Home > Td5 > new fuel pump,cleand out harness now running s**t...help
Page 2 of 6 <123456>
mk1collector
You wouldn't see any leaks if the injector seals have gone as they leak into the engine but your oil may be rising with the diesel in it Ray
My build thread
Post #587033 22nd Dec 2016 6:29pm
roel
I believe there is a small mesh filter in one off the pipes near the fuel filter, can that be the problem? Can somebody advise? I am not sure in which connection it is sitting. Roel
2003 90 Td5 (2009-now)
Post #587040 22nd Dec 2016 6:46pm
dorsetsmith
Post #587042 22nd Dec 2016 6:58pm
roel
Thanks I new somebody would reply quickly. Thumbs Up Roel
Post #587045 22nd Dec 2016 7:09pm
dorsetsmith
also on early fuel filter heads td5 had none return valve fitted they can jammed closed stopping fuel flow Exclamation
Post #587065 22nd Dec 2016 8:13pm
psimpson7
Australia 2014 Defender 90 Puma 2.2 XS CSW Loire Blue
Also check to see you dont have 2 seals on the fuel filter. sometimes the one from the old filter sticks on the housing and then the filter doesn't seal properly and allows air into the system 2001 90 HT 6.0LS/6spdAuto.
2003 90 td5 soft top.
2014 90 XS SW 2.2.
Post #587108 22nd Dec 2016 10:43pm
lozza
morning,will do those other checks and let you know
loz
Post #587158 23rd Dec 2016 10:57am
lozza
latest,it is starting ok but when you press the throttle its very hesitant untill full throttle then it revs,fuel line disconected at filter ignition on fuel flows great,when the engine is running the filter gets hot to hot to touch,new filter same thing,i am thinking regulator,just been down the bypass at 70 deffo not right not the smooth td5 more lumpy and filter roasting after 2 mile run
reading the manual regulator seems to be the one ,before i buy a hawkeye diagnostic would it show the regulator as a fault or is it a visit to a dealer
thanks
loz
Post #587685 26th Dec 2016 2:43pm
dorsetsmith
NO
Post #587693 26th Dec 2016 3:11pm
lozza
no as in?
Post #587694 26th Dec 2016 3:12pm
dorsetsmith
are you refereeing to item 13 ?
Post #587697 26th Dec 2016 3:16pm
dorsetsmith
lozza wrote:
no as in?
Post #587698 26th Dec 2016 3:17pm
lozza
i am referring to 13
Post #587700 26th Dec 2016 3:24pm
lozza
dorsetsmith wrote:
lozza wrote:
no as in?
thanks
Post #587701 26th Dec 2016 3:26pm
lozza
is it normal for the filter to get as hot as say a real hot coffee you have to put down
Post #587704 26th Dec 2016 3:27pm
