Home > Puma (Tdci) > Fwd LR Service Bulletin SSM38792 2.4 Puma Engine knock noise
Page 7 of 7 <1234567
Grockle
It sounds simular to dullbirds ongoing problem 2.4 90 XS
1968 1/32 scale Britains 109 Pick up.
Post #12684 6th Jul 2009 11:25am
Cannonball
Ireland 2008 Defender 110 Puma 2.4 XS CSW Stornoway Grey
Hi Boglaster
I have the same issue but would describe it as more like a pinking noise on a petrol engine than a knock. Happens between 1500-2000rpm when driving but does not appear when revving engine when out of gear at a standstill. I assume it must be either something to do with the transmission/driveline or perhaps only when the engine is under load whilst accelerating. Maybe a fuel delivery issue?
Post #12693 6th Jul 2009 12:56pm
Bogblaster
United Kingdom 2016 Defender 90 Puma 2.2 Adventure Corris Grey
Thumbs Up Thats right Cannonball, only under load, but not drive train related! Kicks in at 1750 ish and runs off at 2000.
Have spoken to my local LR dealer, am awaiting a call back. 2019 MY Disco 5 HSE Lux
Audi A4 Avant 3.0L TDI Quattro - WOW
2016 90 Adventure
Post #12696 6th Jul 2009 2:03pm
shorty
South Africa 2009 Defender 90 Puma 2.4 XS CSW Chawton White
Bogblaster I bet you a fiver they tell you its completly normal, characteristic of the Tdci motor Confused Land Rover's don't leak oil, they simply mark their territory!
Post #12697 6th Jul 2009 2:30pm
Cannonball
Let us know what your LR dealer comes up with Bogblaster. I would agree with shorty.
Post #12698 6th Jul 2009 2:41pm
robharvey
South Africa 2009 Defender 110 Puma 2.4 SW Alpine White
Bogblaster / Cannonball,
Just found this thread. My 09 110 is doing the same with regards to knocking between 1500-2000rpm under load. Took a new 90 for a spin to compare, and it was much, much quieter. I am about to get a new clutch, so there is a possibility that it may be related.
Any news on your fix, if LR managed to fix it at all.
Post #37616 4th Aug 2010 12:07pm
Bosun
Mmm! Might be similar to an issue I have. Pinking noise after an upshift. Not always though. One of those annoying intermittent faults that never occurs when the dealer has the vehicle. My guess is it's engine management related. If the dealer ever sorts it out, I'll post the outcome. Don't hold your breath though!!!
Post #37620 4th Aug 2010 12:47pm
RobKeay
I have a similer problem. Mine smokes like a trooper when its starts from cold. Then it makes some right knocking noises. Its a 10 plate with 3000 miles on. Its going in on the 11th over night so see what happens!!
Post #37639 4th Aug 2010 8:10pm
lyon99
Scotland 2010 Defender 110 Puma 2.4 USW Java Black
I have the same noise when cold a knocking till its warmed up its a 10 plate also. I will need to get it looked at, And see if the local dealers will do anything about it, And they will look at it and say there is nothing wrong with it as they always do. 110 Utility puma 2.4 2010
110 pick up 300 tdi 1998
Fendt 716 Vario
Post #37642 4th Aug 2010 10:25pm
Bosun
I'll wager you get better service from your Fendt dealer.
Post #37649 5th Aug 2010 8:11am
robharvey
Further to my knocking issue which a couple of you seem to have had. Turns out that Cannonball's (informed)guess was correct, at least in my case. A bolt in my fuel pump had come loose causing a high pressure fuel leak. Dealer has tightened up and it seems back to normal. It also seems to have cured a juddering I got when coming to a stop - almost as though I was going to stall.
Post #42301 9th Oct 2010 8:29am
RobKeay
Stafford landrover fixed mine with an ecu upgrade. Runs great now. Have got up to 7600 miles. The engine still does the odd strange thing. But on the whole is ok now.
Post #42306 9th Oct 2010 9:41am
