Home > Technical > DE CAT PIPE
Page 2 of 5 <12345>
JMS
England 2011 Defender 110 Puma 2.4 USW Stornoway Grey
Maybe on Sunday. Too much to get done tomorrow. Sad
Post #34263 11th Jun 2010 10:20pm
fekete
Have fun wish i could be there.... we love the festivals Thumbs Up NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY
Post #34264 11th Jun 2010 10:23pm
driver
United Kingdom 2007 Defender 90 Puma 2.4 HT Stornoway Grey
Sorry its took a while to update this one but i waited in the end to get a mid box replacment pipe as well befor fitting,
As others have reported fitting the decat pipe is a bit of a pain as the catalic converter bit is right up by the turbo, so removing the propshaft and the chassis crosmember needs doing first,other than that it was straight forward just a bit of wiggling to get it past everything,but you do need 4x new nuts, bolts,washers i also took of the heat shield for a few runs and everything was ok without it.
I also removed the large centre box as well as it seemed overkill on a defender and fitted a ss straight through pipe but left the standerd Landrover tail box in place for now until i can get a ss one.
You will need 5x 50mm m10 nuts and bolts for this as the landrover ones are captive bolts on the silencer.
This all went without a hitch the decat pipe came from Allisport and the mid pipe replacment came from BAS
on starting up the vehicle it does sound a bit more throaty but not excessive, bit like a V8.
When you are driving the noise level is no different than standard, unless you put your foot down then it defenetly picks up quicker and is slightly more noisy but sounds good.it also seems to drives more smoothly
will check mpg over the next few weeks to see if there is any differance.
Post #34891 22nd Jun 2010 8:09pm
MK
sorry if it is a dumb question:
1)I understand to remove the cat I would need to replace the whole snake between the cat and the middle muffler? or just between the cat and the flexible joint?
If so, anybody got a better performance (excluding chips and remaps)?
2) why 2 mufflers? would it be to noisy without the middle muffler?
thanks
MK Puma 110" SW
Post #35288 29th Jun 2010 2:08am
fekete
Hi MK I've removed everything up to the back muffler not noisy at all.... But you can here the turbo whistle Cool ..and yes you have to remove everything up to the middle muffler as its all in one piece Thumbs Up NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY
Post #35289 29th Jun 2010 6:56am
K9F
Aparently unless you're prepared to cut the old one off you have to unbolt the cross-member to facilitate removal of the orriginal cat pipe! Original ones are worth money so I'm told so the extra effort may be worth while! Supposedly there are lots of 'cloned pipes' out there? What that means I'm not sure as I thought they all have to be a certain shape to fit no matter where you purchase them TD5 Alive, Twisted Performance or BAS! Pete mentioned 'cloned pipes' in another thread!
I intend buying a complete system but not until warranty expiry! If you go through life with your head in the sand....all people will see is an ar5e!!
Post #35307 29th Jun 2010 11:10am
Robofarmer
United Kingdom 2008 Defender 110 Puma 2.4 USW Stornoway Grey
fekete wrote:
Rolling with laughter Rolling with laughter I can now blast past most vehicles with ease i love it totally different truck Thumbs Up
You should be at the festival not on here
Do you still love it with just the de cat ! and no remap Question and what difference do you think the de cat makes on its own Question 2008 110 County utility
ex 1988 defender 90 ,td
ex 1970 series III
Post #35314 29th Jun 2010 11:54am
JMS
is this K9F writing this ???
Robofarmer wrote:
Do you still love it with just the de cat ! and no remap and what difference do you think the de cat makes on its own
I am now running standard tune and it makes a big difference. If you want to let the engine breath make sure it is breathing well on the intake also (K&N / ITG air filter will help)
JMS
Post #35344 29th Jun 2010 7:56pm
K9F
Yeah, finally had a twinge of guilt when my dealer refused to drive it due to the dubious legality status of the wheels! I generally have an excellent working relationship and mutual respect and understanding with my service manager, a rare trait in this day and age I do not want to take the p155 or risk invalidation any further at this time! Happy days! If you go through life with your head in the sand....all people will see is an ar5e!!
Post #35355 29th Jun 2010 9:47pm
roel
Netherlands 2003 Defender 90 Td5 PU Caledonian Blue
As most of you drive Puma's but probably had TD5's before, how are the experiences to decat a td5 and removing the big muffler. Does it really give more Oemph or is it just more sound?
Mine will change body very soon so probably a nice time to do this. Roel
1984 90 2.5 na Diesel - RR V8 (1994-2001)
1997 Camel Trophy Discovery 300TDI (2001-2009)
2005 G4 Discovery III 4.4 V8 (2008-2018) It's gone but it still hurts.
2003 90 Td5 (2009-now)
Post #35377 30th Jun 2010 8:47am
lestat
1995 Defender 90 Other PU Java Black
hi all, can the original pipes be taken off and the insides of the big silencer and cat taken out??.
I also fitted a K&N filter direct to the turbo and routed a oblong hole for the MAFS to mount on, thus the engine managemet light stays off,
Post #35403 30th Jun 2010 9:13pm
bell-auto-services
On Microcat it lists a NON cat front pipe, on receipt of mine back in 2007 when i was first tampering with the exhaust the non cat pipe from the outside looked the same as the cat version but it does not have any insides Smile
Pete
Post #35404 30th Jun 2010 9:31pm
Did you take any pictures when fitting? Thumbs Up
Post #44096 1st Nov 2010 3:29pm
Peter Td4
Belgium 2008 Defender 110 Puma 2.4 HCPU Santorini Black
Hi all,
Is it really useful to replace the decat and mid-box on a Td4 Question
I know that on a Td5 the sound is really lovely once the mid-box is removed but since the Td4 is a completely different engine (with a much different sound in standard version compared to a Td5) I'm wondering if it is really worthwhile the expense Confused
In low revs my engine tends to have a very slow respone (EGR will have much to do with this I guess).
Helping it to breathe more freely might help to overcome this (partially) ... or not Question Peter,
Defender 110 StaWa - Td5
Defender 110 HCPU - Puma
Defender 90 Soft Top - Td5
Post #46033 23rd Nov 2010 12:04pm
landy andy
Are you talking about a Tdci, as Td4 are freelander engines Question Question Question
Andy
Post #46068 23rd Nov 2010 8:03pm
Page 2 of 5 <12345>
