![]() | Home > Td5 > new fuel pump,cleand out harness now running s**t...help |
lozza Member Since: 13 Oct 2016 Location: oxfordshire Posts: 190 ![]() |
injectors checked by me and the indi guy with posh diagnostic
Sorry but that is not correct ! My TD5 had flat spots and missed at 2000 rpm. Up to 2000 rpm it was fine, maybe a bit sluggish, but still OK to drive. The cause - crank shaft sensor !!! They can be an on/off type fault but I have helped a few people now with running issues on TD5's and probably a third of them had a sensor problem or the famous missing shim that was the subject of a LR recall. I am not saying this is your problem but the mechanic should not have dismissed it - it takes minutes to check if it is OK and the shim is present ! Bob 2015 Jaguar XE240 R Sport - goes like ....... !! 2013 Defender 90 CSW - sold 2009 Defender 110 Double Cab - sold 2001 TD5 90 CSW - offroad project - sold to a forum member 2011 Porsche Boxster - for the sunny days ! |
grafty99 Member Since: 15 Aug 2012 Location: North Devon Posts: 4796 ![]() ![]() ![]() |
Have you got another fuel pump to try? It is the title of this thread! assuming everything was ok before the pump change? 2002 90 Td5 Station Wagon
I've asked both of those questions
![]() My build thread http://www.defender2.net/forum/topic17615.html |
excossack Member Since: 22 Feb 2012 Location: North West Posts: 5900 ![]() ![]() ![]() |
I didn't spot that! 1999 Defender TD5 110
He's very adamant that there's nothing wrong with the pump
right guys,did the injector seals today and.............. and............. fixed at last,all were worn after 150k so touch wood thats all fixed,thanks for all the advice,new clutch fly wheel and disco transfer box this year so no doubt ill be asking for advice again
thanks loz |
Result
![]() Bob 2015 Jaguar XE240 R Sport - goes like ....... !! 2013 Defender 90 CSW - sold 2009 Defender 110 Double Cab - sold 2001 TD5 90 CSW - offroad project - sold to a forum member 2011 Porsche Boxster - for the sunny days ! |
went out this morning ....instant start.....bang on
loz |
