![]() | Home > Technical > Oil advice and recommendations here! |
oilman Site Supporter Member Since: 19 Mar 2009 Location: Cornwall Posts: 511 ![]() |
There is no one best oil, it depends on many factors! Cheers Guy Use the code DEF2 and get 10% Club Discount View Opie Oils Current Offers Here > > oilman's website: http://www.opieoils.co.uk/ - register for news and offers email: sales@opieoils.co.uk phone: 01209 202944 |
It will be ok, it might drop his mpg a bit though as the 5w-30 is used for fuel economy reasons. Cheers Guy Use the code DEF2 and get 10% Club Discount View Opie Oils Current Offers Here > > oilman's website: http://www.opieoils.co.uk/ - register for news and offers email: sales@opieoils.co.uk phone: 01209 202944 |
it's perfect from -15�C in Alleghe (Alps where live my father in love, but helped by my Webasto Themo Top C) to +38�C (Italian Summer, more in the sud) Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition ![]() IID Pro MV License |
Ok, I know I'm a engine designer... but following you experience, for the Puma 2.4 Engine (no particulate filter), in your personal opinion the best oil is? Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition ![]() IID Pro MV License |
It all depends on application and what are you planning to get from your choice of oil. My personal favourites are the ester synthetics.
![]() ![]() ![]() I agree very good oil... On my KTM I use and I always used ester synthetics ![]() it is also true that 90% of the best additives for oil (and make the difference) are produced by only two large manufacturers, Mobil and Lubrizol ..... Many thanks Guy Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition ![]() IID Pro MV License |
ppad Member Since: 16 Nov 2012 Location: now, UK S Coast Posts: 223 ![]() ![]() ![]() |
Hi Oilman,
2005 Td5 90 truck cab, bog standard, 60k miles I was about to do some long drives so asked the local garage (they say they have Landy experience) to change oil, filter and rotor. The invoice said: 'Mobil 5-30' and that's it. No info on type or standards. I assume it is OK oil, but interestingly, the temp guage now reads cooler. It was a tad over the vertical, now it's a tad under the vertical, maybe 10 degrees of guage angle less. Should I ask them for details?? What? (and do Mobil make unsuitable oils ??? ) Thanks Sold the much modified 110 2.8, in Oz Brought the 90 home from Switzerland ... |
Oilman, Asking a bit further clarification for a 2009 model year Puma 2.4, so clearly no dpf, is there a particular Castrol brand oil which falls in your favourites section? If so, which one? Thanks, Eric You never actually own a Defender. You merely look after it for the next generation. http://youtu.be/yVRlSsJwD0o https://youtu.be/vmPr3oTHndg https://www.youtube.com/watch?v=_GtzTT9Pdl0 https://www.youtube.com/watch?v=ABqKPz28e6A https://www.youtube.com/watch?v=rLZ49Jce_n0 https://www.youtube.com/watch?v=XvAsz_ilQYU https://www.youtube.com/watch?v=K8tMHiX9lSw https://m.youtube.com/watch?v=dxwjPuHIV7I https://vimeo.com/201482507 https://www.youtube.com/watch?v=ZSixqL0iyHw |
yoz0807 Member Since: 03 Mar 2016 Location: lancashire Posts: 8 ![]() ![]() ![]() |
Make: Land rover
Model: defender Year: 1999 Engine type: TD5 Performance modifications: bigger intercooler, decat S/S sports exhaust, stage 2 remap Driving style: (road / off-road / track etc) - Road Looking for advice on engine oil to start with But I do want to go through all the fluids and lubes as I like to know they have been done |
andrewlandy Member Since: 07 Feb 2016 Location: Graz Posts: 82 ![]() ![]() ![]() |
why no GL5? |
spudfan Member Since: 10 Sep 2007 Location: Co Donegal Posts: 4761 ![]() ![]() |
Some of the internals don't like it. 1982 88" 2.25 diesel
adseybear Member Since: 08 Oct 2009 Location: Vancouver, Canada Posts: 262 ![]() ![]() |
Question, I've just bought a Volvo V70 D5 (2006 so has DPF). The specs call for a 0w30 A5/B5 oil, castrol recommended by Volvo.
My 2003 td5 defender calls for a 5w30 A1 oil. Is there an oil that would satisfy both? I'm thinking that I probably won't see any harm using a 5w30 in the volvo as it doesn't need to endure any harsh swedish winters. The manual does seem to say a 5w30 is fine for anything above -20. 2003 Defender 90 Td5 CSW Belize Green - "Betty" 1958 Series IIA 109 Station Wagon - "Randolph" - Awaiting Restoration 2019 Jeep Wrangler JL Rubicon - SOLD 2006 Volvo V70 D5 - Ocean Race Edition, SOLD 2003 VW Passat Estate 1.9TDI - SOLD 2008 BMW 320D M Sport Estate - SOLD 2001 Defender 90 Td5 Hard Top - SOLD |
RichLech Member Since: 09 Nov 2015 Location: West Sussex Posts: 115 ![]() ![]() ![]() |
Tim or Guy at Opie.....
Among your M2C934-B spec oils for the 2.2 DPF Puma, you have a G Force C1 Oil that is about half the price of the others you list. Why is it so much cheaper ? |
TopQ1967 Member Since: 14 Feb 2012 Location: Veghel Posts: 236 ![]() ![]() ![]() |
Make: Landrover;
Model: Defender 130; Year: MY2012 Engine 2015. Engine Swapped at 115.000 (oilpump problem) now 135.000; Mods: A lot but no engine modifications (bigger intercooler on the shelf � opting for a ECU upgrade); Use: (road/track etc) 90% road 10% track. Engine oil: Fuchs Titan GT1 Pro C-1 5W-30; Gearbox / diffs: Castrol Syntrans Transaxle 75W-90 API GL-4+. It was a pain to get the C1 oil. Fuchs or a Ford branded oil was the only locally available. I don't know if the gearbox/diff oil is the best I can get. Please advice. Cheers Q. |
