Home > Td5 > new fuel pump,cleand out harness now running s**t...help
Page 1 of 6 123456>
lozza
hi,i put a new fuel pump in my 99td5 Censored would not start,looked in the red ecu and full of oil,had the old girl from new only ever cleaned the harness once about 13 years ago never had a problem,sprayed it all out with contact cleaner pulled out the white bit and cleaned under that as well ,now running very hesitantly like a massive flat spot then power but not quite like it should be,you press the throttle and nothing happens at first then the engine catches up
any help much appreciated
thanks
loz
Post #585387 15th Dec 2016 7:32pm
pj2106
United Kingdom 2008 Defender 110 Puma 2.4 USW Stornoway Grey
Try unplugging the maf sensor see if it makes any difference probably need replacing but only with genuine/vdo I assume you have replaced injector harness already? If not that would be first port of call easy to do about 30 mins job again use genuine loom only 2008 110 2.4 XS Utility (Hagrid)
2002 90 TD5 Hardtop (Sully) Sold
1998 300TDi D1 (Billy) Sold
Post #585409 15th Dec 2016 8:27pm
roel
Netherlands 2003 Defender 90 Td5 PU Caledonian Blue
You have to replace the injector loom. That's where the oil is coming from. You will still have plenty of oil in the main loom that will come out giving time. So you will need to clean you red plug regulary till you see less and less oil coming out.
Take the ECU out and place it with the plugs down, I hope you didn't get much oil in the ECU. Roel
1984 90 2.5 na Diesel - RR V8 (1994-2001)
1997 Camel Trophy Discovery 300TDI (2001-2009)
2005 G4 Discovery III 4.4 V8 (2008-2018) It's gone but it still hurts.
2003 90 Td5 (2009-now)
Post #585541 16th Dec 2016 10:02am
MadTom
The oil is not the real problem, real problem of the loom are tiny connectors on the injectors side of the loom. It loosens contact.
But with replacing the fuel pump you need to purge the fuel system. And it can take quite a bit of time. The procedure was already described somewhere here. And also the new pump can be faulty. If you unplug a pipe from fuel pressure regulator, and switch on the ignition, fuel must squirt out, not just slowly flowing. Put the pipe into a suitable container to catch the fuel. It should be approx. 3 l/ hour of fuel. "Drobek" = The Small One - Discovery 2, "Blufínek" = The Blue Thing - Defender 130, and for me at least Ford Mondeo Smile
Post #585561 16th Dec 2016 12:10pm
lozza
thanks for the reply's,pump is working gonna change the loom,forgot all about the loom issue to be honest only had it once in 16 yrs
loz
Post #585717 17th Dec 2016 8:20am
lozza
update.....replaced loom,cleaned out any oil in red connector still not running Big Cry Big Cry Big Cry Big Cry Big Cry Big Cry
any other ideas lads
loz
Post #586777 21st Dec 2016 4:58pm
mk1collector
Disconnect the maf and drive it about for a week Ray
My build thread
Post #586788 21st Dec 2016 5:23pm
lozza
its just not starting now,cycled the pump done the 5 throttle press cycle just loads of white smoke
Post #586793 21st Dec 2016 5:40pm
bob neville
Injector seals gone or fuel pressure regulator leaking ???
2013 Defender 90 CSW - sold
Post #586814 21st Dec 2016 6:42pm
grafty99
+1 for injector seals, gets progressively worse till it won't run.... 2002 90 Td5 Station Wagon
1990 Vogue SE
Triumph Tiger Explorer 1200
Post #586824 21st Dec 2016 7:30pm
MadTom
Once after replacing fuel cooler, I was not able to purge the fuel system. After 1 hour playing I have just pressed the gas pedal for full throttle and let the starter run for long time (30 seconds). And it finally started, with big cloud of smoke. After that it runs perfectly. "Drobek" = The Small One - Discovery 2, "Blufínek" = The Blue Thing - Defender 130, and for me at least Ford Mondeo Smile
Post #586869 21st Dec 2016 9:18pm
lozza
hi,no leaks anywhere was performing perfectly for 15 yrs before fuel pump went quite suddenly on a 10 mile drive,it will start with jumpleads and 15 mins of trying,had ecu off over night no oil came out,i was gutted when it did not start with the new loom,going to get a new regulator and air mass thingy but still very open to any advice
if you let your fuel pump start cycle compleat then press the throttle 5 times it will constantly cycle and the engine light will flash purging the system
loz
Post #586897 22nd Dec 2016 7:25am
grafty99
Have you replaced the fuel filter? And also is the replacement pump a genuine one? I have heard stories of brand new aftermarket ones failing literally immediately, as in they don't work our of the box.... 2002 90 Td5 Station Wagon
1990 Vogue SE
Post #586923 22nd Dec 2016 9:45am
grafty99
Also if you do replace the filter make sure it is filled with fresh diesel not the stuff out of the old filter Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Post #586925 22nd Dec 2016 9:47am
lozza
new filter,pump is a good one 220 quid i have had it running but needed jump leads to start it,spoke to a indi dealer today he seems to think its injector seals but there is no leaks anywhere and it was running perfect before the pump gave up
Post #587014 22nd Dec 2016 5:26pm
Page 1 of 6 123456>
