Home > Technical > DE CAT PIPE
Page 1 of 5 12345>
driver
United Kingdom 2007 Defender 90 Puma 2.4 HT Stornoway Grey
DE CAT PIPE
I have just got a ss decat pipe from Allisport has anyone ele got one / fitted one ? does anyone know the torq settings for the manifold bolts ?
I had one of these fitted to my 300tdi and it made a good improvement hope this wil be the same.
thanks in antisapation.
Post #31573 6th May 2010 9:02am
PDH
Never fitted one but the torq settings are listed as...
Nut/bolt � 40 Nm / 29 lbf.ft
Stud � 20 Nm / 14 lbf.ft Puma 2.2 90 Stationwagon
Post #31611 6th May 2010 4:36pm
driver
Cheers, i will be fitting it at the weekend and post any changes/results Very Happy
Post #31666 7th May 2010 6:41am
MrFlips
Wales 2008 Defender 90 Puma 2.4 PU Santorini Black
I'm tempted by a decat pipe myself - did you fit it after? Was it tricky to fit? What are the results? Peter
2008 SWB Truck Cab
1952 80" Soft top
Post #34241 11th Jun 2010 8:26pm
jst
Ditto - i would be interested to hear of the results. Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #34246 11th Jun 2010 9:59pm
fekete
United Kingdom 2007 Defender 90 Puma 2.4 HT Bonatti Grey
I got the local garage to fit mine last week and watched them fit it pay the 40 or so quid to get it done its a pain in the bum to fit without ramps and you need additional bolts as the standard are studs Thumbs Up NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY
Post #34248 11th Jun 2010 10:12pm
K9F
Fekete and JMS both had decat pipes fitted just this week and both told me it was worth the effort! Maybe they'll pop along to explain?
That's the next thing on my list I think!
Pipped me to the post by 3 minutes Karlos, we must have been typing at the same time! If you go through life with your head in the sand....all people will see is an ar5e!!
Post #34249 11th Jun 2010 10:15pm
JMS
England 2011 Defender 110 Puma 2.4 USW Stornoway Grey
Driver,
I fitted one last weekend and i have found the results to be very good.
I am currently running with the most recent Land Rover ECU software (as of 4th June) ITG air filter and Alive SS pipe and de-cat.
Fitting was not to much of an issue except if you want to keep the old CAT in one piece. Its huge and to remove it without cutting i had to un-bolt the prop shaft at the front diff and the chassis cross member. Other than that easy.... Rolling with laughter
I found the engine runs quieter, turbo runs much smoother and quite possible getting a few more MPG (will do a tally up on the next re-fill)
Hope this helps.
JMS
Post #34250 11th Jun 2010 10:18pm
MrFlips
Cheers for the replies - I was thinking of fitting one myself, then someone in my Land Rover club said it looked a ba5tard to fit so I became nervous - I think I'll buy one and get my local garage to fit it. Peter
2008 SWB Truck Cab
1952 80" Soft top
Post #34252 11th Jun 2010 10:19pm
fekete
JMS wrote:
Driver,
JMS
They got a still saw on mine Rolling with laughter Rolling with laughter i wasn't laughing at the time Whistle NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY
Post #34253 11th Jun 2010 10:24pm
JMS
Fekete,
I bet yours flys now with the BAS tune in place. Turbo whistle????? Whistle
PS... Just been offered �65 for my old cat pipe... Rolling with laughter
K9,
I recon you should get the SS pipe and de-cat before your tune goes back on!!! Thumbs Up
Post #34254 11th Jun 2010 10:31pm
fekete
Great minds think alike me old mucker Thumbs Up and stop copying all the stuff i get done Rolling with laughter Rolling with laughter Rolling with laughter Rolling with laughter NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY
Post #34255 11th Jun 2010 10:31pm
fekete
JMS wrote:
Fekete,
K9,
Yes she go's well i also had the mid box replaced she sounds good to Thumbs Up NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY
Post #34256 11th Jun 2010 10:33pm
JMS
I bet she does... Thumbs Up
I find the mid box does make a good mirror thou, ideal for when you smack your head on the diff and you want to see how serious the bleeding is before you attempt to get out from under the car. Thumbs Up Rolling with laughter Rolling with laughter Rolling with laughter
Post #34258 11th Jun 2010 10:43pm
fekete
Rolling with laughter Rolling with laughter I can now blast past most vehicles with ease i love it totally different truck Thumbs Up
You should be at the festival not on here NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY
Post #34261 11th Jun 2010 11:03pm
Page 1 of 5 12345>
