Home > Puma (Tdci) > 2.2 Turbo/Intercooler pipe recall. *** WARNING ***
Page 1 of 3 123>
Jim_Bean
*** UPDATE - SEE NEW PHOTOS LATER IN POST ***
So we went on our first proper camping trip this weekend and on the way back the engine light came on and I lost the turbo completely. Even with my foot flat on the floor she wouldn't do more than 30. Luckily I was only 5 miles from home.
I'm really disappointed but not at all surprised. After such a crap experience with the two Discovery 3s that we had I was hoping the Defender would be much more reliable.
This is my 7th Defender but i've not had one for a few years. I was just hoping the Puma would be better.
Just waiting for the Land Rover assistance guy.
I hope this is not start of things to come.
Post #249805 7th Jul 2013 7:32pm
borderterrier
United Kingdom 2013 Defender 110 Puma 2.2 XS CSW Aintree Green
Poor you, I hope its nothing serious and they sort it quickly
Post #249808 7th Jul 2013 7:34pm
ericvv
Had the same when my truck was also relatively new. Went into limp mode several times with engine mgmt light coming on like yours, but nothing wrong with the turbo. Limp mode means no turbo of course. It actually was all down to a faulty EGR valve, which once replaced under warranty, never went into limp mode again.
Hope it is as simple as that in your case too. Thumbs Up You never actually own a Defender. You merely look after it for the next generation.
http://youtu.be/yVRlSsJwD0o
https://youtu.be/vmPr3oTHndg
https://vimeo.com/201482507
Post #249815 7th Jul 2013 7:42pm
Jim_Bean
I hope so too. They've cancelled on me now and told me it will be 8am tomorrow morning.
Another day late to work because of Land Rover.
Post #249817 7th Jul 2013 7:43pm
alwoodley72
England 2008 Defender 130 Puma 2.4 HCPU Alaska White
Hi, we had the same last weekend, puddle of water too... Turned out the turbo hose had come off, and the clip was still there! Happy days!! Hope yours is as simple, sounds just the same symptoms
Alex
Post #249855 7th Jul 2013 9:13pm
JeremyJ
Sounds like your intercooler pipe has come off. Crying or Very sad
Post #249857 7th Jul 2013 9:13pm
Jim_Bean
Land Rover are here now. Apparently the alternator pulley has cut through the turbo pipe.
Its a very common fault apparently...
Post #249895 8th Jul 2013 7:48am
Caterham
amazing - really basic stuff and they're still getting it wrong ??
glad it was a simple fix and no damage done (to the car that is) - confidence and incovenience, thats something else.
hopefully happy motoring from here on
Post #249897 8th Jul 2013 7:57am
familymad
Does the fix still allow the same again in another 1400miles? 1951 80" S1 2.0
1995 110 300TDI
1995 90 300TDI
Post #249899 8th Jul 2013 8:06am
Jim_Bean
The Technician explained that the pipe is just poorly fitted as opposed to a poor design. However, he has reported it many times.
You can see how the pulley has cut a large hole right through the intercooler pipe...
It shouldn't happen again once fitted in the right position. My concern is that air and melted bits of plastic have been able to bypass the filter and go straight into the turbo.
I guess time will tell, thank god for the warranty.
Post #249903 8th Jul 2013 8:16am
Froogle-Yorkshireman
2010 Defender 110 Puma 2.4 USW Stornoway Grey
Speak to Solihull - Surely a free first service for the inconvenience Question Proud owner 110 Utility XS
Ex RR Sport HST V8
Ex Td5 90
Post #250056 8th Jul 2013 7:53pm
zahy
United Kingdom 2013 Defender 90 Puma 2.2 XS CSW Barolo Black
Had the same last weekend ( covering only 2500 miles from new) turned out the turbo hose had come off with the clip feel off, my local dealer fitted two clips to the hose (JUST IN CASE) according to land rover recovery LR will be releasing a modified hose/clip Shocked
Post #250062 8th Jul 2013 8:14pm
K9F
Indeed it is! Thumbs Up
http://www.defender2.net/forum/topic20804.html
Recently replaced mine with stainless steel hard-pipes! Was the other side that had evidience of chafing on mine....against the alternator. If you go through life with your head in the sand....all people will see is an ar5e!!
Post #250121 8th Jul 2013 11:26pm
ericvv
Mal, are you referring to the Entreq Airflow Kit which they produce for the Td4? If I remember well, those from Entreq are for the Puma 2.4, correct? These here:
http://www.entreq.de/products-lr-defender/...r-td4.html
Worth your while I guess. Several years ago I had a turbo hose split on my Puma, which was then replaced under warranty. But I would be happy to have it once and for all out of the the way.
Post #250125 9th Jul 2013 4:34am
K9F
Eric,
It is indeed those very pipes but they didn't come from Entreq. As everything from Entreq it is top quality and top dollar. But a stainless pipe with silicone ends is a stainless pipe with silicone ends. £343???? I think not!!!!! Thumbs Up If you go through life with your head in the sand....all people will see is an ar5e!!
Post #250154 9th Jul 2013 8:02am
Page 1 of 3 123>
