DCPU Stornoway Grey
Good idea with the half shafts. Are there any downsides to doing it though? Surely LR would have designed it like that if its as simple as that? Are they not supposed to float?
Maybe I just expect too much from LR though, especially considering the easily solved issues that have become common faults so soon. Whistle
Post #722596 9th Aug 2018 10:09pm
Retroanaconda
Pretty common ‘bush’ fix back in the day. I’ve read that they are prone to cracking around the inside once welded, so it’ll be interesting to see how it lasts.
Post #722598 9th Aug 2018 10:18pm
Yannis
United Kingdom 2015 Defender 90 Puma 2.2 CSW Corris Grey
Just received my kit from Ashcroft.
It looks like the cup has been dropped and it’s damaged the anodising;
I will call them tomorrow and I hope they will send a replacement out straight away, but my Defender is currently stuck on the drive until this is fixed....
Post #723484 14th Aug 2018 8:29pm
BenB8man
Give them a call in the morning. Their customer service in my experience, is spot on.
Post #723486 14th Aug 2018 8:49pm
zsd-puma
Late ones had one piece shafts from the factory, as did the Discovery's.
Post #723503 14th Aug 2018 10:16pm
Grenadier
I wonder whether any cracking that does appear would be to do with off road use stressing the weld, or in road use with the G's associated with high rotational speed. My DC is 95% Road use, do most normal cars have fixed or floating? Perhaps that would govern if it was a worthwhile upgrade to a road biased Def? Monsieur Le Grenadier
2011 Puma 110DC - Corris Grey
Post #723533 15th Aug 2018 7:39am
Grenadier wrote:
I wonder whether any cracking ... the G's associated with high rotational speed ...
No way would the wheels ever rotate fast enough for " the G's associated with high rotational speed" to be a factor. Any cracking of the weld would be due either to a poor weld in dissimilar alloys or due to the fact that the drive and retardation driveline loads are being taken by the weld not the splines (especially since the weld is likely to have been applied to well-worn splines).
The concept of "floating" halfshafts is irrelevant - the only reasons for making them in two pieces is to facilitate manufacture, it is cheaper and easier to do than to make single piece shafts. Any resultant movement is undesirable since it inevitably increases wear. As such one piece shafts have advantages in all situations, not just certain situations. How many HGVs do you seem with two-piece halfshafts?
If you took a set of brand new shafts and flanges, which were a good fit, and welded them with a really good full penetration weld (perhaps even J-prep or similar) I have little doubt that they'd be just as strong and durable as single piece shafts. A bush weld on a failed joint will never even come close.
Post #723543 15th Aug 2018 8:42am
PAT303
Why bother,your never going to see it again once fitted.
Post #723554 15th Aug 2018 11:14am
PAT303
Just a quick question,whats the best way to seal the bottom bolt in the transfer,I've used sealant and thread tap and the damn thing is still leaking.
Post #723555 15th Aug 2018 11:16am
