Home > Td5 > new fuel pump,cleand out harness now running s**t...help
Page 4 of 6 <123456>
Raywin
United Kingdom 2001 Defender 90 Td5 HT Java Black
One here: http://www.ebay.co.uk/itm/LAND-ROVER-DISCO...7oWDbP_vSQ
Or here
http://www.ebay.co.uk/itm/FUEL-PRESSURE-RE...Swxp9W6ArI
Bit more expensive
http://www.ebay.co.uk/itm/Land-Rover-Disco...Sw-KFXdTVa
If you type TD5 pressure regulator kit into e bay search there are several options, if you just type TD5 pressure regulator then you will also see the full unit, but as I said the housing is just an aluminium casting and not subject to wear.
You pays your money and takes your choice.
If you buy the gaskets separate then remember the P10 has a different gasket to the P 15, and if you do it yourself take great care the little filter in the head falls out when you pull the o ring out and it gets lost beyond any finding......... I know. Ray
Post #587799 26th Dec 2016 7:53pm
lozza
thank you very much sir
if its not this at least thats one more thing out of the equation
cheers
loz
Post #587815 26th Dec 2016 8:51pm
Raywin
Hope it works, at least it's not a fortune if it is not the real cause
keep us posted Ray
Post #587850 26th Dec 2016 10:07pm
lozza
ok,having removed the air bleed valve i know its one way but blowing through it is NO way valve
QUESTION...should i be able to blow through the valve with air line or mouth
loz
Post #588140 28th Dec 2016 1:40pm
dorsetsmith
new ones only by mouth as soon it wet with fuel it starts working it will bleed air from fuel one way only
Post #588141 28th Dec 2016 1:47pm
lozza
so there is no way to test the one that is in it,just put it back in and still the same spins on the key almostcatches but wont
loz
Post #588146 28th Dec 2016 2:05pm
lozza
gonna buy a hawkeye when the shops re open,mate has one but for a disco td5
Post #588148 28th Dec 2016 2:10pm
JWL
A few years ago when mine "blocked" I cracked it open with my penknife and washed it with some lighter fluid, didn't do much so I thought that I hadn't anything to lose by halving the amount of "filter" medium that went back in. It did cure the major problem for long enough for me to get hold of a new one.
Earlier models didn't have them fitted and there's plenty of people around that have binned the things all together.
Post #588277 28th Dec 2016 8:04pm
Raywin
Not sure here but are you mixing up the bleed valve and the non return valve?
The non return was not in all vehicles but that's the one on the front filter connection nearest to the chassis, it has something like the neck of a baloon inside it which is what blocks the return flow.
The bleed valve is on the back side of the filter and inside is a little plastic fitting with an o ring around it and some white (when new) material in the center. Ray
Post #588329 28th Dec 2016 10:02pm
dorsetsmith
Post #588362 29th Dec 2016 8:02am
Raywin
That one is the bleed valve Ray
Post #588373 29th Dec 2016 9:01am
lozza
dorsetsmith wrote:
thats the one,it seems like the fuel system is not pressuring up enough....it nearly starts but not quite......all ive done is change the filter and the injector loom.....pump is pumping......if i spin the engine long enough it will start so loom is doing what loom does.....got the fuel regulator on order so as soon as that comes i'll fit it .....and going to get a hawkeye from somewhere
loz
Post #588378 29th Dec 2016 9:35am
lozza
surprisingly the fuel regulator i ordered came today.....just fitted it......no change!!!!!
Post #588437 29th Dec 2016 3:58pm
mk1collector
Dodgy new fuel pump? Ray
My build thread
Post #588489 29th Dec 2016 6:08pm
bob neville
Totally unrelated to the fuel system but a dodgy crank sensor and/or missing shim ?
Easy to find and fix.
Sensor is on top of the bellhousing at the 1 o clock position as seen from the rear of the vehicle. it is approx 50mm behind the cylinder head.
If you need a shim it is NSJ000010.
2013 Defender 90 CSW - sold
Post #588493 29th Dec 2016 6:20pm
