Home > My Defender > My 110 MILLIE. |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20561 |
Not a fan of those at all.
Mine with the corner protectors and especially chequer pate corners saved mine from a lot of damage but unfortunately the arch spat was screwed but at least the panel wasn't. KEEP CALM AND Drill ON ๐ฌ๐ง๐ด๓ ง๓ ข๓ ฅ๓ ฎ๓ ง๓ ฟ๐ด๓ ง๓ ข๓ ท๓ ฌ๓ ณ๓ ฟ๐ด๓ ง๓ ข๓ ณ๓ ฃ๓ ด๓ ฟ๐ฎ๐ช๐บ๐ธโฝ๏ธ๐ข๏ธโ๏ธ๐งฐ๐ช Last edited by custom90 on 1st Jun 2018 9:39pm. Edited 1 time in total |
1st Jun 2018 8:05pm |
L110CDL Member Since: 31 Oct 2015 Location: Devon Posts: 10844 |
I was lucky as my spats are flexi-rubbery ones so no damage to them that is a good thought though, additional armour on the back sides, will look into that Clayton.
1st Jun 2018 9:38pm |
Bond them on too if you did go CP. That way they'll likely come off or hand off after taking the hit but save the panel.
If they are rivertted affixed with fixings they'll likely damage the panel. I think you know what I'm getting at. KEEP CALM AND Drill ON ๐ฌ๐ง๐ด๓ ง๓ ข๓ ฅ๓ ฎ๓ ง๓ ฟ๐ด๓ ง๓ ข๓ ท๓ ฌ๓ ณ๓ ฟ๐ด๓ ง๓ ข๓ ณ๓ ฃ๓ ด๓ ฟ๐ฎ๐ช๐บ๐ธโฝ๏ธ๐ข๏ธโ๏ธ๐งฐ๐ช |
1st Jun 2018 9:40pm |
Thanks Steve, trying not to go down the CP route, but still a good idea with the fixing method Clayton.
1st Jun 2018 10:05pm |
mk1collector Member Since: 17 Sep 2009 Location: West Yorkshire Posts: 6771 |
Yeah that would make it more difficult. Ray My build thread http://www.defender2.net/forum/topic17615.html |
1st Jun 2018 11:06pm |
Clayton.
3rd Jun 2018 7:48pm |
I do love your truck Clayton, purposeful.
3rd Jun 2018 7:59pm |
Many thanks GREENI Clayton.
3rd Jun 2018 8:03pm |
lb73 Member Since: 27 May 2016 Location: North Wales Posts: 294 |
Canโt beat a roll cage on a defender 1999 300TDI 110 CSW BMW 3.0
1972 VW Beetle 1200 2002 Dax Rush 3.9 V8 2012 Audi A3 tdi 2020 Renault Kangoo electric |
3rd Jun 2018 8:26pm |
^^^ Clayton.
3rd Jun 2018 9:03pm |
Well i have the last bit of the puzzle for you regarding the product i'm using on the arches
After the great day we had green laning, Millie was really muddy so i thought it would be a good time to see how the " product " does under pressure, so late evening i went down to my local garage and pressure washed Mille off, it took 2 go's to get respectable again i made sure that the arches had a good clean then came back home and then after the normal working days Millie has been doing, over a week now, so in the first pic i started to rub the arch to see what would happen, with a bit of water, nothing else, i rubbed with an old dirty towel , this was the result, left clean bit, right dirty arch before the rub ........................ Click image to enlarge The next pic is with more of the arch cleaned off ............................... Click image to enlarge So it's nice and smooth to touch and it has faded a little but it is still better than the other products i have used, i dont know if i mentioned it but i only put the ONE coat of this on in the beginning to see what would happen, so here is the product ..................................... Click image to enlarge It certainly does what it says on the front I will be using this again, good stuff and try and build up a good barrier to keep the arches looking good Clayton. 1996 Golf Blue 300Tdi 110 Pick up. Keeper. |
4th Jun 2018 7:40pm |
On another note i kept on painting my front bumper to keep it in good appearance, but after a while i got fed up of rubbing it down and re-painting so i got it shot blasted, then galvanised to help it last longer then i painted it black again, so after a few more years touching it up, i thought i'm back to square one, so i have took all the black paint off and this is the new look ......................................
Click image to enlarge I really like it and very happy with the end result Clayton. 1996 Golf Blue 300Tdi 110 Pick up. Keeper. |
4th Jun 2018 7:46pm |
seriesonenut Member Since: 19 Nov 2014 Location: Essex Posts: 1228 |
Industrial. I like it 1984 One-Ten CSW
2010 XS USW (sold) 1957 Series One 88 diesel 1958 Series One 88 4x2 |
4th Jun 2018 8:02pm |
Rosco Member Since: 03 Dec 2010 Location: Burntwood Posts: 1836 |
Really love the look of your 110 Clayton 2007 - Stornoway Grey 90 XS SW - Gone
2002 - Black Discovery II - Gone 2014 - Montalcino Red 110 XS SW |
4th Jun 2018 8:14pm |
